TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 3, 2019 at 5:17 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Yeah your right. I’ve learnt a heap from everyone in here with troubleshooting and little mods along the way. Hopefully not too long and I’ll been doing what you did in the video.
    Athlaos and Torspd like this.
  2. Aug 3, 2019 at 8:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Got a picture of this bush boosting beast of yours???
  3. Aug 3, 2019 at 8:29 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    His s/c is red. Must be a southern hemisphere thing.
    12TRDTacoma[OP] likes this.
  4. Aug 3, 2019 at 8:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah, or TRD Australia thing?
  5. Aug 3, 2019 at 9:11 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Toyota Racing Development: Australia Division
  6. Aug 3, 2019 at 9:47 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    So do the rotors spin the other way?
    oni06, BillDaCat8, Norton and 13 others like this.
  7. Aug 3, 2019 at 9:49 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I actually spit coffee out at that one
  8. Aug 3, 2019 at 9:58 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    That was comedic genious
  9. Aug 3, 2019 at 10:30 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    :rofl:
    I need to dub @Kelvin the threads Captain Obvious.
  10. Aug 3, 2019 at 10:34 AM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    The TRD Outback
    Athlaos likes this.
  11. Aug 3, 2019 at 10:52 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    So, does it come with a bloomin' onion?
  12. Aug 3, 2019 at 10:53 AM
    Kelvin
    Kelvin Wheeeeee
    I’ll be here all day folks :D
  13. Aug 3, 2019 at 10:59 AM
    Kelvin
    Kelvin Wheeeeee
    Also my Snow VC-50 is out for delivery
  14. Aug 3, 2019 at 11:01 AM
    TodayWasTHeDaY
    Russ
    Calgary
    The intercooler heats a remote mount FIGG deep fryer with an thermostat e-fan for temp control and methanol injection if it gets too hot.
  15. Aug 3, 2019 at 11:06 AM
    Kelvin
    Kelvin Wheeeeee
    Fryer? Thought they just throw shrimps on the barbie down under
  16. Aug 3, 2019 at 11:28 AM
    TodayWasTHeDaY
    Russ
    Calgary
    It's for the onion silly
  17. Aug 3, 2019 at 11:50 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sure do!
  18. Aug 3, 2019 at 1:06 PM
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    For as much as it costs, I expect the FIGGS to serve me a bloomin onion while it's simultaneously holding coolant. Right @ThomasMore66
  19. Aug 3, 2019 at 1:44 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A turd in the outback?
  20. Aug 3, 2019 at 2:31 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Should have asked. I’d send my Ratiotek to anyone that wanted it.
