TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 11, 2019 at 4:08 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Maybe 2000.
    Just went and checked. Lines looked okay other than a cracked line on the return up near the TB, but no oil spewing out of there. Didn’t see any kinks either.
  2. Aug 11, 2019 at 4:08 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Or cut and trim.
  3. Aug 11, 2019 at 4:10 PM
    Roostfactor
    TX panhandle
    If you have a cracked line there then it cant pull the vacuum it needs.
    Fix the cracked hose then report back. I'm surprised you aren't getting emissions cels.
  4. Aug 11, 2019 at 4:15 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'm not wanting to start one of those long debated topics, but while I do agree with most of that, I disagree with the catch can filtering the vapors out. Unless specifically designed to filter out the vapors and mist a catch can will usually only keep out oil. So technically speaking you will still be ingesting the mist or vapors back in through the intake but will catch the oil.
  5. Aug 11, 2019 at 4:15 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh okay, then as stated you have an obstruction somewhere assuming the build was done well.
    The fuel trims can see as much 18% lean to rich activity before it throws lean or rich codes surprisingly. Our PCM is admittedly fairly sloppy when it comes to throwing those codes. Sort of like 2000 era Fords and their misfire code population on the stored codes list.
  6. Aug 11, 2019 at 4:20 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I thought most of our cans had a steel wool of sorts that acts as an “oil mist eliminator”. The oil that’s being carried away by the air collects on the surface of the wool in the larger area of the cab (slowing down air velocities) and drops out. It’s not perfect, but it is effective. Do you have this type of media in yours?
    Norton likes this.
  7. Aug 11, 2019 at 4:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I actually don't run one. I have an OE style air/oil separator produced by Jaguar inline with the PCV to the blower intake. How effective it has been is anyone's guess. I have to do my cams soon so I'll be able to report back on that when it is time.
    Most of the catch cans I have seen do not have that steel wool you are referring to. Of course that was yesteryear when I followed those mods. New updates to the designs may have rolled out so I could be entirely wrong about modern day CCs.
  8. Aug 11, 2019 at 4:31 PM
    Roostfactor
    TX panhandle
    Oh here we go!
    You should NEVER have liquid oil going through there. Only the mist/gasses that make it into the valve covers gets sent through the pcv and/or the catch can.
    This IS the catch cans job in life, to condense the mist into larger droplets where they rest happily in the bottom of the catch can until being emptied.
    It doesnt matter if its fuel or oil must it will filter it!
    Vapor probably not so maybe it was my choice in wording.
    Norton likes this.
  9. Aug 11, 2019 at 4:31 PM
    DocME
    California
    '07 FJ Cruiser
    Either way a little oil mist won’t be too bad. I actually haven’t reinstalled mine since I installed the new engine. I did a 7th injector so I wanted to see how effective it is at unfouling the intake track and intercooler. I have a Davtron intercooler gauge to install, so I plan on cracking it open some “soon”
    Roostfactor likes this.
  10. Aug 11, 2019 at 4:34 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I actually am not opposed to mist running through, oil on the other hand is no bueno... Of course if a PCV works well there shouldn't be a bunch of oil running through, and with saying that I end my portion of the "catch can debate." :)
  11. Aug 11, 2019 at 4:34 PM
    Roostfactor
    TX panhandle
    I bought a cheap catch can then added one tube (inlet) that drops about halfway down the catch can and I added a course stainless scrubber to filter exactly as @DocME described.
  12. Aug 11, 2019 at 4:35 PM
    Kelvin
    Kelvin Wheeeeee
    I’m out and about but fuck it. This is why I carry a knife. Thou shall be done.
    I had an evap leak code awhile ago but that was because of a hose I forgot to reconnect.
    Mine has an 80 micron filter or something or other.
    Roostfactor[QUOTED] likes this.
  13. Aug 11, 2019 at 4:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I remember back in the early forum days of the mid 2000s the popular mod was to buy one of those Home Depot air compressor filters and rig it to work with the car or truck. We have definitely come a long way since that.
  14. Aug 11, 2019 at 4:43 PM
    Kelvin
    Kelvin Wheeeeee
    Just looked again. The crack doesn’t go all the way through the hose. Just pushed the hose further up the barb until the crack was no longer relevant.
  15. Aug 11, 2019 at 5:16 PM
    Roostfactor
    TX panhandle
    Well if you didnt have the problem before and you only changed one variable (catch can) then you know where the problem is....now to figure it out.
    Norton likes this.
  16. Aug 11, 2019 at 5:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Page 1 update to the belt section now includes the RPM series part numbers. :)
    PS: 2.5-2.6 can currently not play due to the build nature of these belts. If you do decide to play with these sizes be aware you may snap the belt. Belt sizing is THAT critical!
    This is just a preliminary edit for the time. There are ways around the lack of 2.5-2.7 belt options which I will write of between later today or tomorrow.
    Edit: Fully updated. Happy modding!
  17. Aug 11, 2019 at 8:56 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    What do you recommend for 2.5 pulley belts? I’ll have to use stock with possible wrap or a new belt.
  18. Aug 11, 2019 at 9:02 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Damn, Gates is pretty proud of that RPM belt huh? $84
    Edit: only $44 from rockauto
  19. Aug 11, 2019 at 9:12 PM
    Roostfactor
    TX panhandle
    69.5"
  20. Aug 11, 2019 at 9:28 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    green belt is good times. but always better can be had.
