TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 19, 2019 at 2:21 PM
    420taco
    420taco Well-Known Member
    Justin
    PA
    Can't hurt to call around to all the local dealerships...
    Norton and rheath08 like this.
  2. Aug 19, 2019 at 2:31 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Really he cannot flash over the bullydog? Makes me want to go back and find his post about him saying he can.
    Like others have said, you should be able to drive to the dealer (gently). If you are going up a hill I would down shift to stay out of boost.
  3. Aug 19, 2019 at 2:46 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    If you can send him your ECU he could bench flash it with the TRD cal file for $75 - but I think going over the bullydog via ODBII is a no go.
    DocME and rheath08[QUOTED] like this.
  4. Aug 19, 2019 at 3:11 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Yeah, this is accurate. I had $ in hand at the time and was just looking for a opportunity to build an engine. To say they were uninterested was an understatement. I knew they had built a couple of them in the past and they were the natural go-to in this situation. I tried to convey to them that I knew what I was getting into, but they insisted that they just want to sell parts. No builds on this platform.
    Torspd likes this.
  5. Aug 19, 2019 at 3:15 PM
    DocME
    California
    '07 FJ Cruiser
    I have an HPtuner and like beers, but I'm not sure that's going to be too much help for you. The dealers in our areas have loaded the trd tune on multiple trucks. If you sweet talk them, I bet they'd do it for you......
  6. Aug 19, 2019 at 3:36 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    :wave: You ship me a n/a ecu and I can flash the trd tune for you.
  7. Aug 19, 2019 at 3:43 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    i have an extra ecu. can you write the vin at the same time? cause i will send you the extra and flash the magnuson in this ecu for now.
    DocME likes this.
  8. Aug 19, 2019 at 3:58 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    mine does the opposite. at times my aem gauge is right with my meth controller boost gauge. most of the time my meth boost reading is a lb or so higher. after talking to others here I have suspicion my aem gauge is less than accurate.
    DocME likes this.
  9. Aug 19, 2019 at 4:06 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    when I find an ecu I'll take you up on that offer for sure! glad you're happy with the new tune.
    nudavinci64 likes this.
  10. Aug 19, 2019 at 5:07 PM
    rheath08
    Russell
    Bakersfield, CA
    well. good news. one of the local dealers got back to me. they said they would program the ecu. the service manager did go there all the normal liability risks, twice. so i just got back from dropping it off with them before they changed their minds. lol. tomorrow......extended test drive!!!!!:burnrubber:
    BassAckwards, DocME, Norton and 4 others like this.
  11. Aug 19, 2019 at 5:08 PM
    rheath08
    Russell
    Bakersfield, CA
    thank all of you for the help and advise.
    DocME and 12TRDTacoma[OP] like this.
  12. Aug 19, 2019 at 5:14 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    What did you install internally other than cam gears? @rheath08
  13. Aug 19, 2019 at 5:16 PM
    TRON
    I thought you were installing new cams from Kelford
  14. Aug 19, 2019 at 5:18 PM
    rheath08
    Russell
    Bakersfield, CA
    @TRON no cams. just valve guide seals. i had oil consumption issue.
    12TRDTacoma[OP] likes this.
  15. Aug 19, 2019 at 5:20 PM
    rheath08
    Russell
    Bakersfield, CA
    by the way.......i am very surprised that i did not break the camshaft.:eek:
    my gears were so tight i rounded the hex on the cam on one side.
  16. Aug 19, 2019 at 5:26 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I’m not sure if I can write the vin. I no I can but it checks the truck when doing it to make sure it matches. Dunno what it actually checks but it does.
    loginfailed and rheath08[QUOTED] like this.
  17. Aug 19, 2019 at 5:27 PM
    rheath08
    Russell
    Bakersfield, CA
    i found a resolve for now. but, if i need my extra ecu programed ill hit you up. thank your for offering.
  18. Aug 19, 2019 at 5:36 PM
    rheath08
    Russell
    Bakersfield, CA
    @TRON i forgot. while i was that deep in the engine. i replaced the timing chains and tensioners, water pump, belt and oil pump. it all came out or was right there. so i might as well. so now she should be good for at least another 150k miles.
  19. Aug 19, 2019 at 5:38 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I flashed over the bullydog with OvTune but I think you need a trd tune of some sort to exist to overwrite (BD is a varient of trd tune).
    It may not be possible to go from straight a stock NA tune to OV.
  20. Aug 19, 2019 at 5:39 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    How much for a 2.3 pulley?
