TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 9, 2019 at 5:30 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    It doesn’t work. Thomas Moore tried it and a lower bracket from the s/c components would interfere with that hps hose. I had a set and was gonna put them on but didn’t cuz he found out it wouldn’t work....
    rheath08[QUOTED] likes this.
  2. Aug 9, 2019 at 5:40 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Want
  3. Aug 9, 2019 at 5:58 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I've gotten pretty good at cutting belts. using a kitchen cutting board and a few brand new blades in a knife make it near perfect. just be aware to hold the knife straight up and down. the 80 grit sand at idle is a slick move man!
  4. Aug 9, 2019 at 6:02 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Thank you sir.
  5. Aug 9, 2019 at 6:18 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    My cuts are good. My OCD just gets the best of me and they have to be right on like the other side. I use a razor in a vice but the razors deviates the cut as you go so that's the issue really.
  6. Aug 9, 2019 at 6:23 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I follow you. I found a cutting board to work great. just take your time and remind yourself what the belt costs:) do you feel the rpm is better than the green belt?
  7. Aug 9, 2019 at 7:10 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I did mine this year too.
    Roof: 80mil cld, heat wave pro thermal barrier, 1/2 melamine foam
    Doors and walls: 80mil cld, 1/2 melamine foam, 1/4 ccf and 1/8” mlv
    Floors: 80mil cld, heat wave pro thermal barrier, 1/4 ccf and 1/8” mlv
    Huge difference in road and exhaust noise. Totally worth the 3-4 days it took. You think you’re nervous about dropping the headliner, the FJ one is huge and difficult to manage. But ultimately it ended up being easy. Additional thickness behind the panels was easy to manage. Took a little finesse and trimming but got it done.
  8. Aug 9, 2019 at 7:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    By far man. After doing some research I found that the Green fleetrunner belts were designed for high mileage fleet vehicles not for high boost applications.. most of us run high boost considering that we are stuck with 5 rib serpentine belt setups. We need the toughest stuff we could get our hands on. Obviously I need more time to test the belt to see how it holds up to time and heat, but so far I like it a lot!
  9. Aug 9, 2019 at 7:15 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well I have a new green ready to go on. maybe I'll switch things up next year if your test results prove high marks!
  10. Aug 9, 2019 at 8:09 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Im sure @BillDaCat8 knows how well the gates RPM belt last with time and heat. He’s been running one longer than most
    12TRDTacoma[OP] likes this.
  11. Aug 9, 2019 at 8:24 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Anywhere nearby you would suggest? But summer is almost over anyway, I think I can make it lol
    Couldn’t tell you. But yes, dual e fans.
    I actually asked him about it and he said the 2 are actually quite different because of my 6th gear. He suggested the a761 kit for what I’m trying to achieve.
    Also after many humorous calls back and forth between him and his distributor he decided to sell me the kit directly. Never again he says. He doesn’t like being liable for any issues that may arise.
    Thought absolutely everyone and their grandmas in here had the wrap mod
  12. Aug 9, 2019 at 8:47 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The blower whine doesn’t bother me, but I will deaden the firewall if the instrument panel ever comes out for any reason.
    I tried the Pioneer at the suggestion of a friend of mine. The Pioneer was ok, but I’ve always preferred Alpine and ended up switching to the ILX-207 and have been much happier with it.
  13. Aug 9, 2019 at 9:26 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Customer service is the biggest reason I switched from OVT to HPT. Mat was the first one to offer tuning for our trucks, but there were/are a lot of missed deadlines and broken promises. (He tends to over-promise, but under-deliver.)
    Buy your MPVI2 (with credits) from whatever reputable dealer currently offers the best deal. Then, contact @JustDSM for engine tuning assistance - he's the Tacoma (engine) Whisperer. If you have an AT, @nd4spdbh is the Tacoma (AT) Whisperer.
  14. Aug 9, 2019 at 9:47 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well said
    agree fully
  15. Aug 9, 2019 at 11:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I suggest taking it to a shop which has a good AC system service unit. That issue is not normal whatsoever and it could be a lot of things honestly, but the best way to do that is to put it on the machine to see what it is doing first.
    I took my wrap mod off while tracking down the source of the squeaking at idle. After thinking it over some I have ultimately decided to pull it because I want to lessen the idler rotational mass in the system and if I run one more that is one more which can fail.
    I like the blower whine also, the increase in noise at idle I may attempt to subdue some but I also understand it is somewhat of a necessary evil too given the configuration of the system. Hell it could be worse. We could be running cogged pulleys. Lol.
    I actually shyed away from Alpine because I read a lot of reviews of how they would die like a year or year and a half later after installation. It seemed to be pretty commonplace so I ultimately decided on the 8000NEX myself. I like it, and it's been a pretty solid unit. No real complaints and it is leaps and bounds better than the OE JBL headunit.
  16. Aug 10, 2019 at 12:10 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    crashnburn80[QUOTED] likes this.
  17. Aug 10, 2019 at 12:25 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Oh I'm so out if it's not rainbow colored as promised!
  18. Aug 10, 2019 at 7:54 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I've had Alpine equipment in nearly every vehicle I've owned and never had a failure. Like many automotive products, installation quality can greatly affect overall performance. If that many Alpine decks are going tits up within a year, someone screwed up the installs or just plain abused them.
  19. Aug 10, 2019 at 8:23 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Interesting so just running the shorter belt now? I liked the idea of running the normal length but that makes sense.
  20. Aug 10, 2019 at 8:24 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Got the same set up installed last summer (sans drilled). Only gets better after the break-in period. It’s a must if you have a ton of weight and/or get off road frequently. I’ve already gone through 2 pairs of stock calipers prior to these (mud got in them, Montana “gumbo” is too much for stock calipers). The only thing I was kinda annoyed about is that the “16” rims” version caliper were still barely too tight of a fit for my stock TRDOR wheels (when muddy would scratch caliper). Ended up getting bigger rims. No problems since.
