TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 12, 2019 at 2:37 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    @GT7 I also used a Spal. The fan that came with the shroud/radiator combo wasn't moving enough air and I kept overheating. I thought it was bubbles in the system and it was frustrating the feck out of me. Replaced with Spal fan, no problem since.
    Norton likes this.
  2. Jul 12, 2019 at 3:29 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Alright guys question for those with more knowledge than I. Running the TRD tune, with URD Y pipe and exhaust 2.85 pulley, afe intake. Haven’t had any issues other than battling heat in the summer. Recently put some exhaust wrap on the y pipe and a few spots around the cats where they are close to the trans to help with heat. Now my AFRs are all over the place from 14.9 - 15.7. I am using the port on the URD y pipe for the afr sensor so it is actually downstream from the cats that I wrapped.
    Should I be worried and look into tuning to get the afrs back to 14.7 or is the heat wrap just distorting my reading and I need to recalibrate.
  3. Jul 12, 2019 at 3:41 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hmm. I’ve got my y-pipe ceramic coated and no issues. Do you need to leave it out in the open air and let it recal?
    12TRDTacoma[OP] likes this.
  4. Jul 12, 2019 at 3:49 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you checked for leaks around the flanges, pre-sensor?
    12TRDTacoma[OP] and DocME like this.
  5. Jul 12, 2019 at 5:03 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Never
  6. Jul 12, 2019 at 5:07 PM
    zscott
    Zach
    Utah
    Not recently but i didn’t notice anything before. And I wrapped it without taking anything off the truck so there shouldn’t be any Leaks. I put the wrap on last night and the afrs have been wonky most of today. Getting a little better this evening, maybe the computer is adjusting? They are now in the 14.7-15.3 range while cruising.
  7. Jul 12, 2019 at 5:07 PM
    zscott
    Zach
    Utah
    That’s what I wondered
  8. Jul 12, 2019 at 5:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I have some exhaust bung extensions I'd like gone. Maybe distance for a cooler temp may be the trick. With heat wrap on you may have given the sensors more than adequate heat for correct readings. PM me if it interested you.
  9. Jul 12, 2019 at 5:42 PM
    ThomasMore66
    You’re a bad human being. You’re spending my money. I might need money for a ticket.
  10. Jul 12, 2019 at 6:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I meant for myself never stopping.
    You may be correct on me being a lousy human though. Solution-dont get the ticket silly. Just outrun the berries and cherries.
  11. Jul 12, 2019 at 7:27 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I forgot that you liked audio builds. Sorry man. :)
    DUDE. This thing RIPS!!! Talk about SPL for an 8". I'm glad you are getting on the ball with fixing your sub now. :)
    @zscott I am thinking your wrap is creating unwanted heat on the sensor. The aftermarket air fuel ratio sensor setups are somewhat sensitive to heat for some reason. It must be a drawback of being able to have a wider range of air fuel readings over factory capabilities which makes them more sensitive.
    I would run a bung extension as mentioned... What sort of air fuel sensor are you running?
    I would try an air calibration before spending any money on it first.
  12. Jul 12, 2019 at 7:29 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I ment I dont remove the fan for a belt swap. Honestly, I dont have a sub. All my other speakers are upgraded, I need a sub but have no money! :)
    So Im mad jealous
  13. Jul 12, 2019 at 7:51 PM
    ThomasMore66
    Maybe we’ll have a group buy.
  14. Jul 12, 2019 at 8:06 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Looks good. No dynamat back there?
  15. Jul 12, 2019 at 8:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Now you're the terrible person. No talky of GB for at least a month.
  16. Jul 12, 2019 at 8:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
  17. Jul 12, 2019 at 8:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thinks that go bump in the night....and day.
    1350 watts of ear damage goodness
    Athlaos and 12TRDTacoma[OP] like this.
  18. Jul 12, 2019 at 8:20 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Damn. I couldnt lose all that storage but that is badass
  19. Jul 12, 2019 at 8:21 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I have a job/saddle box for everything I need. Just butts and beats in my seats.
  20. Jul 12, 2019 at 8:30 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Gas, ass, or bass...nobody rides for free.
    12TRDTacoma[OP] and henryp like this.
