TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 5, 2019 at 11:42 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    And once you put exhaust cam gears in is it safe to run the redline to 6200? Or does it even make power up that high?
  2. May 5, 2019 at 2:17 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Fuel to the fire... l’m liking the looks of this rabbit hole.
  3. May 5, 2019 at 4:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Don't really know. There is one guy with an X-Runner whom has mirrored my build. His is making over 700 whp with twin turbo.
  4. May 5, 2019 at 4:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look in my N/A Dyno thread. With the proper supporting mods, it does. These heads flow very well. Even with OEM cams.
    Only N/A, is it "safe" to run that RPM on a stock engine. It is harder on the rods though. MUST have a great tune.
    Mine is plenty capable of that RPM. Current cams pick up more HP at the last 1k of the range. Without the VVT-I, it is just a dog down low though. Swapping back for "testing purposes". I know for a fact, it will make the big bore Goldylocks block even look less impressive. With that one, I very quickly made a Hellcat owner shocked, as my truck, with 350 lbs giddy passenger, pulled away.
  5. May 5, 2019 at 4:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The two weak points oh my stroker engine, are the 11 mm head studs, and the block itself. Component strength alone,the block is built for 2000 horsepower.
    BassAckwards and Sacrifice like this.
  6. May 5, 2019 at 4:37 PM
    ThomasMore66
    Ok. I’m in. But damnit, do I play with the 80 first? Bad @Torspd! Is the 700 hp guy running an auto?
    Torspd[QUOTED] likes this.
  7. May 5, 2019 at 4:46 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    How dare someone build a 700 hp and be an auto! X-runners are all manuals!:D
  8. May 5, 2019 at 4:48 PM
    ThomasMore66
    Well, I’m not converting. 750 better be stronger than I think it is.
  9. May 5, 2019 at 4:50 PM
    TRON
    Regardless, the tranny needs to be stout for that kind of power to the wheels
  10. May 5, 2019 at 4:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He's running a built T56 Magnum. Which is literally next on my truck's list.
  11. May 5, 2019 at 4:57 PM
    ThomasMore66
    Oh I get that.
    You guys saw all this come together on the xrunner forum. The 4wd guys are behind. I love haulin ass in a lifted Tacoma with big wheels/tires.
    The guy in the bmw today just didn’t have what it takes to keep up with a Tacoma loaded with mulch.
  12. May 5, 2019 at 4:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With the Raybestos upgraded clutch packs, the 750 transmission can hold between 600-700.
  13. May 5, 2019 at 4:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :bikewheelie::benchpress:
  14. May 5, 2019 at 5:03 PM
    TRON
    That’s the claim. But has anyone tested it on a tacoma yet? So are you still running a twin disc clutch @Torspd
  15. May 5, 2019 at 5:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Lucario Runner is, with the valve body upgrade. He knows his stuff. As far as testing it though, I cannot say.
    Yes sir, I am still. Rated for 1K.
  16. May 5, 2019 at 5:23 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Cams and some original 1UZ fatty connecting rods would be cool. Can’t help but feel it would be a waste of time without some twin turbo setup though. Don’t have the time for that kind of fab time.
  17. May 5, 2019 at 5:33 PM
    TRON
  18. May 5, 2019 at 7:31 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I think I'll just have to be happy with the little power gains I can make here and there safety on my stock engine and SC. For $15k.... I could buy a whole other vehicle!
    So I'll just keep modding this one and every night pray, "God grant me the serenity to accept the things I cannot boost; courage to boost the Tacoma I can; and wisdom to find the funds."
    GT7, Kelvin and Torspd like this.
  19. May 5, 2019 at 7:43 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    And I only say that because I can't afford it. lol If I had the cash available, a shop with a lift, and a sweet 1000hp crate engine.... then I would pray, "God grant me the serenity to accept the things I cannot mod; courage to chop and weld and cage and wheel and cannibalize the Tacoma I can; and wisdom to know when to stop."
    BassAckwards likes this.
  20. May 5, 2019 at 7:44 PM
    Kelvin
    Kelvin Wheeeeee
    It’s how I see things too. Rather have a land cruiser in my driveway than have maybe an extra 100 hp.
