TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 9, 2019 at 11:48 PM
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    So is 12.5-13 afr ok at wot? Your not worried it will get too hot?
    BassAckwards likes this.
  2. May 10, 2019 at 6:57 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm good with it.
    On another note, it was only 55 degF this a.m. in a surprise May TX cold snap. Very boosty.
    mulisharydr[QUOTED] likes this.
  3. May 10, 2019 at 7:38 AM
    ThomasMore66
  4. May 10, 2019 at 8:43 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I am amazed at how much oil is collected in mine. I never had it before and it was out of sight and mind.
  5. May 10, 2019 at 9:19 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    If anybody is looking for a snout cutter let me know. It is required to get below a 2.8 OVERSIZED pulley.
    Norton likes this.
  6. May 10, 2019 at 1:13 PM
    Kodachrome
    Kodachrome Well-Known Member
    Western Colorado
    2005 Taco, 2024 Audi SQ8 ETron
    TRD S/C, URD...Stuff
    They work great as long as setup right (non-collapsing hoses). I just recently pulled my IC off to inspect it and between the can and 7th injector, the thing is near spotless.
  7. May 10, 2019 at 3:55 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I run 255/55r18 and get 2600 rpm. Aren’t xrunners 3.73
  8. May 10, 2019 at 3:58 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  9. May 10, 2019 at 5:00 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Are you running the fpr mod? And im assuming this is with the HPtune?
  10. May 10, 2019 at 5:13 PM
    ThomasMore66
    Yes
    BassAckwards[QUOTED] likes this.
  11. May 10, 2019 at 6:29 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Why are you so lean with the fpr mod? Don’t feel like it should be that lean
  12. May 10, 2019 at 7:03 PM
    ThomasMore66
    @JustDSM tune got me here. Runs great. Have new 650cc injectors in a box.
  13. May 10, 2019 at 7:05 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I enjoy mine too!
    Indeed, they are! 170MPH at the CO Mile...
  14. May 10, 2019 at 7:20 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Not mine, I wish. It was nuts
  15. May 10, 2019 at 8:52 PM
    ThomasMore66
    DocME likes this.
  16. May 10, 2019 at 8:59 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Same, I watch that guy every once in awhile. I still like driving/off-roading my truck more then a f150
  17. May 10, 2019 at 11:48 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Okay that was entertaining to watch. Hahaha. 0-60 in 3 seconds for a truck. That is a lot of fun!
    DocME likes this.
  18. May 11, 2019 at 4:50 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The logs show a discrepancy between the factory widebands and the aftermarket wideband of nearly 0.5AFR in closed loop. Factory commanded AFR 14.7, factory widebands report 14.7, aftermarket wideband reports ~15.2. I don’t have much faith in what the aftermarket gauge is reporting in OL as a result of what I see in CL.
    I have advised @ThomasMore66 of that.
    We’ve richened the truck a bit since that video. The truck runs somewhere around 11.5 (actual) now. Also lowered the enrichment point by correcting an anomalous error in the calibration.
    mulisharydr likes this.
  19. May 11, 2019 at 5:27 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    My afe uego 4110 wideband usually shows 14.3 on the dash at idle (factory sensors show 14.7 at the same time.) That is with trying different wideband sensors hooked to ot too. Because of this, the logs I send you show a corrected wide band calculation (input/0.5)+9.7=output. Is this the wrong thing to do?
    JustDSM[QUOTED] likes this.
  20. May 11, 2019 at 5:31 AM
    JustDSM
    Justin
    Ogden, UT
    I’m ok using the offset function to correct the output. Good job on that!!
    mightytacoman[QUOTED] likes this.
