TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 7, 2019 at 9:39 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    You guys think I can still hook up the green led that shows when you’re injecting meth alongside my new VC50 controller that has its own built in flow graph? Not sure if the led would interfere with the reading.
    I’ve got this stupid idea to keep the controller hidden in the glove box and just have the LEDs visible.
    Edit - called Snow and it’ll work out the way I imagine
  2. Aug 7, 2019 at 10:42 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Just pull the "add a fuse" in the engine compartment fusebox prior to flashing.
    Norton[QUOTED] likes this.
  3. Aug 7, 2019 at 10:44 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    IIRC doing that raised my voltage 0.3 V. I did a log of installed, pulled, installed to see how it would effect it. (engine off/key on)
  4. Aug 7, 2019 at 1:26 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Anyone here running something like this on their headers/manifold to reduce under hood temps. Popular option with fancy cars. They seem to get quite a bit of heat reduction using them although as mentioned before it does heat up your exhaust more.
    DocME likes this.
  5. Aug 7, 2019 at 2:21 PM
    Kelvin
    Kelvin Wheeeeee
    I would consider better flowing headers before doing any of that.
  6. Aug 7, 2019 at 2:32 PM
    zscott
    Zach
    Utah
    Two different purposes as far as I am concerned. Sure better flowing headers will help move heat faster but they are mainly meant to improve flow and add HP/Torque. These blankets/sleeves are primarily meant to contain heat and reduce under hood temps. They aren't meant to directly add performance as far as HP/Torque are concerned. Plus in emissions controlled areas traditional long tube headers may not always be an option.
  7. Aug 7, 2019 at 2:36 PM
    Kelvin
    Kelvin Wheeeeee
    I mean I’m not going to stop you, but how long do you think those paper thin walls would last with the increased heat?
  8. Aug 7, 2019 at 2:40 PM
    zscott
    Zach
    Utah
    I haven't the slightest idea. That's why I brought it up. My original post was questioning their effectiveness/worth. I know that there are tons of this type of product for cars that get hotter than ours with and without upgraded headers/manifolds. Whether they work or not, or whether they do more good than harm I am trying to research and learn about.
  9. Aug 7, 2019 at 4:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Depends on what material is used, that is "paper thin." If it 304 grade or better, it will be just fine.
  10. Aug 7, 2019 at 4:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That looks like something from PTP Turbo blankets, or Heat Shield Products.
    I just use the PTP exhaust wrap, with 3/4 overlay. Works great!
  11. Aug 7, 2019 at 4:34 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    did you notice a difference in performance and under hood temps?
    Norton likes this.
  12. Aug 7, 2019 at 4:37 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I've never seen those header diapers before. I bet they'd work decently to reduce under hood temperatures. Curious to see your results if you move forward with them.
    Edit: Do they have drain holes? or are they oriented in such a way to prevent holding moisture?
  13. Aug 7, 2019 at 4:42 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that would be important not to hold moisture. I wonder if they fit long tubes.
  14. Aug 7, 2019 at 5:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those look like something on an exotic car.
    As for holding moisture, a short idle would rid them of any.
  15. Aug 7, 2019 at 5:47 PM
    Kelvin
    Kelvin Wheeeeee
    He’s wanting to use them on stock manifolds.
  16. Aug 7, 2019 at 5:51 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Can anyone confirm if this is the right bearing for the tensioner pulley?
  17. Aug 7, 2019 at 5:55 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    buy the 50mm double man. I have a complete set of those too.
  18. Aug 7, 2019 at 5:57 PM
    BassAckwards
    I would but dont feel like modifying the tensioner, just a little too much work. I just want to have some stock replacements on hand. Something is chirping occasionally and im not sure if its the belt or the tensioner idler
    Norton and 12TRDTacoma[OP] like this.
  19. Aug 7, 2019 at 6:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I have occasionally heard it too. I removed my jfr belt wrap. it's gone. buddy, get the 50 mmr pulley for the roush. it's so worth it. I swear you will thank me.
    BassAckwards[QUOTED] likes this.
  20. Aug 7, 2019 at 6:17 PM
    zscott
    Zach
    Utah
    Yeah they are for ferrari’s found some for the subis too though. Anything for our trucks would have to be custom
