TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 14, 2019 at 8:43 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    yah that was the original plan, hence a bit of a mod spree. Save some time and install while I am pulling and replacing parts anyway.
  2. Aug 14, 2019 at 8:44 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    you will have to drain the coolant again to do the supercharger, so might as well wait.
  3. Aug 14, 2019 at 8:56 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I've been wanting this.
  4. Aug 14, 2019 at 8:58 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Is there a part number for it?
  5. Aug 14, 2019 at 8:59 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It would be cool I agree, part of that was a joke, the other part of it makes it semi not feasible because the width of the belt needs to be wider in length and due to space constraints would not work unless we ran a redesigned thermostat housing with a snaked 45* degree downward curve, similar to how the Hilux has theirs.
  6. Aug 14, 2019 at 9:01 AM
    ThomasMore66
    Won't the Hilux one fit?
  7. Aug 14, 2019 at 9:10 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    henryp, oni06 and 12TRDTacoma[OP] like this.
  8. Aug 14, 2019 at 9:13 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Thank you @Norton. My senior moment for the morning.
    Norton likes this.
  9. Aug 14, 2019 at 9:19 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Good luck getting one.
    For some reason they are next to impossible to get and on top of that there may be multiple versions of the housing which sort of complicates it a little more. The end summary to it all is that it is more trouble to try to get a 6 rib design belt let alone attempt to do a fully cogged conversion than it is worth. We are better off slapping on a non stretch Gates RPM series belt and calling it a day.
  10. Aug 14, 2019 at 9:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Even if @Murphinator bought the last one ever in the US, there is a company making aftermarket versions of the vinyl floor equal to in OE quality. This would actually be a great mod for further sound deadening.
    Murphinator and zippsub9 like this.
  11. Aug 14, 2019 at 9:27 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Would you be willing to pull one of those plastic floor mat holders off and see if you could find a part number on the bottom side? I have been trying to track this down for months. Would like to add it to the thread with the part numbers for the flooring as well
    Norton likes this.
  12. Aug 14, 2019 at 9:30 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Do you have a link? Just curious
    Norton and BassAckwards like this.
  13. Aug 14, 2019 at 9:32 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Part Number: 08210-00820
    According to the vinyl floor thread.
    Norton and BassAckwards[QUOTED] like this.
  14. Aug 14, 2019 at 9:32 AM
    BassAckwards
  15. Aug 14, 2019 at 9:35 AM
    BassAckwards
    Those will work, however, they are a little different that the ones @oni06 has. Those were designed to be used with carpet i believe.. I'd really like to update the OP in the vinyl flooring thread if i can find the # on the ones pictured above. I have the 08210-00820 in my truck, and the floor mats get pulled back about an inch, and the clips themselves try to come out every week or so..
    Norton likes this.
  16. Aug 14, 2019 at 10:02 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    RPM will just be the same spec belt but in the Gates Racing variety.
    BassAckwards[QUOTED] likes this.
  17. Aug 14, 2019 at 10:12 AM
    BassAckwards
    Think the racing variety is worth the extra 35 bucks? My gut tells me yes..
  18. Aug 14, 2019 at 10:13 AM
    Kelvin
    Kelvin Wheeeeee
    Use the RPM belts whenever possible. Unless you plan on changing pulley size in a week. The RPM belts have no dust and don’t stretch.
  19. Aug 14, 2019 at 10:15 AM
    BassAckwards
    Appreciate the input. Definitely what im gonna do. Changing the belt is a pain on my truck, so id like to do it just once
  20. Aug 14, 2019 at 10:52 AM
    oni06
    oni06 Well-Known Member
    Sure. I can do that tonight when I get home.
