TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 6, 2019 at 10:14 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    ^I think it just depends on what you use it for.
    I've got a super fun built for offroad truck that sees dirt like twice a year lol. 315/75/16s on 4.56 with a 6 speed feels so much slower than what 295/75/16s on stock gears felt like. Granted I went from a semi lighter all terrain to ST MAXX's, but jesus, the thing is a pig at this point lol. TBH I didn't see much of a difference in offroad performance in tire size from 34s to 35s...never had issue on my other truck with 33s. I imagine if I was doing some super crazy rock crawling 35s would probably be beneficial, but that's not really what I built my truck for. So I dunno.
    snowsk8air2 likes this.
  2. May 6, 2019 at 10:39 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’ll definitely look into this more. From what I saw, the 4.10/33 combo takes you back to equal to stack configuration.
  3. May 6, 2019 at 10:51 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I forget the exact number, but I believe stock would be like 4.33 for 33’s so you’d be under gearing at the 4.10’s. I went higher for better off road performance.
    But like @VolcomTacoma said, it depends how much dirt and what kind of dirt you see. I hit dirt frequently and since most of my buddies have jeeps it has a good mix of high speed and crawling. Crawling definitely benefits more from the higher gearing ratio.
  4. May 6, 2019 at 10:53 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Hmm my 285/75/16 st maxx supposedly weigh 64lbs and 315/75/16 st maxx supposedly weighs only 69lbs. So
    How much difference can 5lbs really make
  5. May 6, 2019 at 10:53 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Once you get the HPTuner you can get rid of the speed limiter...
  6. May 6, 2019 at 11:20 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Since the tire size recalibrator doesn't work for speedometer adjustment (yet), are we sure the speed limiter is actually working?
  7. May 6, 2019 at 11:26 AM
    VolcomTacoma
    Jeff
    NorCal
    Ah-hah, but like I said, I went from an All terrain to ST Maxx. St Maxx is just an all around heavy tire. Toyo AT2s in 285/75/16 are only 58lbs, so 11 lb difference per tire. That's still alot of rotational mass. Even 5lbs, you'd notice a difference. That's 20lbs of extra mass total the truck has to rotate. Might not sound like much, but it is. Plus gearing and all that. Just saying, people cut weight on their vehicles for a reason.
    GT7[QUOTED] likes this.
  8. May 6, 2019 at 11:27 AM
    ThomasMore66
    Yes! Wanna race?
  9. May 6, 2019 at 11:29 AM
    VolcomTacoma
    Jeff
    NorCal
    On that note, I'm convinced the Speed Limiter on our trucks is regulated by the Speedometer. On stock size tires, WHILE I WAS ON A CLOSED COURSE, It would govern out at 110 every time. When I bumped up in tire size and got an Ultragauge, I've seen 120ish on my UG and had it govern out right when it hit 110 on the speedo. ON A CLOSED COURSE.
  10. May 6, 2019 at 11:33 AM
    mightytacoman
    Kel
    4.5L 1grfe
    I would if you weren't a 27 hour drive away buddy
  11. May 6, 2019 at 11:34 AM
    VolcomTacoma
    Jeff
    NorCal
    Sounds like someone doesn't do this...
  12. May 6, 2019 at 11:42 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    After further investigation, the tire size is used in transmission function, not speedometer calibration like we initially thought. The speed limiter functions as you might expect.
    Norton and mightytacoman[QUOTED] like this.
  13. May 6, 2019 at 12:00 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What am I doing?
  14. May 6, 2019 at 1:35 PM
    ThomasMore66
    Running upgraded Raybestos clutch packs. You’re the guy that can tell us how much hp they will hold.
  15. May 6, 2019 at 1:40 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Im going down to 33s my next tire set too. I dont need 315/75/16s for hauling a dirtbike or driving around town. 1 trip a year isnt justifying it anymore. Guarantee itll eat more rocks but thats why its skid plated and i have a winch to drag it over if i have to.
  16. May 6, 2019 at 1:47 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So what I remember seeing is the 4.10/33 combo will get you back to near stock for city driving but wouldn’t be the best choice for off-roading. While the 4.56/33 combo would be over geared for city driving but right on for off-roading.
  17. May 6, 2019 at 6:12 PM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Around 750 at the crank. You'll need to invest in a better cooler as well.
    Torspd likes this.
  18. May 6, 2019 at 11:34 PM
    VolcomTacoma
    Jeff
    NorCal
    Depending on what happens with my axle/diff next week, if its a stupid fix that dude can do for cheap, I already have to replace the rear diff I'm sure, might just have him swap front and rear with 4.10s, putt around town for a bit and pick up some 33s, make a little cash back with the 35s and call it a day. Also tempted to go with 17" rims and 285/75/17 for a slightly larger tire over 285/75/16. Prob not, but who knows. 4.10s with 16s will put me a little lower in the power band, but I've got a manual so I can just shift to where I want the power band. And honestly, with 35s and 4.56 the extra gearing is probably the same as 33s and 4.1 because of the extra force the engine has to use to overcome bigger/heavier tires.
    Like I said above, I'm 100% ok with having a little less power offroad. on trails where Im using 4LO it doesn't really matter anyways, and on the sand I'm pinning it in low gears alot anyways lol.
    Watch, I finally spend all this money, get my driveline all fixed finally, just in time to hit pismo and blow my engine up. LS SWAP
  19. May 7, 2019 at 8:06 AM
    ThomasMore66
    I dunno... Lots of 1gr stuff has been floating around in this thread. Pistons, rods, some valve springs... Stock crank doesn't seem to be the weak link. More boost.
  20. May 7, 2019 at 8:11 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Looking to sell my OVTune handheld. Anyone pass theirs on to someone else yet? I think if I sell it the new owner has have it reset by Mat? Anyone done this?
