TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 23, 2019 at 4:25 AM
    rockporttaco
    rockporttaco Well-Known Member
    Henry
    Rockport
    S/C 4x4
    TRD S/C, TRD CAI, TRD C/B, URD THERMOSTAT, BDS 6 INCH, FUEL KRANK WHEELS 18, NITTO M/T 295/70
    I'm on my 3rd auto trans. Hopefully it last. Upgraded valve body and level 10 torque converter now. Feels great.
  2. Apr 23, 2019 at 4:28 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    What’s failing in the trans?
  3. Apr 23, 2019 at 4:31 AM
    rockporttaco
    Henry
    Rockport
    S/C 4x4
    First transmission went out at a 101k I think it was the clutch pack. It would go into gear and then it will slip and catch again. When I put it in park it was still in reverse and when I put it in reverse it was in Drive. Second transmission my flexplate shredded and messed up the pump assembly.
  4. Apr 23, 2019 at 5:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you ever have to rebuild it, Raybestos makes higher torque rated clutch packs.
    mr.trd, DocME and BassAckwards like this.
  5. Apr 23, 2019 at 5:05 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    For those doing fuel pumps please search here for the info on improving the urd fuel pump kit. Pulling a tank on these trucks is only fun the first time.
    rmepilot and BassAckwards like this.
  6. Apr 23, 2019 at 5:06 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Do you think a trans rebuild is a shop only mission?
  7. Apr 23, 2019 at 5:07 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Unless you have all of the proper tools and instructions, yes.
  8. Apr 23, 2019 at 7:08 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    BassAckwards likes this.
  9. Apr 23, 2019 at 7:15 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I had a lift and it wasn’t bad. The URD headers make the starter kind of in the way a bit getting to the flywheel bolts. Long extension with a wobble socket made it pretty easy though.
    12TRDTacoma[OP] and BassAckwards like this.
  10. Apr 23, 2019 at 7:30 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yeah. I'll probably just buy a built one but if I could find a core trans to build I'd consider it.
  11. Apr 23, 2019 at 7:37 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I have one ill sell you. Ill have to ship it to ya though, im in tx
  12. Apr 23, 2019 at 7:41 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I moved the input to the relay to an ignition only wire. Only runs when the engine is on. The wire that Magnuson tells you to use is the same one that power up to activate the leak detection pump.
  13. Apr 23, 2019 at 7:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If and when my trans ever craps out, I would go the more aggressive clutch packs, the trans go valve body rebuild kit and the ratiotek kit all in one go.
    Did you move yours to a pin that is still under the fuse box? If you did, can you send some info on where you relocated it to? I've been wanting to do a relocate since I installed the wire and saw how it functioned.
  14. Apr 23, 2019 at 7:47 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I’m also interested to know.
  15. Apr 23, 2019 at 7:50 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1.
  16. Apr 23, 2019 at 8:11 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ran a wire inside the cab to the fuse box inside. There's probably a wire in the engine bay somewhere, but at the time I did it, the truck had a dead battery after sitting for a week while I was on vacation and I was pissed at myself for not addressing it BEFORE there was a problem. I did a quick check at the engine room fuse box for an ignition only wire and didn't find one. It was easier to just run a wire inside the cab, than sit there searching for longer.
  17. Apr 23, 2019 at 8:21 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    For those that have the foglight anytime mod like myself theres the wire in the tiny fuse box in the engine bay that's ignition switched power. I was going to run my solenoid off it soon.
  18. Apr 23, 2019 at 8:31 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I actually have that mod.. that would be a perfect spot to run the pump if it actually only turns on with the car in run mode!
  19. Apr 23, 2019 at 8:50 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Random question but what's a ballpark figure for crank horsepower and wheel horsepower for one of our trucks with a 2.5 pulley (going to 2.3 soon)? Has anyone dyno'd?
  20. Apr 23, 2019 at 8:58 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The circuit is active in ACC, so the pump would run whenever the keys are in the ignition with accessory power.
