TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 19, 2019 at 2:10 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    What are the chances I’ll ever see a tune for my Lexus LS430?
  2. Apr 19, 2019 at 2:27 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    What engine are you using? The support functionality is really up to @HPTuners not Justin and based on the fact that Lexus is a luxury line before a performance line outside of the IS series I would say the chances are slim unless you are running the 1GR-FE or the Tundra V8s.
  3. Apr 19, 2019 at 5:10 PM
    Kelvin
    Kelvin Wheeeeee
    Well it’s kind of a tundra motor. 3UZ-FE. Although when people think tundra they think the 3UR or something. Mine is just a lower displacement higher compression 2UZ running a premium tune.
    BassAckwards likes this.
  4. Apr 19, 2019 at 5:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh yes, I recognize the engine family.. Okay let me re-ask, because what is important here is the operational PCM.
    What PCM is it? There is a specific support list which drive all the engines supported by HPTuners. If yours is a 3UZ or a 2UZ then you should be good to go.
    Kelvin[QUOTED] likes this.
  5. Apr 19, 2019 at 6:18 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    The differance between the 2nd gen and 3rd gen lug nuts. I dont like them. So much less surface area for the socket to grab hold of.
  6. Apr 19, 2019 at 6:28 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I'm bout to torch this thing.
    So mechanic calls, he says he doesn't think the rear bearings need to get changed, he thinks its a gear whine of some sort either from Trans/Transfer case/Rear diff, we just swapped the rear diff...he said the transfer case fluid looked perfectly fine. I said change the rear bearings anyways since I already bought em. Dunno what to do if that doesn't fix it. Gonna have to just take it back to the shop that set up the diff and let him rip the rear end apart. That should be a fun bill. FML dude.
  7. Apr 19, 2019 at 6:41 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Well... 2nd gen lug nuts can leave you stranded. I always carry a good set of tools including impact wrenches.
    B2195974-0673-40B6-AA6C-F5F8179BAE6D.jpg F959762C-578A-4293-8472-4EFF7EBE774D.jpg
  8. Apr 19, 2019 at 6:42 PM
    VolcomTacoma
    Jeff
    NorCal
    ^yeah done that before. Toyota lug nuts are a joke. Especially when some grease jockey at a tire place just goes to town with an impact, next time you touch em the caps pop off like that.
  9. Apr 19, 2019 at 6:43 PM
    Kelvin
    Kelvin Wheeeeee
    No idea honestly :anonymous:
    I’ll check when I get through this 2 hours of traffic. Most people with this engine are from the GS430 guys that pursue performance. Most of the time they just go AEM piggy. Supercharged guys I can count on one hand.
  10. Apr 19, 2019 at 6:44 PM
    henryp
    Henry
    Montana
    I just took mine to the dealer since I don’t have a press and they do these all the time. My local tire shop wouldn’t change my faulty rear bearing. Took it to the dealer, had bearing changed, and voila the noice was gone.
  11. Apr 19, 2019 at 6:47 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah he said it wasn't the wheel bearing, but a brand new diff shouldn't be noisy like that right off the bat. I'm leaning wheel bearings, since anytime I was turning at high speeds the noise went down or went away. The new drive shaft is coming on wednesday also, so hopefully I change that out and everything is fine after that. If not I'm gonna just take it back to that shop and let him rip it apart. I would rather just pay one more big bill and have it fixed than keep running after it part by part and not fix it.
    henryp[QUOTED] likes this.
  12. Apr 19, 2019 at 6:51 PM
    Kelvin
    Kelvin Wheeeeee
    I had a lot of those as spares from my 4Runner. Perfect lugs for when I went to ARP studs. Then I switched to kyo-ei lug nuts.
  13. Apr 19, 2019 at 8:24 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    All you people who went green solid coupler. Did it sound a lil louder with the rattle at idle? I’m assuming so since it’s solid compared to the stock coupler with the spring to help with shock loading the rotor pack. @Roostfactor @DocME @SManZ
  14. Apr 19, 2019 at 8:29 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    it looks like you have the shorter 3rd gen lugs.... my 2014 has the longer ones.
  15. Apr 19, 2019 at 8:32 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yeah, just ever so little louder. Hasn’t changed since install 85k miles ago.
    mr.trd likes this.
  16. Apr 19, 2019 at 8:37 PM
    TRON
    Yeah mines I little louder too. I had some play in the pulley when the belt was off. But this solid coupler gives zero play! Lil more responsive too :thumbsup:
    12TRDTacoma[OP] likes this.
  17. Apr 19, 2019 at 8:48 PM
    Kelvin
    Kelvin Wheeeeee
    Well...it’s a denso. All I know right now.
  18. Apr 19, 2019 at 9:37 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'm still using the stock coupler but I have heard that the solid coupler is louder at idle.
    Did you just get a rebuild?
  19. Apr 19, 2019 at 9:59 PM
    henryp
    Henry
    Montana
    Those were stock. ‘09, never changed them until I busted the one. Now they are all new. Maybe 2nd gen sport has longer ones?
    TheFang[QUOTED] likes this.
  20. Apr 19, 2019 at 10:05 PM
    TRON
    Nah not a rebuild quite yet. I need to find someone close by that does rebuilds with presses. Think it would be fun to watch the magic. Anyway just new oil and coupler. My spring had a clean break on the stock one. Good news my blower was completely full of oil and it actually looked pretty good for 95k. Maybe it’s time for a 2.3 :cool: @Roostfactor
