TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 5, 2019 at 9:37 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Goal wise it changes too much but a semi go fast, go anywhere truck with more power! Had the SC on my wish list forever.. Its built up almost as far as I can go Mid Travel suspension wise. Needs more clearance and more power but its a learning lesson for sure.
    I am debating maybe going 2.7 or 2.8 pulley. I ordered the 2.5 but seems like its going to need some more work to run well. Unless I read that wrong through the threads. Pulley was supposed to arrive today but they wanted a signature so didnt drop it off.
  2. Aug 5, 2019 at 9:44 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    my goal is too much
    you have similar goals like mine. go 2.7 if you want a start. go 2.5 if you want real fun. my motto is excessive is a great starting point. disregard all my advice if you want balance. I'm on a mission for a scary fast lifted Tacoma. I love mine but more always happens.
  3. Aug 5, 2019 at 9:45 PM
    nudavinci64
    Robert
    Whats everyones take on going with 2.5 vs say 2.7 vs 2.8. Besides needing some HPT love anything else a must have off the back? Shorter belts with the tensioner and smaller pulley. Do I need a new fuel pump right away? Also I am waiting for the ratiotek but is it required right away? Sounds like at some point for sure but looking at what I can get done with limited time at SC install time.
  4. Aug 5, 2019 at 9:45 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Ha! I have 315’s and 4:88’s but I wish I went with 4:56’s.
    mr.trd likes this.
  5. Aug 5, 2019 at 9:45 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I’m breaking in 4.56s with 34” tires right now. Seems like it’s about the perfect match for my auto, I’m turning about 2300 rpm at 65 mph, I haven’t exceeded that because of the break in. I will say it’s been hot here lately, around 100f, and at cruise at 65 mph I’m around 195f with the 170f thermostat. I’m happy with that after last year before the CSF radiator and thermostat when I’d push 210f under the same conditions, or worse.
  6. Aug 5, 2019 at 9:46 PM
    nudavinci64
    Robert
    ha yah I tend to go all in or if I am on one track ill see it through. Thats what I did with the MT setup instead of redoing it all with LT at least in the front. I want to beat the hell out of that first and see if I even need it. goal would be 350-400hp this thing would be super fun.
  7. Aug 5, 2019 at 9:47 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    285/75r17. Just barely a 34" tire, not as wide as 295 tho. I rub enough as it is, cannot imagine going wider.
    Also I will say, anyone looking for the rear end to ride better, these archive garage hammer hangers has completely changed the way my truck handles now. It is an absolute monster now, I am still shocked at the difference every time I drive it.
    mr.trd, TodayWasTHeDaY and DocME like this.
  8. Aug 5, 2019 at 9:47 PM
    nudavinci64
    Robert
    MT or AT? do not recall if the FJ's had MT or not or could be different but on the AT the 4.88 for sure. At the time I did not know when I would go 315 or 35 but I should have known better.
  9. Aug 5, 2019 at 9:48 PM
    nudavinci64
    Robert
    nice I was debating on that or the BAMF setup. did you add the cross bar too? I may go back down to 285/75/17 next time around or 295 if they have it in a 75.
    Murphinator[QUOTED] likes this.
  10. Aug 5, 2019 at 9:50 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if you read and follow the ground work of others here I see only bank accounts being a limit. the fellas here are the most creative and helpful I've ever known. I'm very grateful for the knowledge I've found here. and it evolves constantly. good times.
    mr.trd, Roostfactor, skyking3 and 2 others like this.
  11. Aug 5, 2019 at 9:52 PM
    nudavinci64
    Robert
    Totally, I am all in now that the flood gates are opened. Only been here with everyone for a couple days now getting ready for it and already have this either ordered or on the mod list (for ones that are not really purchases)
    [SC] RatioTek RTA750EHD Valve Body Kit
    [SC] PulleyBoys Qwikchange pulley kit 2.5
    [SC] Rousch HD Tensioner
    [SC] LFP 50mm Billet Double Bearing
    [SC] SuperCharger - pending shipment
    [SC] Speedhut custom - Standalone Air/Fuel Wideband with Analog Out
    [SC] Speedhut custom - Boost/Vac guage
    [SC] Filler neck reduction mod
    *12196-38010 Tundra oil filler tube seal
    *12185-38011 Tundra oil filler tube
    [SC] FPR (Fuel Pressure Regulator) mod
    [SC] Pulley wrap mod for pulley's 2.7 and below
    [SC] Pulley RIP mod
  12. Aug 5, 2019 at 9:53 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    damn you. I thought I held the record for obsessive ordering.
  13. Aug 5, 2019 at 9:55 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I got the cross tube, would not have it any other way right now.
  14. Aug 5, 2019 at 9:55 PM
    DocME
    California
    '07 FJ Cruiser
    Mine is an A/T but they made many manuals as well. It’ll be interesting to see how you like it with the S/C. Aside from freeway rpms being higher than I’d like, this thing does shit and get.
    If I didn’t spend a small fortune to have Zuk do a super sweet gear setup, I’d offer a trade...
    mr.trd and BassAckwards like this.
  15. Aug 5, 2019 at 9:56 PM
    nudavinci64
    Robert
    Nice, I def like that part of it. I had AG on my list until BAMF came out with theirs being local to me but may revisit the archive.
  16. Aug 5, 2019 at 9:59 PM
    DocME
    California
    '07 FJ Cruiser
    Sounds like you have a busy Saturday planned!
  17. Aug 5, 2019 at 9:59 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I considered both options carefully, but ended up with the AG kit. It's more $$ but it was money well spent in my opinion.
  18. Aug 5, 2019 at 10:00 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Sorry for the excessive posts on cooling recently but here’s a conundrum for you guys.
    60 mph cruising in 80-90 degree weather I am hitting about 194 degrees top temperature. One would assume that at this speed the fan isn’t doing much and it is mainly the air flow from speed hitting the radiator and doing the cooling.
    However, if I smash the gas pedal and really pin it, (thus spinning the fan faster) I can get my temps to drop to about 188 pretty quick. Once I let off the gas and return to cruising speed the temps will slowly creep back to 192-194.
    My theory is that due to the excessive crap in front of my radiator (intercooler, condenser, trans cooler, light bars, bumper, skid plate, etc. I don’t get the cooling you would expect from natural air flow at high speeds. I really need that fan pulling air through the small gaps and forcing it over the radiator. Thoughts?
    Roostfactor likes this.
  19. Aug 5, 2019 at 10:01 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Retard gears are in, truck is back together. Gonna let it sit overnight to let the RTV set up. My spark plugs were beyond toast. Like I don’t know how my truck was running toast. :puke:
    Looking forward to how that poly coupler feels....
  20. Aug 5, 2019 at 10:01 PM
    nudavinci64
    Robert
    more like a busy weekend. Was hoping or planning to do it while we install the SC. Or at least find out what I can install at first.
