TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 10, 2019 at 8:57 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'll tell you what, I'll do you one better and I'll get you an iridium colored one. :D
    That was my thoughts too, but I didn't feel like rolling the dice so I went with the well reviewed Pioneer just to be on the safe side.
    I'm very choosy of the mods I do and how it impacts my time off these days.
    I've always ran the shorter belt which is appropriately sized for the pulley setup.
  2. Aug 10, 2019 at 11:27 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I have one that was just delivered yesterday. I will let you know how far off it is and how much modification it takes to make it fit
  3. Aug 10, 2019 at 12:01 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The urban assault vehicle!
    Stealthy.
  4. Aug 10, 2019 at 12:20 PM
    Roostfactor
    TX panhandle
    I am using most of it.
    I have a temp sensor inline for my Efan controller so I have a few inches of stock hose then the temp sensor, then the blue hose.
  5. Aug 10, 2019 at 12:25 PM
    Roostfactor
    TX panhandle
    I have his old set. It's what is on my truck now.
  6. Aug 10, 2019 at 1:23 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Dam.....he said that lower bracket was interfering with the hose. How did you get it to work?
  7. Aug 10, 2019 at 7:12 PM
    MTB Tac0
    MTB Tac0 Active Member
    I got a new to me supercharged Taco and it has a few things that I am not aware of the function:
    1. What does this little red button do? I'm assuming it's tied into the boost system?
    2. I have this cool digital display, but I have no idea what's it's displaying outside of the one labeled RPM. What does this show me and what should I be looking out for?
    3. What is the button on the boost pressure gauge for?
  8. Aug 10, 2019 at 7:16 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    My guess the button is for PLX Multifunction gauge or an aftermarket alarm systems valet switch.
    If I had to take a WAG at what your seeing: RPM, Engine Load, Air intake temp (at MAF), and Coolant temp.
    www.plxdevices.com
  9. Aug 10, 2019 at 8:41 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    We both wonder. I have pics.
  10. Aug 10, 2019 at 8:44 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah man I remember it clearly wouldn’t work.
  11. Aug 10, 2019 at 9:09 PM
    ThomasMore66
    Now a man needs to be careful picking a fight with a Dodge and Ford diesel, because you can turn the wick up on those and get hurt. But today I’m 2-0 and there was a lot of black smoke in my rear view mirror as I drove away.
  12. Aug 10, 2019 at 9:36 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Mexico's finest drivers!
    12TRDTacoma[OP] likes this.
  13. Aug 10, 2019 at 9:41 PM
    ThomasMore66
    Indeed. In the SE part of the country it’s easy to set the to set the hook with a loud stand on the throttle...must teach the little Tacoma a lesson...
  14. Aug 10, 2019 at 9:41 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Even if it was trimmed? I know the stock lower coolant hose has to have like 2” trimmed off for it to work.
  15. Aug 10, 2019 at 9:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    we could call hps and have them make a coolant hose that works for s/c specs. they can make anything. maybe another GB?
  16. Aug 10, 2019 at 9:55 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
  17. Aug 10, 2019 at 10:16 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    There is a specific trd part number for the proper size hose. It’s way overpriced from Toyota but they could use that for R&D.
  18. Aug 10, 2019 at 10:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'd be more than happy to get a hold of them if someone has the dimensions or a donor hose they would like to donate to them.
  19. Aug 10, 2019 at 11:31 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    That's what I'm talking about! Customer service!
  20. Aug 11, 2019 at 1:05 AM
    zscott
    Zach
    Utah
    Any benefit of having the sensor in the lower vs the upper? Or does it just depend on what temp you set your sensor at.
