TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 9, 2019 at 7:19 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I've been to Mexico a time or two myself; this is from a couple of days ago. Ran out of runway. I'm on the 2.5", but I don't see the boost you do. Maybe the headers, high-flow cats, and exhaust debottleneck things more than I think. I'm lifted and on LT 285's - heavy. It was more like 83, not 38 when I was there.
    https://youtu.be/7TEpoAkAmFQ
    BassAckwards, Torspd, DocME and 2 others like this.
  2. May 9, 2019 at 7:30 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I see, yeah thats not that big of a different. The stock setup reads slightly faster than you are actually going so your speedo is probably closer to what your actual speed is vs stock tire size.
    I drove an xrunner once, man it was fun to drive.
  3. May 9, 2019 at 7:59 AM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    i cant wait to get it tuned right to. im hoping to find a dyno locally and spend some money for some seat time and get it dialed in.
    Torspd, Murphinator and DocME like this.
  4. May 9, 2019 at 8:10 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I agree with all other here. Get a sweet 2015 and switch over. You have all the go fast goodies, I think you'll be disappointed with the every day drive of the 3rd gen. It's hard to go back from being in a supercharged application. The only cure is a good v-8. If you could return yours to stock, there might still be decent value in it even with full disclosure. On a side note, you have the 7th injector and at that elevation, you should be able to swap to a much smaller pulley very easily. Might be something to think about when you make a decision.....
    Torspd likes this.
  5. May 9, 2019 at 9:18 AM
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    Thanks everyone, it's literally a rotten deal on the part of the frame and a tough as hell decision to be making in short order due to it being primarily a work only truck that needs to find a solution pretty quick.
    I have done a lot of cost/benefit analysis on it at this point and that includes having my accountant who is a good friend weigh in on it. A reliable platform comes first over power in this case and in having driven the gen-3 four times, once with my wife who is also a HP junkie, well lets just say that with an OVtune on it we know we can get by with the 2019 and have it get the job done.
    And I actually like the idea of having two trucks, one that is dedicated for work/camper and then one I can rip around in with the S/C, make a run to the hardware store in and ultimately take my time in figuring out how to revive it and make it better. In all likelyhood and unless URD comes up with a super reliable FI platform for the 3.5L, the roles would be reversed down the road once the 4.0 platform is on solid footing again.
    Sometimes life is about timing and right now it is what it is. We still have about a month before we have to get the camper back on something but right now placing a bulls eye square on a exact build 2019 with a known history and OVtune is looking like the best choice from a business standpoint. The 05 is not going anywhere soon and truth be told, we get our real HP/FI fix with the monster in the garage, an Audi RS7 pushing 645hp/656tq.
    Either way, I will be hanging out here regularly because I simply can't leave the S/C'd 4.0 platform, it is just that good!
  6. May 9, 2019 at 9:26 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Pulls just like mine! Love it sounds great. I may have to take a trip down to mexico this evening for some testing
    TRON and Torspd like this.
  7. May 9, 2019 at 10:50 AM
    ThomasMore66
    BassAckwards likes this.
  8. May 9, 2019 at 11:29 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    If I had to guess probably just icy water? But maybe something cooler than that..
  9. May 9, 2019 at 11:49 AM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    yeah he sprays c02 its cry02 intercooler sprayer
  10. May 9, 2019 at 11:52 AM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    Liquid co2 probably.
  11. May 9, 2019 at 12:06 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I want to motor swap with that. 550hp and 570tq should be plenty for the taco. Sad thigh is my taco probably weighs close to if not more than his tundra
  12. May 9, 2019 at 12:51 PM
    ThomasMore66
  13. May 9, 2019 at 12:58 PM
    ThomasMore66
  14. May 9, 2019 at 1:04 PM
    BassAckwards
    Pretty cool, might consider one of these since i no longer daily the truck. Also considering an icebox for the intercooler like @o0opackersfano0o is doing. I think thatd be the cheapest option for intake charge cooling over the long term vs buying co2
  15. May 9, 2019 at 1:08 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    It didn't go unnoticed that he's making ~550whp through the stock Tundra airbox/MAF. ;)
  16. May 9, 2019 at 1:13 PM
    ThomasMore66
    Speaking of cooling, any thoughts on the Stiegmeier Venom cooling system? They claim it can be installed on our supercharger.
  17. May 9, 2019 at 1:24 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Order it when You get yours ported. Test it out
  18. May 9, 2019 at 1:30 PM
    ThomasMore66
    Help me spend my money! Lol.
    GT7[QUOTED] likes this.
  19. May 9, 2019 at 1:32 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    look up killer chiller. its expensive but works. same way the demon cools
    DocME likes this.
  20. May 9, 2019 at 1:36 PM
    ThomasMore66
    Ok. You buy that.
    I think it will fit where the air pump used to be...
