TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 6, 2019 at 12:55 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Dana 60, Ordered. Front Diff rebuild, ordered.
    Torspd, mr.trd, BassAckwards and 2 others like this.
  2. Jun 6, 2019 at 12:57 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Right on. Im looking to hopefully order monday. What locker did u get @VolcomTacoma
    BassAckwards likes this.
  3. Jun 6, 2019 at 1:00 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hey, wait for me! FOMO!
    GT7[QUOTED] likes this.
  4. Jun 6, 2019 at 1:01 PM
    ThomasMore66
    Is this the limit to higher rpm in the 1gr-fe, or is it that and the rods/pistons?
  5. Jun 6, 2019 at 1:20 PM
    VolcomTacoma
    Jeff
    NorCal
    I went with the Eaton electric locker since my ARB has been a little wonky lately plus I need to relocate it. So I wont have to worry about air lines n shit
  6. Jun 6, 2019 at 1:26 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah but let's be real here we are rocking a supercharger that is built off a Ford Lightning and Cobra. :rofl:We are already Fordy as it is.
    The computer pulls timing as necessary to compensate for all the heat soak.
  7. Jun 6, 2019 at 1:36 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I put supertech dual springs in my car. Nothing wrong with them mechanically, although they're overkill because I didn't increase the redline much, and now they're wearing out the variable mechanism in the stock intake camshaft gears and I need a $1000 to get upgraded ones...
  8. Jun 6, 2019 at 1:50 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    ^This right here is a good point.
  9. Jun 6, 2019 at 2:00 PM
    ThomasMore66
    I have Harrops in both of my 80's which have the Eaton mechanism. They're wonderful.
    DocME likes this.
  10. Jun 6, 2019 at 3:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Both, plus springs.
  11. Jun 6, 2019 at 4:38 PM
    ThomasMore66
    At what point do we need the forged crank? I see a build happening...
  12. Jun 6, 2019 at 5:17 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Apparently the foam gasket next to our Intercooler is sold by the lineal inch. Odd. Anybody have a # for how much we need?
    75 cents an inch but I'd like to get enough to have a spare.
  13. Jun 6, 2019 at 5:19 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I've seen 178° idling. It still runs.
  14. Jun 6, 2019 at 5:30 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Does it make sense to insulate our intake?
    loginfailed[QUOTED] likes this.
  15. Jun 6, 2019 at 5:47 PM
    Lucifer29
    Lucifer29 Well-Known Member
    Red
    Anyone got the link for @Roostfactor pulley wrap mod. I got the pulley shaved down just need to see the mounting set up
  16. Jun 6, 2019 at 5:57 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don't think it matters because heat will eventually soak through anything you wrap around it. Might delay how quickly, but I doubt it will make a measurable difference. My 178° was during a long period of idling while stationary. It would have gone way down had I been moving.
    Roostfactor likes this.
  17. Jun 6, 2019 at 6:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I can see that. With a slight air gap and reflective insulation things might change. But you'd have a seriously ugly intake tube.
  18. Jun 6, 2019 at 6:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Forged crank. We already need on. GB!
    TodayWasTHeDaY and GT7 like this.
  19. Jun 6, 2019 at 6:47 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Get 6 of the smallest meth nozzles and install them across the tube and have them spray. Bam, cool intake tube!
  20. Jun 6, 2019 at 6:54 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I was pondering a double spray!
