TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 12, 2018 at 2:14 PM
    #1661
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I've read that the coating on the supercharger rotors isn't methanol friendly. Would likely be better off tapping the housing post-rotor to cool the heated charge air. OV Tuned has mentioned this as something worth checking out.
  2. Feb 12, 2018 at 2:18 PM
    #1662
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Methanol will wear the coating off. Which also loosens the tolerances of the rotors to each other. Minutely, but still.
    Biscuits and BenMara like this.
  3. Feb 12, 2018 at 2:29 PM
    #1663
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Easy tiger... Yes you’re right with proper size injectors you don’t... But spraying e85 on the rotors for supercharged applications has huge benefits
  4. Feb 12, 2018 at 2:38 PM
    #1664
    ThomasMore66
    Dallas/Fort Worth & Durango
    I replaced my with a product from Figgs Engineering. Everyone chastised me for the cost of my little aluminum jewel, but it works! Mine leaked around the cap. Cap replaced; leaks returned.
    Biscuits and loginfailed like this.
  5. Feb 12, 2018 at 2:40 PM
    #1665
    ThomasMore66
    Eff ethanol and the corn lobby! That hydrophilic crap shouldn't be in gasoline at all. Waste of good corn, drives up the price of feed/food, and eats rubber. Good ol' high-octane gasoline is the answer. Irony is that you use nat-gas to distill the corn. As you were.
    https://www.pure-gas.org/
    Norton, BenMara, oni06 and 3 others like this.
  6. Feb 12, 2018 at 2:43 PM
    #1666
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    *overpriced aluminum :thumbsup:
  7. Feb 12, 2018 at 2:44 PM
    #1667
    ThomasMore66
    It glitters.
  8. Feb 12, 2018 at 2:49 PM
    #1668
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Pic of this little aluminum jewel? Never mind, I found it. Holy $$$$$ that's pricy!
  9. Feb 12, 2018 at 3:01 PM
    #1669
    ThomasMore66
    You know you want one now. Maybe I should polish it to a high luster.
  10. Feb 12, 2018 at 7:10 PM
    #1670
    Roostfactor
    TX panhandle
    If I wanted one that bad I'd fabricate my own! It sure is purdy though!
    Skootter14 likes this.
  11. Feb 13, 2018 at 2:27 PM
    #1671
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Yeah... Purdy expensive!
    Roostfactor[QUOTED] likes this.
  12. Feb 13, 2018 at 7:09 PM
    #1672
    ThomasMore66
    Hater!
  13. Feb 13, 2018 at 8:03 PM
    #1673
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahahaha. Umadbro?
  14. Feb 13, 2018 at 8:58 PM
    #1674
    GT7
    Grant
    Phoenix
    2013 DCLB
    I am. I like your reservoir but no space for me
  15. Feb 14, 2018 at 7:49 AM
    #1675
    GT7
    Grant
    Phoenix
    2013 DCLB
    It has been about a month since my truck has been all put back together.
    Before this I was getting a P0300 code anywhere from 1-5 times per week. Probably about 400 miles of driving each week.
    Since I put in my new injectors, I have only gotten a p0300 twice in a month.
    I cant figure out why this is occurring.
    Yesterday and the day before, a few times I would give it gas for mild acceleration and it pulled the timing or something, it had no power compared to normal.
    I also had the gaurdian feature activate 3 times in the last week and it hasnt done that since my fuel pump issues.
    Last thing to note, I get the P219A about every day or two. This has happened since the ucon install. I narrowed it down for when the light comes on. I will have been driving on the free way for 40 miles, pull off on an exit, sit at a traffic light idling for 10-30 sec and the light comes on.
    I dont know how to fix these issues, but Im going to take some more datalogs.
  16. Feb 14, 2018 at 8:39 AM
    #1676
    ThomasMore66
    You're not inspiring confidence in the Ucon.
    12TRDTacoma[OP] likes this.
  17. Feb 14, 2018 at 9:01 AM
    #1677
    GT7
    Grant
    Phoenix
    2013 DCLB
    Im a ok with that
  18. Feb 14, 2018 at 9:51 AM
    #1678
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    See........ovtune
  19. Feb 14, 2018 at 9:52 AM
    #1679
    ThomasMore66
    That’s where I am too.
  20. Feb 14, 2018 at 9:53 AM
    #1680
    TRON
    Can you removed the ucon ems and see if those exact codes pop up again driving without it? I ask cause I’m not sure what your mods are. So many times, I tried fixing issues with my truck when it was the ucon all along. I think the more modded you are, the more problems a ucon can potentially give. It’s one reason why I love the TRD reflash. It’s consistent and reliable.
    Roostfactor likes this.
