TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 26, 2019 at 2:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
  2. Aug 26, 2019 at 2:13 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    he currently has a far better tan. cut me some slack. this area isn't known for sun.
  3. Aug 26, 2019 at 2:15 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well, I aint got no nothin' on that.
  4. Aug 26, 2019 at 2:15 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Boo
    loginfailed[QUOTED] likes this.
  5. Aug 26, 2019 at 2:16 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Goode thing I have a day job, eh?
  6. Aug 26, 2019 at 2:16 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well, I can't impress everyone. ask all my exes.
  7. Aug 26, 2019 at 2:17 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    :rofl:
    :rofl::rofl:
  8. Aug 26, 2019 at 2:17 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I made the mistake of looking up what he looks like. Great. Now you just sent me down the crazy rabbit hole.
    Torspd[QUOTED] likes this.
  9. Aug 26, 2019 at 2:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    best I'm not the rabbit
    loginfailed likes this.
  10. Aug 26, 2019 at 2:19 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not unless you have a show called "cosmic disclosure" on YouTube. :rofl:
  11. Aug 26, 2019 at 2:20 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    cosmic and rabbit hole sound too offensive for tw.
  12. Aug 26, 2019 at 2:20 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Depends if he means rabbit hole or rabbit hole. Don’t want to know if it’s the ladder. :D
    12TRDTacoma[OP] likes this.
  13. Aug 26, 2019 at 2:21 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    sounds like a stool step I don't want any part of.
  14. Aug 26, 2019 at 2:22 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Might be a slippery slope. If you know what I mean. :D
  15. Aug 26, 2019 at 2:24 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    no. no I have no idea. probably best that way.
  16. Aug 26, 2019 at 4:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ha! Knew it would happen to at least one member. That is an epic adventure of a rabbit hole my friend. Have ye a Goode ole tyme.
  17. Aug 26, 2019 at 4:52 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so, is this like a Rick roll, but with a rabbit?
  18. Aug 26, 2019 at 5:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    More like follow the White Rabbit, like in the Matrix.
  19. Aug 27, 2019 at 10:56 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Just did a leak down test. Had some vibrations/mildly rough idle. I have a bad cylinder and supercharger in dire need of rebuild. Not sure if last shop screwed up the install. Lasted 20k miles. Good knowing you folks. Henry out of boost club for a few months till I can get it all figured. Thanks for all the help.
  20. Aug 27, 2019 at 11:01 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    How bad was the cylinder? Were you getting other symptoms like smoking or burning oil?
    BassAckwards and 12TRDTacoma[OP] like this.
