TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 14, 2019 at 5:53 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    How many inches Hg are you guys reading at idle?
  2. Jul 14, 2019 at 7:00 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Anywhere between 19-20 if everything is functioning properly and is nice and tight.
    Athlaos, Norton, DocME and 1 other person like this.
  3. Jul 15, 2019 at 3:01 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Dudes, got a dyno appointment right after work tomorrow.
    Norton, jojotoo, Torspd and 8 others like this.
  4. Jul 15, 2019 at 3:05 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Nice. I think I'm still on for Friday. I have low expectations. It'll be hot and humid.
    Athlaos[QUOTED] likes this.
  5. Jul 15, 2019 at 3:13 PM
    Athlaos
    Leigh
    Edmonton
    You can just use the weather report as extra bragging. "Oh it was 120 and humid, but I still made 360whp" ... or something.
  6. Jul 15, 2019 at 3:59 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Make sure the show the graph in SAE smoothing, and RPMs instead of MPH. Woot
    Norton, Athlaos[QUOTED] and TRON like this.
  7. Jul 15, 2019 at 4:04 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Can UCON disable the speed limiter for 4th gear pulls?
  8. Jul 15, 2019 at 4:25 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    How's the weather been? Are we all entitled to one guess? If its 80 degrees, 4th gear pull, I'm tossing out 435 RWHP......(or hopefully more)!
    BassAckwards and Athlaos[QUOTED] like this.
  9. Jul 15, 2019 at 4:47 PM
    Athlaos
    Leigh
    Edmonton
    You bet. I buried the speedo needle in 5th last time.
    BassAckwards likes this.
  10. Jul 15, 2019 at 4:48 PM
    Athlaos
    Leigh
    Edmonton
    I’d be over the moon with that. Hoping for cooler weather tomorrow but looks to be around 80 in the evening anyways.
  11. Jul 15, 2019 at 4:52 PM
    DocME
    California
    '07 FJ Cruiser
    I don't have any real basis for that guess, just throwing it out there! Seemed like most trucks running all the conventional mods 2.5, fuel injectors, bolt on goodies were hitting 365 at the rear wheels. You've got the highest maf score by far....still hoping there's a correlation there.
  12. Jul 15, 2019 at 5:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Max MAF g/s x (whatever that number is that I always forget) = BHP.
    Multiplied by approximately 12 to 13% drivetrain loss, and we should be in the ballpark of his will horsepower.
    @Athlaos how close are your tires to stock dimensions?
  13. Jul 15, 2019 at 5:23 PM
    DocME
    California
    '07 FJ Cruiser
    I think the multiplier was 1.18 hp/gps. His latest posting was 444 g/s. So 444*1.18*.87 = 455ish. I estimated down for other factors.....but it would be cool to 450ish!
    Athlaos and Torspd[QUOTED] like this.
  14. Jul 15, 2019 at 5:31 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    TRON likes this.
  15. Jul 15, 2019 at 5:50 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    266 to the wheels
    12TRDTacoma[OP] and Athlaos like this.
  16. Jul 15, 2019 at 5:54 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    No way it’s 450 rwhp. I’m thinking more around 380 rwhp. Depends on whether dynodanamics or dyno jet. Tires are a factor too on dynos like @Torspd said. But maybe 400 torque. Those stock internals would be hurting north of 400 especially the rods and Internals don’t lie, they tell you the truth real quick.
  17. Jul 15, 2019 at 6:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My money is around 380 - 400.
  18. Jul 15, 2019 at 6:06 PM
    Athlaos
    Leigh
    Edmonton
    Okay so I think we have so far:
    @DocME 435whp
    @TRON 380
    @Kelvin 266
    I'm personally going to say a nice round 400.
  19. Jul 15, 2019 at 6:07 PM
    Athlaos
    Leigh
    Edmonton
    They are 2" bigger diameter.
  20. Jul 15, 2019 at 6:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll be getting some dyno pulls after my cams are installed, and tuned with the VVT working. The shop where I had this stroker engine dyno'd on OEM ECU, then later under Haltech control, is the same place that I'll go again. Due to consistency alone. Not necessarily a fan of Mustang dyno's, but the scientific process must be followed as closely as possible.
