TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 21, 2019 at 8:07 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Time to bust out the Dremel if we need to change the output hole. These blowers are a one piece design and not a two like the previous gen 1 design of the TRD supercharger, so changing the bottom portion is out of the question. We could only modify.
  2. Jun 21, 2019 at 8:10 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yes, it is the better design. Only reason I was liking the roots design is because with a twin screw it will be a lot quieter. Not necessarily a bad thing, but I do like hearing the blower scream right now with the roots design.
    What a doucher. He really is his worst enemy. I wonder if you could source the exact whipple he is using, then just try and make your current blower parts fit it. Probably not, because I’m not sure of the idler setup but it would be interesting.
  3. Jun 21, 2019 at 8:12 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's what happens when you are a toolshed. Your stuff gets tampered with or gets sold off in favor of moving on to bigger and better ventures.
    I would imagine it doesn't, it is nice don't get me wrong, but the fact he is not willing to Innovate or to be flexible and wheel and deal with us makes him get left behind real quick.
    I will not buy any URD products unless it is 100% absolutely necessary, ever.
  4. Jun 21, 2019 at 8:12 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yes, and if we could make a template that would be fine. The only problem would be if we had to add material I think it would be one of those things where we would want to go through a shop where they fix the output and install the rotors.
  5. Jun 21, 2019 at 8:13 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I agree, I love the loud whine. Ill call Whipple one day and ask. Id rather have the intake hole facing the front rather then the back. With the idlers and crank pulley Ill get all new so I can sell my blower as a complete kit. probably get an ATI super dampener crank pulley
  6. Jun 21, 2019 at 8:14 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I don't even think that's the price. You have to pm the OP for the price.
  7. Jun 21, 2019 at 8:15 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What we would really need is to obtain a proper computerized measurement of the inside dimensions of the SC housing for the rotors so we know how much space we are working with. From there we would need to source a machinist who is worth a damn and is willing to design a set of twins screw rotors from billet aluminum which would fit the housing. If we got enough people on board with wanting to change the rotor pack I would imagine we would be able to get a substantial savings in $$$.
  8. Jun 21, 2019 at 8:16 AM
    DocME
    California
    '07 FJ Cruiser
    No. Sorry! Only engine crank. But you may still want one of those to go with your S/C pulley as they do have a mating relationship that the machinist would want to know about.
  9. Jun 21, 2019 at 8:17 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I used to own a ATI super damper pulley. On my LS engine. Woo those things are awesome!
    GT7[QUOTED] likes this.
  10. Jun 21, 2019 at 8:18 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yeah I looked it up a while back so that would work good with the 6 rib whipple pulley. at least I think its 6 rib
  11. Jun 21, 2019 at 8:19 AM
    DocME
    California
    '07 FJ Cruiser
    I'm relatively close in proximity to them. If you need something on this end, let me know.
  12. Jun 21, 2019 at 8:19 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I believe I have my old accessory engine crank pulley sitting in my garage actually, so at this juncture all I would need is the secondary SC drive pulley. If someone has a spare lying around or has their engine all torn apart with no idea when completion would be, I do know a few machine shops around here which would be willing to grind out some new pulleys for real cheap if we GB! ;)
    If someone has a SC drive pulley it would be great if they could send it your way, or even my way and we could get some new pulleys created! It's good to know you are close to them.
    TodayWasTHeDaY and GT7 like this.
  13. Jun 21, 2019 at 8:29 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Ahhh gotcha.....then it’ll be more than what I paid. But not by much I’m sure
  14. Jun 21, 2019 at 8:38 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    @Athlaos had tried an grippy SC pulley and it munched his belt really fast. Now, that could be because it’s so small.
  15. Jun 21, 2019 at 8:45 AM
    DocME
    California
    '07 FJ Cruiser
    No I mean, its considerably less. They just didn't want to advertise it.
    Norton and JuanitoBonito[QUOTED] like this.
  16. Jun 21, 2019 at 9:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mine were custom grinds from Kelford. Intake and exhaust. They may have just exhaust cams available? That requires a LOT less work.
    You'd have to contact them for "custom" grinds, as that is all they will do for us. As a middle eastern supplier has rights.
    Even if multiple people from this forum all used the same s/c specific "custom" grind, they would all still have to be requested as such.
  17. Jun 21, 2019 at 9:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Should some of my friends and I get the money together to get a CNC machine, we'd be able to make those.....Hmmm
  18. Jun 21, 2019 at 9:31 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hmmmm What does it cost?
  19. Jun 21, 2019 at 9:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not cheap. Lol
  20. Jun 21, 2019 at 10:03 AM
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Yes,:spending:
