TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 26, 2019 at 3:42 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    My recommendation would be to buy a spare ecu and ask @o0opackersfano0o if he would be willing to flash it for you. He came in clutch for me when i was having problems and he flashed mine with the TRD tune. I would send him a PM, nice guy that can probably help you out.
    JustDSM likes this.
  2. Jun 26, 2019 at 4:02 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    :wave:
    Norton, JustDSM, 420taco and 2 others like this.
  3. Jun 26, 2019 at 4:03 PM
    BassAckwards
    :hattip:
    12TRDTacoma[OP] likes this.
  4. Jun 26, 2019 at 4:12 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Welcome to the UCON haters club! :D
    BassAckwards likes this.
  5. Jun 26, 2019 at 4:20 PM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    How did you get on such a small pulley with out cutting the shit out of the snout? I’m about to cut mine to allow for a 2.5 or 2.6” pulley and just looking at the snout it doesn’t look like there is enough meat on it.
    Norton and BassAckwards like this.
  6. Jun 26, 2019 at 4:21 PM
    BassAckwards
    Lol this gentleman took a grinder to his snout i believe.. a bit of trimming was definitely done:D
  7. Jun 26, 2019 at 4:42 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Angle grinder. It took like 60 seconds, it was awesome.
  8. Jun 26, 2019 at 4:48 PM
    BassAckwards
    I would have paid to see this:popcorn:
  9. Jun 26, 2019 at 4:55 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Are you able to "bench flash" ECU's?
  10. Jun 26, 2019 at 6:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    O_O
  11. Jun 26, 2019 at 6:20 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
  12. Jun 26, 2019 at 6:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Does this mishimoto give us the clearances needed if we go with a 6 rib system?
  13. Jun 26, 2019 at 6:41 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    No sir. I work for toyota so I just grab a used tacomaoff the lot and plug the ecu I’m reflashing into it and flash it. And it’s done. Unless it plugs into my xrunner then I just use that. But ecus changes certain years.
  14. Jun 26, 2019 at 7:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Inspector Gadget is not gonna be happy when he sees this!
    You bought one from Mishimoto or you already own a 160* thermostat?
    No they do not. It is just a lower temp T-stat with a shorter neck. The longer I think about it, the only way I ever anticipate a 6 rib setup will work is if we get a thermostat housing which is 3D printed out of some incredibly strong, incredibly temperature resistant plastic or a CNC'ed housing... Coupled with the custom building of a 6 rib crank pulley, the additional costs of the 6 rib idler and blower pulley conversion, along with the belt itself and this project may be way too much trouble than it is worth. I don't know that it will be worth it unless we can streamline the mods to like a one stop shop which would offer some sort of package to do all that for us.
  15. Jun 26, 2019 at 7:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I see your point. How about this- I dont really like how close the belt is to the t-stat. I'd like a custom aluminum one even if a 6 rib option is a slow process IF it happens. Could we contact smooth flow?? Nate I believe. If he can make a s/c pulley that works I have faith. Or.... we find another readily available billet unit close enough in specs to have a shop modify it to work. Food for thought.
  16. Jun 26, 2019 at 7:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A 6 rib pulley is already available. That is not the issue. It is the amount of work and redesign which will be involved in such a conversion process which will involving sourcing and custom building items from too many separate sources to make it a clean and relatively inexpensive venture. That is the issue.
  17. Jun 26, 2019 at 7:38 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    :facepalm:
  18. Jun 26, 2019 at 7:39 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I meant if an all new billet pulley needed to be made if not smooth flow then they might have the connection for it.
  19. Jun 26, 2019 at 7:40 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    My supercharger came with a 160 thermostat. What’s the significance to this?
  20. Jun 26, 2019 at 7:40 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It makes like another 20hp.
