TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 3, 2019 at 2:45 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    It’ll hold your beer.
  2. Aug 3, 2019 at 2:48 PM
    ThomasMore66
    ‘Cause you don’t have a Tacoma.
  3. Aug 3, 2019 at 3:09 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    I just want to sticker bomb someone’s truck in here with figs stickers
    But I have 2 more cylinders. And heated rear seats.
  4. Aug 3, 2019 at 3:23 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'll take it! I need one.
    nudavinci64 and zerotimeouts like this.
  5. Aug 3, 2019 at 3:28 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    To keep the asses warm of all the chicks you don’t have?
  6. Aug 3, 2019 at 3:29 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Oooooh, right in the nuts
  7. Aug 3, 2019 at 3:56 PM
    Kelvin
    Kelvin Wheeeeee
    :pout:
  8. Aug 3, 2019 at 4:14 PM
    TodayWasTHeDaY
    Russ
    Calgary
    Keep your chin up, I've been where u are. Then all of a sudden you'll end up married with a kid lol.
  9. Aug 3, 2019 at 4:34 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Other than @loginfailed does anyone else have an electric fan installed? Anyone seen this kit https://www.lceperformance.com/Elec...MIl5rzg-fn4wIVQ5yzCh0eTQPNEAQYAiABEgKo6PD_BwE
    I just put the CSF radiator in and it solved the overheating issues completely at speed but at idle and slow speeds I still need moar! Going slow up the trails I can see engine temps drop 2-4 degrees just by stomping on the gas to get that mechanical fan going a little quicker. I am convinced that an electric fan that is full power regardless of speed would help my offroad trips
    mr.trd likes this.
  10. Aug 3, 2019 at 4:38 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Well I'll be damned
    12TRDTacoma[OP] likes this.
  11. Aug 3, 2019 at 4:41 PM
    Athlaos
    Leigh
    Edmonton
    I have an e fan. Although it’s a champion four core radiator made for an impala. I bought it from ledfoot racing and it came with a fan and a shroud. I had to replace the fan though, the fan that came with it was a really cheap one and I kept overheating. Replaced with A Spal fan and it’s been good.
  12. Aug 3, 2019 at 4:46 PM
    zscott
    Zach
    Utah
    What output fan did you use?
    Anyone know the output of the stock mechanical fan?
  13. Aug 3, 2019 at 5:30 PM
    Roostfactor
    TX panhandle
    I've got an Efan I Frankensteined out of a 90's Lincoln Mark VIII.
    Athlaos likes this.
  14. Aug 3, 2019 at 5:33 PM
    Roostfactor
    TX panhandle
    Not offhand but you can change the mechanical fans properties by changing fluid viscosity, volume, and engagement temp.
    I played with it a bit but ultimately went with the Mark VIII efan.
  15. Aug 3, 2019 at 5:37 PM
    ThomasMore66
    Pm me where to send it.
    Roostfactor[QUOTED] likes this.
  16. Aug 3, 2019 at 5:38 PM
    ThomasMore66
    Ya know, I didn’t even get a sticker...
  17. Aug 3, 2019 at 6:45 PM
    Athlaos
    Leigh
    Edmonton
    I can’t remember the model or output that I bought. I just bought the 16” Spal fan that had the highest CFM possible.
  18. Aug 3, 2019 at 6:56 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm curious how the stock alternator handles this. Yes, it frees up drag from a mechanical fan but it's a heavier load on the charging system. Looks nice. I wanted to get an electric fan out of a Lexus and fit that. Keep it OEM-ish. Genuine Toyota parts tend to have better build quality than some aftermarket ones.
    12TRDTacoma[OP] and BassAckwards like this.
  19. Aug 3, 2019 at 7:03 PM
    zscott
    Zach
    Utah
    Yeah at this point I am fine upgrading the alternator if needed. I need something that will run full speed while I am crawling along.
  20. Aug 3, 2019 at 7:32 PM
    Roostfactor
    TX panhandle
    No problem. I also put a slightly smaller pulley on my stock alternator to boost low rpm/idle output.
    I integrated my Mark VIII fan and should into a stock FJ shroud so it looks stock. You cant even see the fan in the shroud.
