TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 3, 2019 at 3:31 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  2. Jun 3, 2019 at 3:47 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Athlaos and loginfailed[QUOTED] like this.
  3. Jun 3, 2019 at 3:53 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Seems like A02A is what I’m looking for.
    It’s crazy how 90% of the eBay sellers are advertising 4.10 ratio and they’ve all got under hood pics of a V6 or VIN stickers that say A04C. Bone heads.
  4. Jun 3, 2019 at 3:58 PM
    BassAckwards
    That is crazy! For someone who doesnt know what theyre buying, that could end in a bad situation. Im not sure what the code youre looking for is, but the way i did it was just asked for the VIN# of the donor vehicle. I then plugged that into toyotaowners.com and downloaded the full factory spec sheet for what the truck comes with (which conveniently includes what type of wheels they come with as well). Then you can be 100% sure (if the truck was stock) that you have the right gears. This of course is just for if youre not able to go and look at it first. If you can do that, you can take the drain plug out, mark the ring gear and then turn the driveshaft flange by hand and count how many turns it takes for the ring gear to make a full turn. This is what i did before installing it to be 1000% sure i wasnt about to destroy my driveline
    mr.trd and Athlaos like this.
  5. Jun 3, 2019 at 5:08 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I need some little Tacoma stickers to put on my front fender for all of the ones that think they’ll outrun me...
  6. Jun 3, 2019 at 5:15 PM
    BassAckwards
    Might as well put it on the tailgate, thats what theyre gonna see.. Then theyll know theyve earned themselves a spot:D
  7. Jun 3, 2019 at 5:49 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I've considered putting the numeral 2 on the bumper. That way the guy behind me knows what place he's going to be in the race.
  8. Jun 3, 2019 at 6:09 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Opinions on the need for bigger injectors. I seem to remember that the TRD SC ones are adequate. I'm going to have the SC and valve cover off for the install of exhaust cam gears... already plan on new spark plugs while I'm in there, is it worth it to throw injectors in the mix as well? Plan on doing a 2.7 pulley in the near future.
    BassAckwards likes this.
  9. Jun 3, 2019 at 6:12 PM
    Athlaos
    Leigh
    Edmonton
    Trd ones have a lot of room. With 1.87" pulley I'm at 85% duty on them and 60% duty on the 7th injector. I also have methanol injection though.
  10. Jun 3, 2019 at 6:13 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    From what I've observed, the stock TRD injectors will work well with a 2.7". Getting towards the 2.5 is when they're starting to really get taxed, though I have used them on a truck with a 2.3" (@12TRDTacoma) and while the IDC's are quite high, they are working *hard*. :)
    Norton, TheFang[QUOTED] and DocME like this.
  11. Jun 3, 2019 at 6:14 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Depends on what your end goal is. With the 2.7 pulley the TRD injectors will serve you well. Really only *need* them if you go 2.5 with all the available mods and still want some headspace on the duty cycle. Or if you go turbo at some point. The nicer injectors that everyone has may also idle and control fuel a bit better, but it’s hard to think you’ll notice
  12. Jun 3, 2019 at 6:14 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Good to know. Thanks dude.
    Meth has always been in the plan. I'm working on supporting mods before the 2.7
    Plan is exhaust cam retard gears, fuel pump, and meth before my pulley goes on a diet and loses some around the waist.
  13. Jun 3, 2019 at 6:16 PM
    Athlaos
    Leigh
    Edmonton
    Those are all awesome mods.
  14. Jun 3, 2019 at 6:19 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Gotta do it safe. I want this truck to last a long time.
  15. Jun 3, 2019 at 6:20 PM
    Athlaos
    Leigh
    Edmonton
    Yep, and you're doing it the right way.
  16. Jun 3, 2019 at 6:25 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah I'd want mine 70" WMS and no leaf or shock mounts on it so I can custom mount mine.
    Hawk373 and mr.trd like this.
  17. Jun 3, 2019 at 6:25 PM
    VolcomTacoma
    Jeff
    NorCal
    I'm pretty done with Toyota diffs
    GT7 likes this.
  18. Jun 3, 2019 at 6:29 PM
    VolcomTacoma
    Jeff
    NorCal
    Wondering if ECGS would take 2 8.4" diffs with ARB lockers in the for cores and knock off a grand or two off a Dana 60 lol
  19. Jun 3, 2019 at 6:56 PM
    ThomasMore66
    I have some URD 650's new in the package with pigtails if your interested. PM me.
    JustDSM likes this.
  20. Jun 3, 2019 at 8:05 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    To be fair here I run the TRD injectors because of smog. The less I have to revert back to OE by the time I'm up for the bi- annual visual inspections the more peace of mind I have. I'm all for race trucking, but I also have to be realistic with my mods. It's very difficult to be a car enthusiast here in Commifornia.
    That being said the current duty cycle on my injectors with my mods nets me no more DC than an OE NA Tacoma at WOT. The truck runs great and I couldn't be more thrilled with the way it runs thanks to the tuning wizard @JustDSM himself.
    This truck will last me no more or less time than one which is lighter modded. I have all the confidence in saying that. This is the longest I have ever owned a vehicle and I have every intention of making sure it lasts me a very very long time moving forward.
    Norton likes this.
