TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 13, 2019 at 3:59 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Yeah the general consensus is that my axle housing is tweaked a hair and thats causing bad gear engagement. There's no reason 4 rebuilt diffs in a row go bad so quick. The last one built by a shop that TW members go to and as soon as I drove off with a brand new rebuilt diff the gears were clashing like crazy. 'Bout 300 mile on the diff and its almost not driveable.
    Dana 60, 70" wms, set up with 4.10 gears and an Eaton electric locker, Spring under axle perches and shock mounts. Should be able to just bolt it right in and swap over the drum brakes.
    Also regearing a spare front diff with 4.10 gears. Finally getting smart and sending it all to ECGS.
    Prob gonna end up selling the 35s and going with 33s or 295/75/16 again. 35s are just to much work to clearance and killer on components. Would rather go back to 33s and keep a bunch of power
  2. Jun 13, 2019 at 4:14 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Everything. Absolutely everything is better here.
    So did you get those LCA bushings on yet?
  3. Jun 13, 2019 at 6:43 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    This is seriously off topic, but y’all are the only people I talk to. In lieu of a hi-lift for my 80, I have this new off-road Pro Eagle floor jack. It’s made to get dirty. Heading to CO tomorrow. Yes dear, the jack is coming.
    mr.trd, BassAckwards, Norton and 4 others like this.
  4. Jun 13, 2019 at 6:44 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Seriously want one
    Lord Helmet likes this.
  5. Jun 13, 2019 at 6:45 PM
    ThomasMore66
    The little cylinder on the back is an up to 8” extension. Seems way safer than the hi-lift to me.
  6. Jun 13, 2019 at 6:46 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    I sold mine. Really didnt like the unpredictability. I know if you use it right its fine, but still.
  7. Jun 13, 2019 at 7:10 PM
    ThomasMore66
    And when you have an 80, you can do this:
    Tailgate does get heavy AF.
    BassAckwards, Norton, henryp and 3 others like this.
  8. Jun 13, 2019 at 7:35 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Reminds me of my 78 blazer. 300lb tailgate.
  9. Jun 13, 2019 at 9:53 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Meth:
    1. Hydro lock, not possible.
    2. 'octane boost' from cooling intake AND evaporation of water droplets when the compression stroke happens
    3. The supercharger's heat input is the same regardless of water/meth. So overall your intake charge temp goes down, water/meth isn't negated by it, per se.
  10. Jun 14, 2019 at 5:36 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Details? That one has ports for sensors? How or where does it install in and lock in place if it replaces a sandwich plate? It looks like a different location. I likey
    Norton, Scott B. and BassAckwards like this.
  11. Jun 14, 2019 at 5:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    See that nipple in the picture? That is the nipple you attach a hose to, for spillage collection, when removing the oil filter.
    TodayWasTHeDaY likes this.
  12. Jun 14, 2019 at 5:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    1/2" NPT to 1/8" NPT .
  13. Jun 14, 2019 at 5:48 AM
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    It won’t be completely bolt in. You’ll need to get the drive shaft shortened because of the 60 being longer at the gear housing. Also, you’ll need new, longer, hard brake lines that go along the axle because you’re going wider than stock.
    BassAckwards likes this.
  14. Jun 14, 2019 at 7:11 AM
    TodayWasTHeDaY
    Russ
    Calgary
    Thanks for the details. Didn't realize it was a bushing reducer. I think I'll be doing that in the future!
  15. Jun 14, 2019 at 7:36 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Where exactly is this on the engine? I wouldn't mind an oil temp on my Tacoma but don't like sandwiches. I suppose I could drill and tap the oil pan....
  16. Jun 14, 2019 at 7:39 AM
    TodayWasTHeDaY
    Russ
    Calgary
    I just asked that and Torspd answered in posts 15951 and 15952
    Torspd likes this.
  17. Jun 14, 2019 at 7:42 AM
    Voodoo Rufus
    Bakersfield, CA
    Still working on my coffee....thanks.
  18. Jun 14, 2019 at 7:58 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Jun 14, 2019 at 8:07 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Ordered the 2.8" URD pulley today. That's as small as I would go anywho.
  20. Jun 14, 2019 at 8:12 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    For now. Smaller pulleys will come in time.....they always do.
