TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 20, 2019 at 7:25 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is this your SPEC clutch thats slipping? If so, how many miles you have on it? Sorry to hear youve been having such bad luck man
  2. Jun 20, 2019 at 7:28 AM
    BassAckwards
  3. Jun 20, 2019 at 9:04 AM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    This sounds a lot like someone saying "2.85 pulley should be my final mod" ...
    Thanks for all the updates, you're the man @12TRDTacoma !
  4. Jun 20, 2019 at 9:45 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @Sterdog couldn't start a conversation with you for some reason. Did you block me??!! Haha.
    In any case I'll be in Calgary on July 20th in the evening, probably after supper or so.
    @Speedwaytacotuesday @TodayWasTHeDaY
    12TRDTacoma[OP] and BassAckwards like this.
  5. Jun 20, 2019 at 10:16 AM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I too "overland". LOL And yes the s/c is very much worth it. But if you tow, gearing will make as big of a difference, for me, a bigger difference since I am what they call "overloaded" and tow beyond the rating. LOL
  6. Jun 20, 2019 at 11:01 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Nah, sorry man you’re not blocked. I have PMs blocked off from an issue with a member a while ago who likes to create multiple accounts lol. Apparently permanently banning people on TW doesn’t actually happen.
    Sadly I won’t be around tonight. In Calgary right now but I have to head south for work.
  7. Jun 20, 2019 at 11:01 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    July? ^
    Athlaos likes this.
  8. Jun 20, 2019 at 11:23 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yes. we regularly go camping and wheeling (I refuse to use the "O" word), heavily loaded, long distance trips. like others have said.. a re-gear will yield great results and imo is the best bang for the buck. I'm re-geared with the blower.. snorkel, etc.. and weigh in around 6k+ loaded up. long trips through the mountains are no problem.. and I've done some of these trips pulling an expo trailer too. I cruise around with my RTT and shit on all the time as the Taco is my toy basically.. and it still turns heads and surprises people leaving the line. definitely fun whoopin some dude with a loaded down brick of a truck. lol
    BassAckwards and mr.trd like this.
  9. Jun 20, 2019 at 11:44 AM
    Athlaos
    Leigh
    Edmonton
    Gotchya, it's impressive sometimes how people can get so passionate about attempting to bother someone else. If they put that passion toward something productive, they might actually get something done.
    Actually I'll be there July 20th. So you have a month to prepare.
  10. Jun 20, 2019 at 12:42 PM
    Athlaos
    Leigh
    Edmonton
    I decided to put close to pure water in my intercooler for the summer. Kept a little bit of glycol in it for corrosion protection, and slight freeze protection (sometimes, in Canadiastan it goes below freezing in July). I also put some redline water wetter in it, which touts itself as having additional corrosion protection.
    I calculated some years ago that when you compare the specific heat capacity and thermal conductivity of pure water against a water/glycol mix, pure water is 6 times as effective at transferring heat. Now, this change would possibly result in only 10 degrees decrease in manifold air temperature, if I'm lucky. But, given the amount of work and money required to do it, I figured it was a worthwhile thing.
  11. Jun 20, 2019 at 1:34 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I usually run more distilled water because.
    1. I’m in California
    2. I’m cheap
  12. Jun 20, 2019 at 2:12 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Typical Bay Area cheapass.
    :boink:
    :rofl:
    I feel though. Hahaha!
    Kelvin[QUOTED] and Athlaos like this.
  13. Jun 20, 2019 at 2:35 PM
    Kelvin
    Kelvin Wheeeeee
    And I’m Asian. Get on my level of cheap :anonymous:
  14. Jun 20, 2019 at 3:30 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Stock Tacoma’s here come with a 60/40 antifreeze/water mix :eek:. I know just going to 50/50 helped me lower my temps a bit. T
    DiamondW likes this.
  15. Jun 20, 2019 at 3:41 PM
    Athlaos
    Leigh
    Edmonton
    Ya. That too. I will be diluting my coolant as well, although not nearly as much as the intercooler fluid dilution I just did.
  16. Jun 20, 2019 at 3:42 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I just bought Aisin Toyota Pink 50/50 from Crappy Tire when I changed my coolant and installed my new radiator. That saved me a trip to the dealer too.
    Athlaos likes this.
  17. Jun 20, 2019 at 6:06 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Lets do a stoptech group buy from sos. Fronts and rears. Someone make it happen :luvya:
    Who’s in?
    5thGearPinned, loginfailed and henryp like this.
  18. Jun 20, 2019 at 6:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have 16's... Not I. :(
  19. Jun 20, 2019 at 6:48 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im getting the 16” version....
    Norton likes this.
  20. Jun 20, 2019 at 6:51 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I’m getting 17” wheels cuz the “16” wheels calipers” very slightly rub on my stock TRD OR wheels. Super annoyed. Great breaking power though.
