TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 18, 2019 at 9:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    But first....check all of your spark plugs.
  2. Jul 18, 2019 at 11:53 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    On that note, I have IKH24 right now. Would you guys see any problem with going to IKH27? I was thinking of doing that, considering I have water/meth injection, it should keep colder plugs carbon-free. I know this is a bit like asking "what engine oil should I use", but curious if anyone has opinions on the pros/cons of going to IKH27.
  3. Jul 18, 2019 at 12:06 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  4. Jul 18, 2019 at 12:33 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
  5. Jul 18, 2019 at 12:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those are what I have been using for five to seven years.
    Athlaos[QUOTED] likes this.
  6. Jul 18, 2019 at 12:34 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  7. Jul 18, 2019 at 12:35 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Make him an offer, he said he’ll split it up
  8. Jul 18, 2019 at 12:53 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    They do reccomend a slightly warmer plug for methanol use. I learned that after installing 24's
    BassAckwards and 12TRDTacoma[OP] like this.
  9. Jul 18, 2019 at 12:57 PM
    Athlaos
    Leigh
    Edmonton
    You went back to 22s?
  10. Jul 18, 2019 at 3:23 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm going to.
  11. Jul 18, 2019 at 4:50 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    @Roostfactor did you trim the gauge down to fit your space there, or did you order it that way? Ordered one of these gauges and I'm looking for mounting options....should've looked first I suppose...
    Edit: Also, why's your truck soooo quiet?:boink: ;)
  12. Jul 18, 2019 at 6:54 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Quiet = weak, right?
  13. Jul 18, 2019 at 7:36 PM
    DocME
    California
    '07 FJ Cruiser
    Naw, I'm just poking him a bit. That was a wayyyy old post. Might have been pre y pipe.
  14. Jul 18, 2019 at 7:39 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    :rofl:
    12TRDTacoma[OP] and Torspd like this.
  15. Jul 18, 2019 at 10:32 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I trimmed the gauge face down and removed the channel between where two switches would go.
    That was y-pipe, flex, cat, res, Magnaflow 12579. :D
  16. Jul 19, 2019 at 7:40 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Ran a new ford ranger this morning. It didnt go as planned for him:D
  17. Jul 19, 2019 at 7:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :D
  18. Jul 19, 2019 at 8:15 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I would go hotter not colder @Athlaos for the spark plugs. A colder plug would only potentially open the door to misfires as the cooling effect of meth or water injection is already substantially cooling the engine down. You want the spark to burn the mixture not further cool it down.
    Athlaos likes this.
  19. Jul 19, 2019 at 8:16 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    All in this thread as part of the GB. Please reconfirm whether or not you are still in for the crank pulley GB so I can reupdate the list. There have been some recent developments some might find unfavorable to them.
    BassAckwards likes this.
  20. Jul 19, 2019 at 8:17 AM
    BassAckwards
    Im back in depending on pricing sir:)
