TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 8, 2019 at 5:31 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    All idler bearings replaced and my chirp is gone.
  2. Aug 8, 2019 at 7:53 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks for the link! i think i found those bearings i posted in DocME's post on the pg 1. Just wanted to be 110% sure those were the bearings needed.
    Good to know, i have a feeling my idlers need replacing. Just threw a new belt on 2500 miles ago so it's hard for me to believe its that. Will do some more troubleshooting now though since ive got the truck back up and running. Thanks for chiming in brother
  3. Aug 8, 2019 at 8:48 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Anyone see issues upgrading the fuel pump now before I get the SC? Trying to see what I can swap prior to doing the install to cut down on the work.
    I can post a list and see what I. And do but figure most is SC dependent except radiator and maybe fuel pump.
  4. Aug 8, 2019 at 8:52 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Not going to hurt anything, but will for sure help your work load when you get your supercharger and everything.
  5. Aug 8, 2019 at 9:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do it first.
  6. Aug 8, 2019 at 9:06 AM
    nudavinci64
    Robert
    Thanks! Figured it couldn’t hurt.
    DocME likes this.
  7. Aug 8, 2019 at 4:19 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I have a one way check valve on my fuel line to maintain pressure so the truck doesn't have a slow start. credit goes to @crashnburn80. he may have a few left. you may want it.
    TodayWasTHeDaY likes this.
  8. Aug 8, 2019 at 4:21 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Looky looky.
    To quote ThomasMore66,"It's happening!"
  9. Aug 8, 2019 at 4:37 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so cool! Kiel keeping us updated like this is a great thing. professional.
    12TRDTacoma[OP] likes this.
  10. Aug 8, 2019 at 4:40 PM
    nudavinci64
    Robert
    Tell me more? @crashnburn80 what’s the deal?
  11. Aug 8, 2019 at 4:43 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    the 255 can leak down pressure causing a slow start. just more cranking than needed. a check valve holds line pressure making starting exactly like stock. I believe he bought a few thinking other guys would want them. I think he has a couple laying around. he always buys the best quality stuff.
    Norton and BassAckwards like this.
  12. Aug 8, 2019 at 4:45 PM
    nudavinci64
    Robert
    I picked up the AEM 320 assuming same deal. I’m game for making it all better. That’s the idea right?
  13. Aug 8, 2019 at 4:52 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
  14. Aug 8, 2019 at 4:58 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have had the issue once every year or so on my AEM green top. Maybe twice on a bad year. Twice out of 365 days of the year for me does not justify installing an inline check valve.
    Not a bad rate considering I've had the pump in for the last 5 years.
  15. Aug 8, 2019 at 4:59 PM
    nudavinci64
    Robert
    I just picked it up off Amazon. Does URD provide some other stuff?
  16. Aug 8, 2019 at 5:01 PM
    nudavinci64
    Robert
    Makes sense. I am in there already no harm in adding it but not a deal breaker.
  17. Aug 8, 2019 at 5:11 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I don't think you need it with the aem. it's not in the tank anyway. you could add IF needed later.
  18. Aug 8, 2019 at 5:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I bought those as well. use a heat gun or boiling hot water to install it.
  19. Aug 8, 2019 at 5:21 PM
    nudavinci64
    Robert
    The AEM is an intank pump
  20. Aug 8, 2019 at 5:22 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    He's talking about the check valve
