TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 9, 2019 at 4:43 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    He came out with one?
    Not that I am surprised in any way shape or form. "Some fancy double walling in the high speed merge collector" is my most recent memory :D
  2. Jun 9, 2019 at 4:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    loginfailed likes this.
  3. Jun 9, 2019 at 4:49 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It was on FB recently. Possibly on XRU as well, but I haven't been there.
  4. Jun 9, 2019 at 4:52 PM
    Roostfactor
    TX panhandle
    I kind of see what you are up against. You have your crossmember gusseted which also raised it so room is less.
    I cant reference the amount of room between pan and skid but yeah, no way to fit even an oval (expensive) tube in there and still have enough clearance for engine/frame flex.
    You and your buddies have skills! If I were you I'd buy some materials and make what you want to fit your needs. I doubt you would be happy with any of the current offerings for your specific "one off" application.
    If you want, you can PM me to discuss your options.
  5. Jun 9, 2019 at 4:58 PM
    Roostfactor
    TX panhandle
    He is too late for that party! He will only get the scraps now. He had the opportunity long long ago and his question was......who is going to change their pulley after they go smaller?
    Well I have personally tried 4 pulley sizes and of course I am FAR from alone in that aspect.
    I wonder when he is going to offer HPtuners and SAI block off plates for sale? :rofl:
  6. Jun 9, 2019 at 4:59 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’m tired of working on it. I’m ready to just bolt something on... lol.
    I may shoot you a PM at some point for advice if you don’t mind.
  7. Jun 9, 2019 at 5:20 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    and he made it red instead of keeping it bare aluminium o_O
  8. Jun 9, 2019 at 5:30 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    It only goes to a 2.7 pulley too... lol
    Athlaos and 12TRDTacoma[OP] like this.
  9. Jun 9, 2019 at 6:22 PM
    Roostfactor
    TX panhandle
    Absolutely! That's what I was getting at. Please get with me before you throw something in there!
  10. Jun 9, 2019 at 6:47 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Oh its totally awesome!!
  11. Jun 9, 2019 at 8:22 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    From my understanding the top tested oils are usually Penz Platinum and Amsoil. That being said if you stick to an aggressive OCI you should never have any issues even with cheap synthetic.
  12. Jun 9, 2019 at 8:41 PM
    eon_blue
    Azusa, CA
    Pennzoil uses a lot of detergents, it's a good oil to use if you need to clean out the engine. I always run Pennzoil full synth 5/30 with the little green emblem on it "for modern turbocharged engines", supposedly good for boosted engines that run more rich than N/A ones do.
    Roostfactor likes this.
  13. Jun 9, 2019 at 8:48 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    He is SO late to the party. No doubt he designed it because of his near immediate drop in pulley sales from this thread and the dedicated qwikchange thread I made long ago. All those stealth and Supergrip pulleys were getting dremeled, destroyed, and bent for removal and it probably hurt his little heart (and wallet as well) to see it. Lol.
    I have changed pulley sizes at least 3 times total since my initial 3.0 pulley. It's fun to tinker and that's what the spirit of this whole thread has always been about and the encouragement in doing so!
    The herd moved on to bigger, more fruitful ventures after proper sources had been discovered and now while he will be an option, he will be getting the table scraps of remaining sales left over.
  14. Jun 9, 2019 at 8:52 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think if he started selling cam gears he could make good $$ on it. And also design a 7th injector kit that does not require the ucon.
  15. Jun 9, 2019 at 9:01 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I know the penz stuff is almost as good as amsoil, and it's price is definitely better for the $$ it kills everything else over the counter currently unless your local wolly world stocks amsoil. That said I was reading about the amsoil transmission fluid and I might have to try that stuff out in my A750, see if it performs any better than the toyota WS.
    mr.trd likes this.
  16. Jun 9, 2019 at 9:08 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    If he waits too long to offer his cam gears, he'll be getting the table scraps for those sales too after this group finds an alternative
  17. Jun 9, 2019 at 9:39 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I run Amsoil in the transmission and my diffs. Always have. In the engine it's either Penz or Amsoil, price dependent.
  18. Jun 9, 2019 at 9:51 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Did you notice any difference with the trans fluid? I know it’s expensive but I don’t mind spending the $$ on stuff I know is good. From the research I’ve done I know it should perform as good as toyota ws, and most likely better.
  19. Jun 9, 2019 at 10:21 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Hmm I can't tell the difference honestly. I changed pretty early on though. I've heard nothing but bad things about most modern fluids. They really aren't as advertised. Companies want you to believe they invented these miracle ingredients to make transmission fluid last forever. Reality is they just put in a higher detergent package and they count on most trucks failing well out of warranty.
  20. Jun 9, 2019 at 10:33 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A lot of truth in this stuff here... if he sold a 7th injector independent to the UCON he would definitely be in for a good hit with us, as 7 injector fueling would always be a nice addition for those not wanting to upgrade injectors but want the additional fueling for smaller pullies or even E85... cam gears are touch and go, as a lot of us who wanted them already have them or are in the process of getting them.
    There is still a supercharger market to be had here. If he really wanted to give us options and choices he could make a custom billet tensioner unit with a double bearing idler design which is bolt up right off the gate. I know a lot of you guys still want something as far as a tensioner goes as nice as Roush is, it's still an aluminum unit. Carry a supply of Gate RPM series belts for those of us wanting more belt integrity. Hell he could even offer a replacement billet secondary crank pulley exclusively for the supercharger drive itself... which I would gladly pick up in a heartbeat to lessen the rotational mass... something..
