TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 29, 2019 at 7:28 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Norton and sbchero[QUOTED] like this.
  2. Jun 29, 2019 at 8:21 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I also read about the horror of pulling, and got the craftsman puller.
    Norton, sbchero and 12TRDTacoma[OP] like this.
  3. Jun 29, 2019 at 9:45 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    If theres still a Sears near you buy a quality puller. Shield with foil if you torch.
    sbchero[QUOTED] and Torspd like this.
  4. Jun 30, 2019 at 6:10 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Pulling from the front lip and not the back lip worked better for me. Slightly more material so bends/brakes less
  5. Jun 30, 2019 at 7:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Another removal tip is a spray can of air. The propellant is usually VERY cold. Spraying only the shaft can cool it helping in removal.
    Athlaos, BillDaCat8 and BassAckwards like this.
  6. Jun 30, 2019 at 8:19 AM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Got a package from cali... :D
  7. Jun 30, 2019 at 8:46 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    You’re going to need to start putting all your extra money in a new account away from anything the significant other knows about. This is your first stop on a path to debauchery.
    Norton, Biscuits, Athlaos and 8 others like this.
  8. Jun 30, 2019 at 8:52 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    The secret truth of everyone on here lol
    Biscuits, Athlaos, henryp and 2 others like this.
  9. Jun 30, 2019 at 9:48 AM
    henryp
    Henry
    Montana
    I just say, honey this truck just keeps breaking down. Gotta get this new ____ to fix ___. Problem solved. I might even get a second car out of it, cuz I spend my time “fixing” this old truck. Lol. I think she’s onto me though.
    mr.trd, Norton, Athlaos and 1 other person like this.
  10. Jun 30, 2019 at 10:54 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    My transmission is hesitating. I think I need the valve body upgrade.
    (Of course I just tell myself this because I’m single)
  11. Jun 30, 2019 at 11:16 AM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    This sounds familiar. What pulley is being removed? The stock one is fighting that bad eh?
    https://www.tacomaworld.com/threads/xpotrpr-build-bs.182905/page-463#post-16791268
    Norton likes this.
  12. Jun 30, 2019 at 11:20 AM
    BillDaCat8
    Jake
    PHX
    I used this method when installing. Hot pulley and cold shaft.
  13. Jun 30, 2019 at 11:21 AM
    BillDaCat8
    Jake
    PHX
    This man speaks truth
    Athlaos likes this.
  14. Jun 30, 2019 at 12:05 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My little chirp at idle only while in drive is back again. Of course it would be only at idle and of course sounds would be the one thing which pisses me off the most.
    Athlaos likes this.
  15. Jun 30, 2019 at 2:16 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  16. Jun 30, 2019 at 2:41 PM
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    bingo. craftsman 5ton ratcheting puller did the trick.
    thanks for the help yall.
    Norton, RyanL, BassAckwards and 5 others like this.
  17. Jun 30, 2019 at 2:42 PM
    VolcomTacoma
    Jeff
    NorCal
    I must have got lucky, wanna say I used just an Autozone 3 jaw and got it first try.
  18. Jun 30, 2019 at 2:52 PM
    TodayWasTHeDaY
    Russ
    Calgary
    My stock pulley destroyed the cheap 2 arm pulley I used so I bought a better puller. Then the 2nd aluminum URD pulley just bent everywhere the puller grips and had to be cut off to remove it.
  19. Jun 30, 2019 at 2:54 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah I've seen Robs fuck ups trying to get the URD pulley on and off lol. They weren't really designed to come back off easily. I'll probably switch to a quickpulley at some point whenever I get an HP tuner.
  20. Jun 30, 2019 at 2:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is a pulley specific removal tool which is sold which utilizes a wrap around through the entire pulley design itself which I have seen before. We are late into the game but I may search for it again so any newcomers know of and have access to it outside of the pullers we usually use.
    Ahh yes. :D Those were fun times. Hahaha. Thank god it is no longer and never will be an issue anymore.
