TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. May 18, 2019 at 12:02 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Apparently it was a recent thing when I spoke to a Continental rep just a few weeks ago. It was definitely this year, there is still old stock hanging around in stores and such but once the stock has been liquidated its goodbye Gatorback style belts for good.
    Let me know how the RPM series belts fares out. I have been eyeballing them for a long time now but cannot justify their incredibly high price tag.
    Any notable change with those Ruthenium plugs?
  2. May 18, 2019 at 12:10 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
  3. May 18, 2019 at 7:53 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    On Ag equipment here there are two products you don’t skimp on, bearings and belts. The brands farms use if they want to replace things once and get the most lifespan out of it are Timkin/Koyo bearings and Gates belts. I have confidence I’ll get longer than OEM lifespan out of a Gates belt.
  4. May 18, 2019 at 8:57 AM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    i just put the ratio tek kit in my tranny, and its not good. doesnt down shift (from 5mph it feels like its in 2nd) and i have a bad flare from 4-5 about 1500 rpm. works great when i manually shift all gears. called oregon trans where i bought it and called ratio tek with no response. i followed the instructions to the t. might it be one of the 2 valves that are adjustable not correct? anyone else have these issues?
  5. May 18, 2019 at 8:58 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    No issues on mine. Runs great, no flare and firm shifting. How much fluid did you put back in?
    12TRDTacoma[OP] likes this.
  6. May 18, 2019 at 9:22 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Check for tranny codes that may be pending or current... if none make sure you check fluid level again. I ended up putting in 9.5 quarts on an 11 quart system after it was all said and done after a few checks and fills. :eek:
  7. May 18, 2019 at 9:24 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I was at 8 going back in. Without the engine running and cold fluid after it has been circulated I could only get 6 qts in. I was never able to enter tranny temp mode, but using an IR thermometer on the pan and with the engine running I got two more quarts back in.
  8. May 18, 2019 at 10:15 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Should be good. It’s the best of the best right?
    Just got my headers on. Haven’t even started the car up yet. I don’t suspect I’d notice anything though.
  9. May 18, 2019 at 10:24 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    @loginfailed had issues too. I am not a fan of that shift kit. I went with an Australian solution. Good luck.
  10. May 18, 2019 at 10:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You need to get the tranny to about 100-115*F to be able to accurately check the fluid level. I dont even bother going into tranny temp mode anymore I just get it to proper temp and check then fill if necessary. The fluid level is important to get right otherwise you will get those weird issues you are describing potentially.
    If that does not resolve your issues then you have a botched install and will have to recheck or have the work rechecked again unfortunately.
    I hear it is the best around... of course I have never tried it so I am not in a position to say.
  11. May 18, 2019 at 10:57 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Stay safe boosted brethren in Tornado warning today!
  12. May 18, 2019 at 11:17 AM
    Kelvin
    Kelvin Wheeeeee
    It’s the only belt that was suggested to me so I just went with it. Paired with the larger tensioner pulley I’ve got decent belt tension. Good enough for me.
    On a different note. I’m having issues getting this steering shaft joint back on. All I have to do is put my intake back on, bolt the rest of my exhaust back on, get my shaft back together, and I should be able to test drive it around.
    mr.trd likes this.
  13. May 18, 2019 at 11:31 AM
    ThomasMore66
    An appropriate song at the moment: Texas Flood
  14. May 18, 2019 at 12:31 PM
    Kelvin
    Kelvin Wheeeeee
    Any of you interested in some lightly used vibrant bottle resonators and magnaflow race mufflers? 2.5” in/out and I’ve got 2 each.
  15. May 18, 2019 at 12:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Well if we are doing a for sale now. Lol.
    Anybody interested in an Aero Turbine 2525XL muffler? Probably has 70K on it but works brilliantly still.
    Kelvin likes this.
  16. May 18, 2019 at 12:47 PM
    mr.trd
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    How long are each of them?
  17. May 18, 2019 at 1:11 PM
    Kelvin
    Kelvin Wheeeeee
    Short. The magnaflow is like 4” round x 6”. I’m wanting to switch to borla s type mufflers.
  18. May 18, 2019 at 1:52 PM
    Kelvin
    Kelvin Wheeeeee
    Yea somebody buy this mans muffler and one of mine and I’ll bring it to Roberto for a combined shipment
  19. May 18, 2019 at 6:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :rofl:
    Double prizes!
  20. May 18, 2019 at 6:32 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Since we are at 759 pages this is considered a bs thread right?
    No more one wheel peel for this Tacoma.
    By the way toyota charges a criminal amount for their 75w-85 gear oil. It’s made in Japan atleast. $38 a damn quart. And they put it in cans with no way to pour it into the diff lol. I bought a pump though because I am lazy and I think a screw driver will open the can up easy enough.
    Also on my way home my blower rolled over 25,000 miles. I am itching to turn up the boost.
