TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Jul 29, 2019 at 9:45 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    https://youtu.be/_EPpBhP2he0
    I'll just leave this here.... all the disclaimers of course: closed course, professional driver, NASA escort, running on humanly sourced all natural organic fed bat guano.
  2. Jul 29, 2019 at 11:12 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    So does your cruise control work at this speed? I wonder if HP tuner can increase the limit on it.
    Athlaos likes this.
  3. Jul 30, 2019 at 3:39 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Spoke to Magnuson. They won’t ship me a bypass valve but they have informed me of a distributor they have here not far from me. I have spoken to them and they have the parts there plus they also have the HP tuner software to dyno the car so I’m taking it there for them to fix and get everything working 100%. Easy done.
    Question: my tire size is one size up than normal which puts my speedo out. Will this effect the dyno results?
    Norton likes this.
  4. Jul 30, 2019 at 3:47 AM
    australian hilux
    Justin
    None at this point
    Man I hope my Ute runs that well when it’s finished! I’m jealous right now!
  5. Jul 30, 2019 at 4:18 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Gave mine a ride after a lot of work. Her bodily expressions said the same thing. The boost bug bit hard. :D
  6. Jul 30, 2019 at 4:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I was always curious how you were planning on tuning the ECU. As you had never mentioned HP Tuners prior. Now it all comes together.
    Have you read through any of the HP Tuner thread? One of the premier tuners in that thread is @JustDSM. I don't remember if they can recalibrate for tire size, bit they have made leaps and bounds of progress over there.
    People making more power and saving petrol, simultaneously.
  7. Jul 30, 2019 at 5:16 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hmm, my gas mileage has declined...not the fault of HP Tuners.
  8. Jul 30, 2019 at 6:14 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Found those lead soled shoes eh? ;)
  9. Jul 30, 2019 at 6:18 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Tungsten.
  10. Jul 30, 2019 at 6:40 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    A speedo that’s off won’t affect your dyno results.
    mr.trd, Norton and 12TRDTacoma[OP] like this.
  11. Jul 30, 2019 at 6:51 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    No, but the tire size will.
  12. Jul 30, 2019 at 6:56 AM
    Athlaos
    Leigh
    Edmonton
    Ya, good point. Especially with dynojet: I’m tired this morning.
    12TRDTacoma[OP] likes this.
  13. Jul 30, 2019 at 6:57 AM
    Athlaos
    Leigh
    Edmonton
    Maybe I can use that as an excuse for why I don’t have the 1.18 factor that I should :D
  14. Jul 30, 2019 at 7:13 AM
    Athlaos
    Leigh
    Edmonton
    I'm hoping I get even worse fuel economy with the camshafts in. I use the abominable economy as a bragging point. I'm pretty sure no one else thinks I'm bragging though...
  15. Jul 30, 2019 at 7:25 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Pulled about 1.5mpg recently. You ever go that low?
  16. Jul 30, 2019 at 7:38 AM
    Athlaos
    Leigh
    Edmonton
    I don't think I've made it there. That's something to brag about for sure.
  17. Jul 30, 2019 at 7:52 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    My mpgs have definitely gone up after refining the TRD tune. Used to get 270-280 miles per tank. Now I get over 300
  18. Jul 30, 2019 at 7:55 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    1.5?! What the heck tune were you running, Potato?
    JacksonTacoma likes this.
  19. Jul 30, 2019 at 8:06 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Lol. That was while on the rubicon. 16 miles took roughly 18hrs and 1/2 tank.
    Same trip I saw almost 18mpg thanks to a damaged drive shaft limiting me to 65mpg and drafting my buddies jeep
  20. Jul 30, 2019 at 2:24 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    Very nice, love the gauges and I think I need a needle gauge because looking at my AFR I don't think I even cruise at stoichiometric. EVER. lol
    Norton[QUOTED] and BassAckwards like this.
