TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 5, 2019 at 6:31 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I've bought both. I feel the roush is a better product.
    My 2 cents.
  2. Aug 5, 2019 at 6:32 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Not a mandatory item. I'd say do it when you have time.
    12TRDTacoma[OP] likes this.
  3. Aug 5, 2019 at 7:42 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I would do the Roush out of all of them, cheap(er) more effective, and more worth the modding to make it work if you want to use the double bearing roller.
    I can mod it later.
  4. Aug 5, 2019 at 7:48 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Your 2 cents is appreciated sir. I was on the fence pretty bad... almost as much on the fence as @nudavinci64 is about new cams. :D
    nudavinci64 likes this.
  5. Aug 5, 2019 at 7:48 AM
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    What is everyone offering him on eBay for the bearing?
  6. Aug 5, 2019 at 7:50 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Asking price. He is on to us by now.
    nudavinci64 and 12TRDTacoma[OP] like this.
  7. Aug 5, 2019 at 7:52 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Same
  8. Aug 5, 2019 at 8:06 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I just paid for it straight up
  9. Aug 5, 2019 at 8:09 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Is the 255 lpm upgraded pump enough to handle the 2.7 pulley or do I need to jump to the 320 or 340? Currently hitting high 9s and low 10s AFR at WOT with the 2.8 pulley and no FPR mod so I am definitely running rich. Doesnt seem to have any issues with fuel supply but I don't know how big of a difference the 2.7 is going to make.
  10. Aug 5, 2019 at 8:11 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    I like my 320. Might as well it was only $110. Whats your tune? U need one
  11. Aug 5, 2019 at 8:13 AM
    zscott
    Zach
    Utah
    Just the TRD tune right now. I may get the HPtuners but from what I have read there are a few people running the 2.7 on the TRD tune with the FPR mod and 320 pump.
  12. Aug 5, 2019 at 8:16 AM
    zscott
    Zach
    Utah
    To be honest I don't really need the 2.7 pulley, the 2.8 is working fine, but the finish on it is terrible. It has slowly flaked to where it is stating to rust and looks like garbage. Every time I open the hood I see it and it pisses me off, not to mention the rust corrosion will probably start rubbing off on the belt too. So I am going to replace it and figured If I am going to swap it out, might as well get the quick change setup and try the 2.7.
    RyanL likes this.
  13. Aug 5, 2019 at 8:23 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Exactly. I had the 2.7, 320, and trd tune. It was fine. U want an hpt tho
  14. Aug 5, 2019 at 8:25 AM
    zscott
    Zach
    Utah
    Hmmmm.... which to get first. HPT or smaller pulley and 320 pump. One will have to be purchased next month when funds recover.
  15. Aug 5, 2019 at 8:26 AM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hpt first and start messing with it. Pulley and pump wont make a huge difference
  16. Aug 5, 2019 at 8:29 AM
    zscott
    Zach
    Utah
    Yeah but then I have to look at that garbage for another month. :puke:
    Did a thorough cleaning of the engine bay yesterday and it made it worse. Everything clean and that pulley looking like it came from a 40 year old junk yard vehicle.
  17. Aug 5, 2019 at 8:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You can run 2.7 with the fpr but I wouldn't recommended now that we have proper fuel control tuning available to run at the PCM. I would do HPT first then get your go fast stuff.
    Roostfactor and Torspd like this.
  18. Aug 5, 2019 at 8:51 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    20190805_084903.jpg what is the secret of these clips? How did yall get them off?
  19. Aug 5, 2019 at 8:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mishimoto makes the bolt in 160° with included housing.
  20. Aug 5, 2019 at 8:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yank up. Flat head underneath them to pry.
    JacksonTacoma and DocME like this.
