TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Feb 28, 2018 at 12:04 PM
    #1821
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Fuel pressure under boost
  2. Feb 28, 2018 at 12:06 PM
    #1822
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It allows you to potentially run a smaller pulley for more boost since the fuel injectors will be supplying more fuel proportionate to boost pressure. Search is your friend in this case. Much has been said on this topic.
    Norton likes this.
  3. Feb 28, 2018 at 12:48 PM
    #1823
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    You hit the nail on the head man. I may try and crack the crank pulley first so I don’t get everything else taken apart and can’t get that. I’ll work on not over thinking it :thumbsup:
    Roostfactor[QUOTED] likes this.
  4. Feb 28, 2018 at 2:46 PM
    #1824
    tfeltz73
    tfeltz73 That's greasy Ricky
    central Wisconsin
    2013 supercharged long travel thing
    I'm trying to figure out where to hook the hoses up for the oil catch can and can't figure it out on the trd s/c. Tried searching but couldn't find anything. So I'm wondering if someone with the catch can on a trd supercharger could snap a pic of where the hoses hook up to.
  5. Feb 28, 2018 at 2:49 PM
    #1825
    ThomasMore66
    Dallas/Fort Worth & Durango
    On the first few pages! One weekend there was a flurry of activity and reporting.
  6. Feb 28, 2018 at 3:37 PM
    #1826
    Roostfactor
    TX panhandle
    On the drivers side rear of the valve cover is the pcv valve and the line connects to the bottom of the sc inlet right before it does the 180 degree bend. You disconnect the line off the pcv valve and run tubing to your catch can, then the return line from your catch can to the sc inlet.15198607554331437861667.jpg Not the best pic but look directly below the screwdriver. That's the line going to the intake, the other side of that line goes to the pcv valve.
  7. Feb 28, 2018 at 8:46 PM
    #1827
    ThomasMore66
    And there will be blood when you attach the hose to the PCV valve. Unless you have small hands and arms.
    loginfailed likes this.
  8. Feb 28, 2018 at 9:04 PM
    #1828
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Or magic fingers
    Biscuits and Roostfactor like this.
  9. Feb 28, 2018 at 9:45 PM
    #1829
    Roostfactor
    TX panhandle
    That can be taken sooo many ways!
    loginfailed[QUOTED] likes this.
  10. Feb 28, 2018 at 10:35 PM
    #1830
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Factor PCV sucks.... always allows the SCer to suck in oil.... Thinking about just venting the PCV to atmosphere
  11. Mar 1, 2018 at 5:35 AM
    #1831
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I believe that would cause a vacuum leak
  12. Mar 1, 2018 at 5:59 AM
    #1832
    tfeltz73
    central Wisconsin
    Thank you I've located it and have no idea how the hell to get to it. I might need my brothers small hands in there.
  13. Mar 1, 2018 at 6:28 AM
    #1833
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In one method, yes. Removing the pcv system from the intake at both ends, BY capping the intake tube as well as the intake manifold, is the only proper way to prevent a vacuum leak.
    Murphinator[QUOTED] and BenMara like this.
  14. Mar 1, 2018 at 7:39 AM
    #1834
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Isnt the PVC the only thing thats rerouted to the intake? Doesnt the PCV relive pressure in the crank case? Man i need to find my catch can..
  15. Mar 1, 2018 at 7:42 AM
    #1835
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    So if you capped both ends from the intake you could allow it to vent to the atmosphere with no issue? Interesting
  16. Mar 1, 2018 at 8:39 AM
    #1836
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I had to be more specific than the way you had mentioned it. I know some fool would see that and then just disconnect one side and vent it to atmosphere. Then cause a huge vacuum leak. Then complain that we told him wrong. Lol.
    This is how mine is. The engine sucks nothing from the valve covers. Both valve covers are routed into a catch can with a breather on the can.
  17. Mar 1, 2018 at 8:56 AM
    #1837
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Very cool to know!
  18. Mar 1, 2018 at 4:36 PM
    #1838
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    12TRDTacoma[OP] and Torspd like this.
  19. Mar 1, 2018 at 4:42 PM
    #1839
    GT7
    Grant
    Phoenix
    2013 DCLB
    zerotimeouts[QUOTED] likes this.
  20. Mar 1, 2018 at 7:48 PM
    #1840
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Hi.
    Wat.
    I sense marketing horse shit but please elaborate .
    Hm. This makes me think of something refiners have known for a number of years and why methanol is slowly being phased out of de-icing/antifreezing applications.
    You are aware that EtOH is added to gasoline to increase the octane, correct? Ever since good ole MTBE was found to be a pretty potent carcinogen and banned, EtOH was the best alternative at the time.
    If you want "naturally" blended high octane gasoline without EtOH, or any other "additive" blendstock (e.g. lead, MTBE, EtOH), be prepared to pay a hell of a lot more for gasoline. What's good for the gander is good for the goose.
    Oh, and refining crude oil uses natural gas as well... To fire the heaters .
    You're paying for the detergents that are Shell-proprietary. I can't guarantee with confidence where the actual gasoline came from in your area, but I can tell you it didn't come from a Shell refinery. It likely came from tank that held gasoline refined from a half dozen refineries across the US.
