TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 24, 2019 at 10:43 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    In other words, keep it floored and you won’t blow up from knock??
    BassAckwards likes this.
  2. Jun 24, 2019 at 11:13 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @JustDSM might be able to share some insight on this. He had to dial mine back a touch in timing. As I was too close to the knock zone.
    DiamondW, 12TRDTacoma[OP] and JustDSM like this.
  3. Jun 24, 2019 at 11:30 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I don’t agree with that at all.
    Based off what you’re telling me about your observations, and from what I’ve seen him post, his method for fuel control (at least on 2nd gens) is by adjusting tables that modify or add too the main fuel table.
    I prefer adjusting the main table(s), which will provide you with instantaneous enrichment exactly where you set it.
    It doesn’t take any measurable amount of time for the Ecu to calculate that stuff.
    DiamondW and 12TRDTacoma[OP] like this.
  4. Jun 24, 2019 at 12:04 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It won't knock/ ping if your timing parameters are set to what they need to be based upon pulley size. Lol.
    But if you want to floor it everywhere than by all means don't let me stop you. Boost on brother!
  5. Jun 24, 2019 at 12:08 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    TRD flash stock does not go into open loop until after 70% throttle. With HP Tuners, you can adjust what percent you want it to do it. Mine is set at 55%.
  6. Jun 24, 2019 at 12:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I think that is around what mine is set to now also.
    Of course that is after you turn off Catalyst Overtemperature Protection mode.
  7. Jun 24, 2019 at 12:34 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have my cat over temp turned on and set the enable temp super low so it’s always active and that table is always used for fueling.
    BassAckwards and 12TRDTacoma[OP] like this.
  8. Jun 24, 2019 at 12:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. I had no idea that table was adjustable, but I never looked at that.
  9. Jun 24, 2019 at 12:46 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    My cat over temp protection is off and my power enrichment/open loop is set to come on at 32%. I think gearing must play a role here. At 50+% open loop enable would put me at 8+ boost before it kicked in. Even now I can make 6 pounds before it kicks in.
    12TRDTacoma[OP] likes this.
  10. Jun 24, 2019 at 12:46 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    The short version is if I'm accelerating at 25-50% throttle, it'll sit at stoic and then go rich after a few seconds or certain RPM. So how I drive it is I'll give it light throttle at 0-2psi until it goes rich, then dig into the throttle for more power. That's how it behaves.
    I also have the automatic transmission, if that matters.
  11. Jun 24, 2019 at 1:51 PM
    JustDSM
    Justin
    Ogden, UT
    It doesn't have to be that way. It is possible to tune it so you don't have to drive it a specific way properly fuel it.
  12. Jun 24, 2019 at 2:12 PM
    JustDSM
    Justin
    Ogden, UT
    I'm going to make some inquiries with Chris and see if there isn't some way to get PE enabled based on load in addition to throttle angle. I think this would be the saving grace for the S/C crowd. You could keep your throttle based enrichment point at a reasonable setting but get additional fueling when boost comes on at low throttle angles..
    Now that Rev-Hang is out of the way I've got to give him something else to work on.. :D
  13. Jun 24, 2019 at 2:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah that would amazing. I have only seen a low of 14.3 AT most when throttling it before PE engagement and if there can be some additional fueling to at least put you in the lower 13s that would be amazing.
  14. Jun 24, 2019 at 2:29 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  15. Jun 24, 2019 at 2:53 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Has there been any discussion about load calculation tables? It would be nice to see how the ECU is calculating load percentages.
    Seems like for different pulley sizes the calculations need to be different since, say on a smaller pulley there is more boost, earlier. Not sure if that makes sense (it does in my head!)
  16. Jun 24, 2019 at 3:03 PM
    JustDSM
    Justin
    Ogden, UT
    If you want to read up on Load Calculation:
    SAE International SAE J1979 / ISO 15031-5
    Absolute Load = [air mass (g / intake stroke)] / [1.184 (g / intake stroke) *
    cylinder displacement in liters]
    Derivation:
    - air mass (g / intake stroke) = [total engine air mass (g/sec)] /
    [rpm (revs/min)* (1 min / 60 sec) * (1/2 # of cylinders (strokes / rev)]
    - Absolute Load = [air mass (g)/intake stroke] / [maximum air mass (g)/intake
    stroke at WOT@STP at 100% volumetric efficiency] * 100%.
    Where:
    - STP = Standard Temperature and Pressure = 25 °C, 29.92 in Hg (101.3 kPa BARO
    - WOT = wide open throttle
    The quantity (maximum air mass (g)/intake stroke at WOT@STP at 100% volumetric efficiency) is a constant for a given cylinder swept volume. The constant is 1.184 (g/liter 3) * cylinder displacement (liter 3/intake stroke) based on air density at STP.
    Characteristics of Absolute Load are (Generic):
    - Ranges from 0 to approximately 0.95 for naturally aspirated engines, 0 – 4 for boosted engines
    - Linearly correlated with engine indicated and brake torque,
    - Often used to schedule spark and EGR rates,
    - Peak value of LOAD_ABS correlates with volumetric efficiency at WOT.
    - Indicates the pumping efficiency of the engine for diagnostic purposes.
    Another thing to keep in mind, Boost is more or less meaningless in terms of our ECU and it's calculation. It's all done based off airflow. If we were using a speed density setup like an aftermarket ECU (Haltech) we'd be controlling fueling based off manifold pressure (boost), but our Mass Airflow based system, does not look at, use, or consider anything related to boost.
    It really doesn't care if you're at 10psi or 1. It's fueling based off the measured mass of airflow entering the engine. And remember, just because the pressure is higher, doesn't always mean more air is flowing into the engine.
  17. Jun 24, 2019 at 3:49 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Makes perfect sense now. :D
  18. Jun 24, 2019 at 3:49 PM
    JustDSM
    Justin
    Ogden, UT
    In otherwords, it's just not defined by a table :)
  19. Jun 24, 2019 at 3:51 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just needed an excuse to post cat gifs. Thanks for the explanation!
    BassAckwards and JustDSM[QUOTED] like this.
  20. Jun 24, 2019 at 3:52 PM
    JustDSM
    Justin
    Ogden, UT
    I just sent Chris an email about the load based PE enable. I have a feeling there's not.. But I wouldn't be doing my part if I didn't try!
