TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 25, 2018 at 3:19 PM
    #1781
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    That is very interesting. Does it drive any different?
  2. Feb 25, 2018 at 3:26 PM
    #1782
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Nope pretty much the exact same, it’s running very nicely.
    Skootter14, loginfailed and jojotoo like this.
  3. Feb 25, 2018 at 4:00 PM
    #1783
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I’m going to be running 2.6 pulley. I need the fpr mod.
  4. Feb 25, 2018 at 4:01 PM
    #1784
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    On mine, the throttle response felt a little sluggish with the FPR mod.
  5. Feb 25, 2018 at 4:02 PM
    #1785
    GT7
    Grant
    Phoenix
    2013 DCLB
    You do? I have the 2.5 without.
    oni06 likes this.
  6. Feb 25, 2018 at 4:16 PM
    #1786
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    U running ucon?
  7. Feb 25, 2018 at 4:18 PM
    #1787
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yes, aren’t you?
  8. Feb 25, 2018 at 4:30 PM
    #1788
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    No I’m not. You aren’t supose to run fpr mod with ucon
    12TRDTacoma[OP] likes this.
  9. Feb 25, 2018 at 4:32 PM
    #1789
    GT7
    Grant
    Phoenix
    2013 DCLB
    For some reason I thought you had one! Thats why I was asking to make sure you didnt with the Ucon :cheers:
    Skootter14 likes this.
  10. Feb 25, 2018 at 4:34 PM
    #1790
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Haha I just don’t think I can justify the $$
    GT7 likes this.
  11. Feb 25, 2018 at 7:20 PM
    #1791
    ThomasMore66
    Dallas/Fort Worth & Durango
    I did fpr and jet removal. Seems faster.
    12TRDTacoma[OP] and loginfailed like this.
  12. Feb 25, 2018 at 8:13 PM
    #1792
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You removed the FPR?
    :D
    12TRDTacoma[OP] and Roostfactor like this.
  13. Feb 26, 2018 at 4:26 AM
    #1793
    ThomasMore66
    Careful. I’ll have to come down to Houston.
  14. Feb 26, 2018 at 5:45 AM
    #1794
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ll be in Dallas soon if you want to discuss further. :D
  15. Feb 26, 2018 at 11:04 AM
    #1795
    ThomasMore66
    In reality, if you're in the area and it works out, I could be talked into a beer or 3.
    loginfailed[QUOTED] likes this.
  16. Feb 26, 2018 at 1:18 PM
    #1796
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dare you.
    Biscuits, Roostfactor and loginfailed like this.
  17. Feb 26, 2018 at 8:52 PM
    #1797
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    do any of you have a link to the "how to" sorta write up with pics on modifying the URD TCAI for the S/C? I KNOW I saw it on here somewhere and cant find it in the search feature. Im tracking the 2" cut off of the part near the TB and wanted to make sure I had the scrap metal for the bracket to extend the filter passed the intercooler
    loginfailed likes this.
  18. Feb 26, 2018 at 9:33 PM
    #1798
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I know you searched it on TW.....try doing a google search , it may pop up there
  19. Feb 27, 2018 at 12:05 AM
    #1799
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think @tacomavoyager had the URD TCAI.
  20. Feb 27, 2018 at 6:22 AM
    #1800
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I added an autozone bend piece and made a bracket so the filter sits here since mine was rubbing on the intercooler. IMG_1232.jpg
    Skootter14[QUOTED] likes this.
