TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 22, 2019 at 11:23 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Hell man I live in a cold-ass city and I run 0w40. And I'm looking at going to 20w60 in my car.
  2. Jun 22, 2019 at 11:23 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Same. I usually have about 1/2 - 3/4 of an inch in the bottom.
    BassAckwards and GT7[QUOTED] like this.
  3. Jun 22, 2019 at 11:31 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I shall run it a bit longer then. I’m glad I didn’t install the big mishimoto can I have. Thing is huge and would probably take 8 oil changes to fill it.
  4. Jun 22, 2019 at 11:39 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Same here.
  5. Jun 22, 2019 at 11:51 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I'm in Igloo country and I still run 5w-30 :p. I doubt the 1GR cares much what oil is in there as long as it's well cooled.
  6. Jun 22, 2019 at 2:27 PM
    skyking3
    skyking3 Well-Known Member
    Tom
    2025 Tacoma TRD Sport Hybrid
    TTD billet oil cap, Weathertech tonneau cover ---All following mods were for my 3rd gen --TRD cai, TRD cat back, JFR y pipe,Wilwood BBK,LEDs, Limited Homelink mirror,debadged,WeatherTechs,Dynamat Extreme sound deadening,sabm second snorkle to fender, Huper Optik ceramic tint, TRD Sema wheels, aerodynamic under body pan, OEM Audio Plus 500Q reference system, Depo faux pro headlights, real pro fog lights, OV tune, OEM aluminum filter housing, Mobtown IFS skid,TRD oil cap,TRD radiator cap, Osram Night Breaker 150 halogen headlamps, Fumoto valve,dashboard blackout,OEM tailgate power lock, MESO steering wheel logo, MESO two color dome light, TRD Pro coilovers, Artec LCA skids, Volk TE37 XT forged wheels, Roadmaster Active Suspension Garmin Minicam, Garmin minicam II
    Actually, I have been on 93 octane since I got the OV Tune last year. Unless there is an option for boost soon, my next mod will be porting and polishing my heads. I have seen a couple of videos that don't seem too hard but the third gen has all of the exhaust runners inside the heads and only a single port out to the down pipe. No headers are possible. This makes it very difficult so I contacted Stiegemeier and he wants $1400 for the job. While I have the heads off I plan on replacing all of the valves with titanium valves from the Lexus LC500. I bought 1 intake and 1 exhaust valve to make sure they are compatible and they are. This is great since I can get all 24 valves for just over $400 which is 10 times less than custom made valves. The intake valve is only 29 grams for the titanium valve while the steel valves are almost 50 grams each. By reducing the reciprocating mass by 40% it allows you to increase the red line to 7500 RPM without worry of valve bounce or valve flutter. The red line on the LC500 is 7300 RPM but it has higher compression so 7500 on the Tacoma should be safe. OV tune has already increased the red line to 6800 for the performance tune but I will be getting a custom tune for my set up. The following picture shows the titanium valves with the Lexus part numbers. I do not know if they are compatible with the 4.0 engines.
  7. Jun 22, 2019 at 2:57 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
  8. Jun 22, 2019 at 4:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Well said. Thanks for the support of us boost heads. I'm betting a turbo option will be what's in store for 3rd gen guys.
  9. Jun 22, 2019 at 7:54 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Swapped out my 2.6 pulley tonight for a 2.5 and did some data logging with the new exhaust. Max air flow was 337g/s with 81*F ambient temps and i saw 9.9lbs on my boost gauge. Im 2200ft above sea level so that sounds about right. Very happy with how UCon is running the truck right now
  10. Jun 22, 2019 at 7:54 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Sounds awesome man!
    BassAckwards[QUOTED] likes this.
  11. Jun 22, 2019 at 7:55 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Are you running a larger diameter intake?
    Athlaos and BassAckwards[QUOTED] like this.
  12. Jun 22, 2019 at 7:57 PM
    BassAckwards
    No sir, running URD tcai and stock size throttle body
  13. Jun 22, 2019 at 7:59 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Wow. Those numbers are good for that. Time for a 76mm buddy. I'm building a new intake now.
  14. Jun 22, 2019 at 8:13 PM
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Sweet, I need a ride in that rocketship soon to give me the push lol.
  15. Jun 22, 2019 at 8:22 PM
    BassAckwards
    Im pretty happy with them! I was thinking the same thing. Been wanting to get a 76mm tb but URD has been out of stock of the adapter plates for a while now. Starting to explore other avenues to have an adapter made now but im not in too big of a hurry. I also have a 7th injector waiting to be installed, but i really dont want to change anything else right now. Gonna have to keep an eye on my AFRs looks like UCon is still adapting some..
    What kinda intake you building? Tundra air box so you can rescale the MAF?
  16. Jun 22, 2019 at 8:22 PM
    BassAckwards
    Absolutely man! We will get you on board my friend:D
    :devil:
  17. Jun 22, 2019 at 8:25 PM
    DiamondW
    Kent
    Gonzales Co. TX
    Yeah, that’s what I’m afraid of :fistbump:
  18. Jun 22, 2019 at 8:31 PM
    BassAckwards
    Youre already a regular in here.. its only a matter of time :rofl:
    Im really interested to see what kind of numbers you can make n/a though before you go f/i.
  19. Jun 22, 2019 at 8:37 PM
    DiamondW
    Kent
    Gonzales Co. TX
    I’m gonna take it all the way before boost for sure. My target is 275 to the ground... time will tell if I’m over ambitious.
  20. Jun 22, 2019 at 8:39 PM
    BassAckwards
    That would be impressive numbers for n/a! You gonna put it on the dyno once youve taken it as far as you can?
