TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 8, 2018 at 9:46 PM
    #1921
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Haha thanks man. Putting both at the same time wasn’t my initial plan, that’s for sure. But a window opened up and I went for it all. Hit a couple snags but got it all done in a weekend, just in time for work on Monday lol. It’s nice to finally be a part of the group after havin the SC sit in my garage mocking me the past 5 months that I’ve been home
    Murphinator and loginfailed like this.
  2. Mar 8, 2018 at 10:06 PM
    #1922
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You're very welcome!
    You can't datalog with the UCON until Scott loads the program on your laptop. You won't get the program unless you either have problems or get headers which would justify a new tune.
    The UCON doesn't record any data (that I know of) so you can't just plug in a laptop and download a bunch of data. The only way to datalog with the UCON is by having the program (Etune Lite) I believe installed by Scott, then you have to connect the laptop to UCON. When ready to datalog you hit the "start" button on Etune Lite and it only records for 60 seconds.
    If Scott ever remotes in to your UCON he will ask for 2 catalogs. One cruising at steady throttle on the freeway and one floored from a dead stop through 3rd gear.
    Then you email the 2 datalogs to Scott for him to check all the parameters.
    The intercooler pump will drain the battery if it's connected to the circuit in the instructions. That circuit runs the evap pump so NOW, after the truck is turned off the evap pump and intercooler pump turn on and off randomly.
  3. Mar 9, 2018 at 6:16 AM
    #1923
    Skootter14
    Jeremy
    That makes sense, is there a good alternative to this? ORis it wired to do this for a specific reason?
    loginfailed likes this.
  4. Mar 9, 2018 at 6:31 AM
    #1924
    Roostfactor
    TX panhandle
    Any source that only goes hot with ignition on is what you want. Mine is still connected to stock location but I plan on changing it at some point.
    No advantage to stock location.
    Skootter14, Murphinator and trekker like this.
  5. Mar 9, 2018 at 8:05 AM
    #1925
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ran mine to the main ignition wire inside the truck. The wire is a heavy guage and the color I believe is black with a red stripe. I installed a fuse in line for safety.
    Leak detection pump runs randomly while the truck is off. If the coolant pump is hooked to the place in the instructions, the pump will also run. No reason for the coolant pump to be running while the truck is off.
    Roostfactor likes this.
  6. Mar 9, 2018 at 8:15 AM
    #1926
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I've considered hard wiring my fuel pump to the ignition to get around the UCON sync time but haven't tested it yet.
    loginfailed and Roostfactor like this.
  7. Mar 9, 2018 at 8:38 AM
    #1927
    Skootter14
    Jeremy
    15A fuse?
    loginfailed[QUOTED] likes this.
  8. Mar 9, 2018 at 9:03 AM
    #1928
    Roostfactor
    TX panhandle
    Same rated fuse that is on the pump wiring I would think. Just extend the wire and route inside the truck to a dedicated ignition wire.
  9. Mar 9, 2018 at 9:34 AM
    #1929
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I've considered the same. Just haven't executed yet.
    Same as what is already used by Magnuson.
  10. Mar 9, 2018 at 9:56 AM
    #1930
    Skootter14
    Jeremy
    Yea I’ll have to double check but I’m pretty sure it was a 15A.
  11. Mar 9, 2018 at 4:18 PM
    #1931
    cdelgado14
    cdelgado14 Well-Known Member
    Alice,Texas
    Supercharged micro machine ;)
    Bilstein 3 inch w/ 5100's
  12. Mar 9, 2018 at 8:59 PM
    #1932
    ThomasMore66
    Dallas/Fort Worth & Durango
    You just parachuted in? We don’t play that way in this thread. You’ve gotta add something. And don’t start talking about fuel pumps.
  13. Mar 9, 2018 at 9:10 PM
    #1933
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Ill add
    Interesting catch can location inyour profile picture. Looks great
  14. Mar 9, 2018 at 9:30 PM
    #1934
    Skootter14
    Jeremy
    Is everyone running a catch can?
  15. Mar 9, 2018 at 9:38 PM
    #1935
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Ive been meaning to.....
  16. Mar 9, 2018 at 11:14 PM
    #1936
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I definitely recommend one for our TRD blowers cause they catch half a pint every 4000 to 5000 miles. Plus, the intercooler fins will thank you being oil free
  17. Mar 9, 2018 at 11:32 PM
    #1937
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Guess mine needs a really good cleaning then OOps.....
  18. Mar 10, 2018 at 12:38 AM
    #1938
    cdelgado14
    Alice,Texas
    I'm on page 13 of 97.give me some time lol
  19. Mar 10, 2018 at 2:52 AM
    #1939
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    I’m not. And no plans either.
    12TRDTacoma[OP] likes this.
  20. Mar 10, 2018 at 4:00 AM
    #1940
    GT7
    Grant
    Phoenix
    2013 DCLB
    I have similar results with mine. It gets alot.
    Ive been meaning to disconnect it and see what happens with my random misfire code.
