TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Apr 29, 2019 at 7:34 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I dont know what's up with my pump. The tank stays full but the gauge shows injection . I'll need to check. Maybe next mod day with my hombre @crashnburn80 . But that's all about him getting on the small pulley bus.. if theres time we might address mine.
  2. Apr 29, 2019 at 7:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I owe him. Anyone that's helped put long tube headers on knows your buddy owes you a favor.
    crashnburn80 likes this.
  3. Apr 29, 2019 at 8:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Really shouldn’t be too hard to troubleshoot in a controlled environment. Test if the pump runs with a different power source, then trace power back from the pump to find the fault.
  4. Apr 29, 2019 at 9:04 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Anyone got a 2.7 they wanna sell?
  5. Apr 29, 2019 at 11:46 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    So after installing a new air intake (this one from aFe) I started to notice a nigh pitched spraying sound while on WOT. Hard to describe, but as if something was spraying at high pressure or a belt is getting shredded to pieces. Only at highway speed and on 4th/5th gear (putting it in neutral or while parked no noise). Does this sound like a bad transmission or the S/C causing trouble. Serpentine and SC belts are brand new and look good. I did do some work 1 month ago (new water pump, new CSF radiator, replaced several pulleys - I torqued everything down to spec and had no leaks over the past month).
    Here is a clip, hard to hear but a high pitch sound only on WOT (comes up twice on the clip). Let me know what you guys think.
  6. Apr 30, 2019 at 6:34 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm not sure.
  7. Apr 30, 2019 at 6:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Negative. You would have to go through one source alone. www.rsgear.com to get their AWD mated Magnum.
  8. Apr 30, 2019 at 8:08 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @Torspd talk me into getting a t56 lol i would love to drive one and see how these truck should shift
  9. Apr 30, 2019 at 8:32 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Selectable or full time AWD? Does it work good? Very interesting...
  10. Apr 30, 2019 at 8:36 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Correct, hard to hear. I don't hear anything out of the ordinary. I do know that changing the intake will change the sound quite a bit. I have gone between my factory and the AFE stage II a few times and with the AFE you can hear the amount of air going through it. My dad has the AFE open element intake, stage 1 I think, on his tacoma and that thing sounds like it is trying to suck small children off the sidewalk. But I love the fact you have such a good spot to jump on the freeway and test under boost. I love that pass. And I love your boost numbers. They look very high compared to mine. What is the elevation of Livingston? Can you watch your boost numbers go down as you climb up the pass?
    henryp[QUOTED] likes this.
  11. Apr 30, 2019 at 8:51 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I still got a 2.85" I will have off shortly. I plan on cutting the snout this weekend after I finish with the Tranny Valve Body upgrade. I have my roush tensioner, smaller belt and everything on hand.
  12. Apr 30, 2019 at 8:54 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Turn your controller to boost mode and change it to kick on at 1psi. Then take the line off that feeds your nozzle, take the vacuum hose off your boost port, turn the key to on (to provide power to pump), blow into the vacuum hose (for the controller) and see if your pump kicks on. This is how i test mine and prime the lines
  13. Apr 30, 2019 at 9:30 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    What belt did you go with?
  14. Apr 30, 2019 at 9:54 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Hard to tell, that's a tough one. Possible it's just the sound of the intake sucking in all that air?
  15. Apr 30, 2019 at 10:21 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It's normal. Nothing to worry about.
    If you are still troubled over it, throw your stock intake back on and run it, if the sound goes away it is purely from the intake.
    The Momentum AFe intake is a gorgeous beast of an intake. I wish I didn't live in California.
    It is my advice to you guys and to all moving forward that you do NOT go with Dayco belts if longevity is your goal. Yes I am referring to Toyota OE belts as well, as they are Dayco, as I have found that their running lifespan is around or less than 10,000 miles before they start getting all cracked.
    Either they do not refresh their inventory circulation and the belts they are selling through their distributors have a case of rubber rot, or they are using inferior materials over Gates and other competitors.
  16. Apr 30, 2019 at 10:26 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    My man! Which reminds me, I need to get that roush tensioner...
    BassAckwards and 12TRDTacoma[OP] like this.
  17. Apr 30, 2019 at 10:31 AM
    henryp
    Henry
    Montana
    Elevation is around 4700’. It’s probably a little richer than afr shows since I’m connected just after the y-pipe. It will drop down to 9 and be super rich at times on the Bozeman pass. Waiting on my new y-pipe that’s gonna have an o2 sensor on each side.
  18. Apr 30, 2019 at 10:36 AM
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    I’ve got one. I’m looking to go with a 2.3 or 2.5.
  19. Apr 30, 2019 at 10:41 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Anything smaller than 2.5 will require another machining of the snout or a cutting of the material underneath the surface the pulley spins over, you can't just step down from the 2.5 to a 2.3 just like that.
  20. Apr 30, 2019 at 10:47 AM
    Wild Heart
    Daryn
    2015 DCLB BRM
    Oh ok. Glad to know. I was assuming that the one cut would be good enough. Thank you sir.
