TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 11, 2019 at 12:57 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Minor obstacles for pioneers like us! Care must be taken, I did add a corrosion inhibitor. Won't freeze here for at least another two months, lol. And even though I run huge boost, the intercooler fluid's not going to boil.
  2. Jul 11, 2019 at 12:57 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Good to know, thanks for the info Norton!
    Have you ever tried watter wetter? curious if a blend of this and water would be okay down in TX
  3. Jul 11, 2019 at 12:58 PM
    Athlaos
    Leigh
    Edmonton
    Yeah I'm at about 90/10, still added some additional corrosion inhibitor just in case.
  4. Jul 11, 2019 at 12:58 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Was thinking the same. Also was wondering if I needed a capacitor.
  5. Jul 11, 2019 at 12:59 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I would had done the same, but I'm just lazy and don't feel like monkeying with coolant, so I just service it and go. It's just easier for me and I don't have cooling issues here in my part of California, so I figure why mess with it if it ain't broken you know?
  6. Jul 11, 2019 at 1:00 PM
    Athlaos
    Leigh
    Edmonton
    Redline does market its water wetter as having corrosion inhibitors. Should we trust Redline? Sure, why the heck not.
  7. Jul 11, 2019 at 1:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You shouldn't need a cap until after about 1200 watts I believe.
    If you have an alternator over 130 amps it will cover you up until around that amount RMS. My sub is 900 so I'm not too worried about excessive draw which the system cannot keep up with.
  8. Jul 11, 2019 at 1:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have heard of some people having issues with water wetter, though I have not largely explored that avenue much because of the reason I stated above. Lol.
    BassAckwards likes this.
  9. Jul 11, 2019 at 1:03 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    With the blessings of the guys that have already ordered their cams; I’m trying to get this deal to carry through July.
    So, order before the end of this month and you get the deal.
  10. Jul 11, 2019 at 1:04 PM
    Kelvin
    Kelvin Wheeeeee
    Thought we all talked about coolant not too long ago? Higher water mix is better for heat transfer but if you live where it’s cold cold then it can freeze over
  11. Jul 11, 2019 at 1:04 PM
    Athlaos
    Leigh
    Edmonton
    Why, why must you tempt me into further financial insecurity...
    BassAckwards and 12TRDTacoma[OP] like this.
  12. Jul 11, 2019 at 1:06 PM
    Kelvin
    Kelvin Wheeeeee
    Alternator is exactly 130 amp. Combined my 2 amps will be 1150 watts. Sounds close but it should work.
    But then I’ll have quad retrofits soon drawing even more power.
    But then I don’t usually blast music at night anyway.
  13. Jul 11, 2019 at 1:06 PM
    Athlaos
    Leigh
    Edmonton
    Here in Canada if you keep the truck running, it just turns into a slurpee machine. No problem.
    Norton and BassAckwards like this.
  14. Jul 11, 2019 at 1:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I'm drawing my line at cams honestly. For sake of engine teardown downtime and my own personal finances right now. I would do it in a heartbeat if it was my spare vehicle, but I need my truck and I could use that money for TONS of other stuff that I don't need.
    Athlaos[QUOTED] and BassAckwards like this.
  15. Jul 11, 2019 at 1:07 PM
    BassAckwards
    Maybe ill get lucky and hit the lottery by the end of july :D
  16. Jul 11, 2019 at 1:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You should be okay. I'll be close to about 1080 combined, I'll have to monitor my electronics and make sure the lights don't dim. If they do I'll have to do the Alt-S mod for sure for sure and then from there recheck for dimming. If so, then I'll have no choice but to wire in a cap.
  17. Jul 11, 2019 at 1:09 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I plan on using water and amsoil’s version of water wetter in my supercharger loop soon. Then when I drain all my coolant I will switch to a 70%water/30% coolant + amsoil’s WW for the engine. It never gets that cold out here so I should be fine in terms of the coolant freezing.
  18. Jul 11, 2019 at 1:09 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This thread and my blower pulley thread is jumpin' with activity for a Thursday work day. :D
    TheFang, Murphinator and BassAckwards like this.
  19. Jul 11, 2019 at 1:12 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    As @12TRDTacoma mentioned, this is popular in some high-boost applications. I know some of my Shelby brethren in southern latitudes do it.
    +1. Like @Athlaos, I have to worry about freezing half the year, and I'm not interested in doing coolant flushes twice-a-year.
    LOL! :rofl:
    That's a solid plan in your location. :thumbsup:
  20. Jul 11, 2019 at 1:12 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I am finally getting my fix! This last weekend it was pretty slow around these parts. Now I can spend some of my workdAy BSing with you guys making it go faster :D
