TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jun 30, 2019 at 5:47 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Is this a chirp in the supercharger? I have a chirp in there that comes and goes, but only at idle.
  2. Jun 30, 2019 at 5:58 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I don't know man. Mine does it and it comes and goes as well. It's really pissing me off.
    Athlaos[QUOTED] likes this.
  3. Jun 30, 2019 at 7:27 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    On/off chirp at idle here also. Don’t know what to make of it. Didn’t change when I replaced air intake.
    Athlaos and 12TRDTacoma[OP] like this.
  4. Jun 30, 2019 at 8:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It seems to be a common thing. I may have to remove the blower belt then go from there. If the sound goes away then the issue is either a bearing in the blower pulley drive setup or the belt itself. Last time I had a chirp it was the belt itself, but it seems to have come back. I'm not sure if the belt itself may require replacement again. So annoying.
    Athlaos likes this.
  5. Jun 30, 2019 at 8:16 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I got all new bearings for the idlers. If that doesn’t solve it, I’m not sure what it is.
  6. Jun 30, 2019 at 8:25 PM
    Athlaos
    Leigh
    Edmonton
    Coincidentally I drove without the blower belt and there was no chirp.
  7. Jun 30, 2019 at 8:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Before you guys go too deep take a spray bottle with water in it and spray the belt while it is rotating around the pulley at idle or when the issue is occuring. If the noise goes away it is the belt.
    Norton likes this.
  8. Jun 30, 2019 at 8:48 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Spray some WD-40 on it. That stuff quiets everything .
    mr.trd, Norton, BassAckwards and 5 others like this.
  9. Jun 30, 2019 at 8:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oil on the pulleys and on a belt will eat away at the rubber on a belt and can cause unwanted slipping on a rotating surface, especially one which requires surface traction in order to engage boost. I would highly advise against using WD-40 on belts and rotating surfaces.
  10. Jun 30, 2019 at 8:54 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I was applying my comedic value:D
    mr.trd, Norton, zerotimeouts and 3 others like this.
  11. Jun 30, 2019 at 9:02 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I got what you were putting down...
  12. Jun 30, 2019 at 9:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh. Hahaha. I missed that. Hard to hear how you said it through text. You know someone or a guest here is bound to read it and take it literal though. There's always that one guy. Hahaha.
    Gotta break it down Barney style in this thread!
  13. Jun 30, 2019 at 9:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I use motor oil. Seconds as a rust preventative and bearing lubricator. Covers everything in a matter of seconds. Like a kid in a highchair with spaghetti sauce.
    mr.trd, Norton, BassAckwards and 4 others like this.
  14. Jun 30, 2019 at 9:22 PM
    TodayWasTHeDaY
    Russ
    Calgary
    If it squeeks after that you gots issues
  15. Jun 30, 2019 at 9:24 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Then you just dont feed it dessert.
  16. Jun 30, 2019 at 9:24 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Probably best to junk it if it keeps squeaking.
  17. Jun 30, 2019 at 9:24 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I second this. Every oil change I just pour a quart of oil over the top of the engine so it can really get into all the cracks and crevices and prevent rust.
    zerotimeouts, henryp, RyanL and 2 others like this.
  18. Jun 30, 2019 at 9:27 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    DX it. Done.
    My man. If they only grasped the genius to save the Tacoma frame. :cheers:
  19. Jun 30, 2019 at 9:28 PM
    VolcomTacoma
    Jeff
    NorCal
    Easy, every time you find rust, just spray paint over it. Bam, no more rust.
  20. Jun 30, 2019 at 9:29 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sometimes the neighbors catch me yelling at it.
