TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 1, 2019 at 2:37 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    We are already configured and set up to run a Supercharger so in reality it would cost more at this junction to switch out to a turbo.
    We do it better. That's right. :thumbsup:
  2. Aug 1, 2019 at 2:43 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    If I had a blower and tolerances I have a guy that could make one.
    TodayWasTHeDaY likes this.
  3. Aug 1, 2019 at 2:52 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  4. Aug 1, 2019 at 3:20 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I know.
  5. Aug 1, 2019 at 3:36 PM
    Wild Heart
    Wild Heart Well-Known Member
    Daryn
    2015 DCLB BRM
    Question. Would those Rotrex superchargers that Gadget sells flow more air?
    Anderson likes this.
  6. Aug 1, 2019 at 3:57 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yes, more than a TRD supercharger. However, there are other considerations with the Rotrex. It doesn't have as much low end torque and the reliability is not the same as the TRD unit.
  7. Aug 1, 2019 at 4:01 PM
    Wild Heart
    Daryn
    2015 DCLB BRM
    Thanks for the response. I learned something new today.
  8. Aug 1, 2019 at 4:33 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Quite a bit.
  9. Aug 1, 2019 at 4:46 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Aren’t we, and by we I mean some of you, already pushing the max boost these engines can take without needing internal upgrades out of the trd unit? If so, obviously you can upgrade internals and do a custom whopper setup, but then how far can you go? 500whp before you’re making something else out?
    Just some genuine curiosity as one day I’d like to be making over 500 reliable whp. Always thought it would be by doing a 5.7 tundra swap with the sc as I don’t want to be like everyone else doing an ls. But depending on cost and power output, a full 1grfe build may be cheaper than the tundra swap. Then again I want to swap tundra front and rear axles/ diff one day to the taco so may just buy a totaled one and scavenge what I can
  10. Aug 1, 2019 at 4:53 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Iv'e been looking to buy a used 1GR-FE and rebuild it with a Brain Crower stroker kit, Darton Sleeves, bore it out 0.050" to make it a true 4.4L , the Kelford cams plus my current setup. Even then I doubt I'll be at 500hp but I should be close(r). @Torspd has done just about everything to his motor and put down some serious numbers.
  11. Aug 1, 2019 at 6:36 PM
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    These are still trucks. Trucks tow stuff. Trucks pull heavy loads up big hills for hours on end.
    I don't dislike turbos. Every other car I have is turbocharged. Turbos make power, sure enough. They also liquify exhaust valves (and more) when used for heavy load towing. There's a reason Toyota/TRD chose a supercharger for the Tacoma and the Tundra.
  12. Aug 1, 2019 at 6:47 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I like how my engine is just a glorified tundra engine that’s been tuned for higher hp and fuel economy
  13. Aug 1, 2019 at 6:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This guy right here gets it.
    Athlaos and GT7 like this.
  14. Aug 1, 2019 at 6:54 PM
    Kelvin
    Kelvin Wheeeeee
    Sometimes I wished the UZ could handle more power but then I see you guys spending and spending and spending and I quickly have a change of heart
  15. Aug 1, 2019 at 7:23 PM
    ThomasMore66
    There is a new STI questioning his choices tonight in my little town. I love my supercharger, but I don’t want a third gen running past me. Phuckers.
  16. Aug 1, 2019 at 7:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    To be honest here, I haven't spent much so far. The Qwickchange, the belts and the tensioner... Can't think of anything else other tha the maintenance which had the coupler.
    Oh yeah, the recent cam gears thing.. there was that.
    mightytacoman and Athlaos like this.
  17. Aug 1, 2019 at 7:31 PM
    Kelvin
    Kelvin Wheeeeee
    You suck. Step your game up Holmes
  18. Aug 1, 2019 at 7:33 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    I'm happy for the 3rd gen guys. I'd never have touched that 3.5 without some kind of boost in it.
    Just wonder how the schizophrenic trans will hold up with that kind of hp and all the TSBs it's needed.
    I also question if the TT setup can be mass produced with reliability and decent support. Time will tell.
    Who knows the competition might require us to step up our game.
  19. Aug 1, 2019 at 7:39 PM
    Kelvin
    Kelvin Wheeeeee
    What is the 3.5 related to? RR Racing has a supercharger for the Lexus 350’s that makes something like 450 whp if you want to gauge strength of internals
    skyking3 likes this.
  20. Aug 1, 2019 at 7:41 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I feel I have a hint about the level of support, not awesome
