TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 5, 2019 at 10:17 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Surely, if one spent enough money; they could make just about any engine make a bunch of power. Getting in to forged bottom end bits is far beyond what I’d say 95% of guys are seriously going to even consider.
    I’ll go ahead and take the liberty of saying that just about all of the guys active in these threads would be happy with a dependable daily truck that makes 400hp. This motor, as delivered from Toyota, can certainly handle that.
    We have most of the recipe already. A tablespoon of Injectors, a pinch of pulley, a smidgeon of tensioner, a couple more tablespoons of headers/exhaust, and a big ole heaping cup of TUNING! Mix well and then add in the blower. Cook at 170° to taste. Season with air intakes and cooling system enhancements.
  2. May 5, 2019 at 10:19 AM
    BillDaCat8
    Jake
    PHX
    Maybe I’ve been barbecuing too much lately?
  3. May 5, 2019 at 10:19 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Does the 3UR 5.7 mate up to our transmissions, whether they are auto or stick?
  4. May 5, 2019 at 10:32 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I called LC engineering twice this time, last year discussing a engine built and what specifications and prices etc. Then they never called me back. :boink:
  5. May 5, 2019 at 10:42 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Sounded delicious to me!
    I called them too last year with the same inquire. They wanted nothing to do with it.
    Hawk373 likes this.
  6. May 5, 2019 at 10:45 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Thats what he said, then they said they would consider it. Then they called back and we talked for 30 mins. Then nothing.
    So since they are out I wonder who would be the next logical choice
    Hawk373 likes this.
  7. May 5, 2019 at 10:53 AM
    DocME
    California
    '07 FJ Cruiser
    I really liked talking with Gary @ http://www.larryspower.com/engine/DartonSleeves.html
    They would get my business. Also be a good time to call on @Torspd as he's the only one aside from gadget that has gone down this rabbit hole.
  8. May 5, 2019 at 11:09 AM
    DocME
    California
    '07 FJ Cruiser
    Healthy discussion only. Agreed different strokes for different folks, but we are all in the same proverbial 4,500 pound boat together. You’re right, It’s all bench racing right now anyways. It’s a big investment to start experimenting!
    RyanL, JustDSM[QUOTED] and GT7 like this.
  9. May 5, 2019 at 11:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Molnar Rods are the market cheapest. I helped them get those going. Next are the Brian Crower Rods. There are also Pauter Rods, and CP Carrillo rods - as the most expensive.
    LCE in AZ can build an engine with whatever you want. Even a place more local.
    Sleeves are not necessary unless pushing past upper 500 whp and higher RPMs. As a rule of thumb, due to cylinder wobble and cylinder pressures.
    Rods, pistons, head studs and head gaskets are the basics and will handle more than the TRD will ever give it, as well as making it extremely reliable. You can also then raise the rev limiter without worry, to 6200.
    More than 6200, you want valve springs and retainers. Possibly even upgraded valves or larger valves. SuperTech valves are more affordable than Ferria valves, but are oversized, unless you want "custom" which is where OEM spec falls.
    I had LCE build an engine with CP pistons, Pauter Rods, head studs, head gaskets, dual valve springs and retainers for ~$5k. Including labor.
    Stroker crank and sleeves came in later builds. As well as cams and oversized valves. That obviously made the build price increase.
  10. May 5, 2019 at 11:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a stroker engine and a 6500 rpm limit. :p
  11. May 5, 2019 at 11:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Rods, pistons, plasti-gauge, head studs, you're looking at around ~$2500 depending on parts.
  12. May 5, 2019 at 11:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    LCE does sleeve installs for about $2200.
  13. May 5, 2019 at 11:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They just recently finished assembly of their first fully built 2TR, that they also used for prototyping, and delivered it to @MrCrowntown.
  14. May 5, 2019 at 11:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Factory crank has been proven to handle ~600's whp.
    OEM pistons have very weak ring lands. Best buds are the anemic rods.
    TodayWasTHeDaY and DocME like this.
  15. May 5, 2019 at 11:22 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yeah but both people I talked to sounded uninterested with our engines until The manager or whomever called me back and we discussed build specs and never heard from him again
    DocME likes this.
  16. May 5, 2019 at 11:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    John in tech. They just don't like shelling out tons of information, and investing tons of time, only for someone to take that information elsewhere. Which is understandable. They have built quite a few 1GR's. Three that I personally know of.
  17. May 5, 2019 at 11:33 AM
    DocME
    California
    '07 FJ Cruiser
    I feel like we're talking about two different LCE's, even though I know we're not. A couple of phone calls to them, they talked internally and turned me away. Not sure why our experiences are so different.
    GT7 likes this.
  18. May 5, 2019 at 11:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Couldn't tell you.
  19. May 5, 2019 at 11:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I also most recently had H Squared Performance Engines, build my last two. Here in Houston.
    DocME likes this.
  20. May 5, 2019 at 11:41 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @Torspd what do u think the limits of your motor are. How much boost? How much hp? And how many rpms?
