TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 28, 2019 at 5:56 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Believe it or not I actually use that area. I put my sunglasses in there because it's tucked in and since it's dark in there anyways no one thinks to look in there if all they see is black since my sunglasses bag is black.
    loginfailed, BassAckwards and mr.trd like this.
  2. Aug 28, 2019 at 6:13 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I do you mine too. I have a spare underbody led light that's quite bright and still room for a wallet. (mines rather thin now)
    mr.trd likes this.
  3. Aug 28, 2019 at 10:31 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Speaking of supercharged tundras...has anyone perused their forums? What kind of power are they making and do they have any good mod ideas we can steal :)
    I can't imagine they've been more creative than this group.
  4. Aug 28, 2019 at 11:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    They definitely have not. I have scoured many supercharger forums including theirs in pursuit of ideas outside of what I have originally added to our page and they definitely do not have the dedicated fanbase we do. The ones who are keep their secrets fairly tight under wraps because they don't want the others taking their ideas. Not here. Free trade, because we love each other and want to see each other go faster. ;)
    Average HP increase from their setups are about 100HP over stock, but then they run into a semi brick wall because they have plastic internals on their valve bodies and trannys which leads to frying of their transmissions. I believe it is their boost valves if I remember right. Unless they bust out their dedication tools and either modify said valve bodies and trannys or send them in for modification, they are in trouble.
  5. Aug 28, 2019 at 11:30 PM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Hey guys. I have an issue. My dyno guy still can’t work out what is happening with my boost cutting out at 3000rpm.
    The only thing I can think of is that this has something to do with the engine and ecu I have was bought second hand out of an automatic Ute and mine is a manual. Would this have anything to do with it?
  6. Aug 29, 2019 at 3:06 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I can’t think of a way that the ecu can control boost. It’s a mechanical operation. If you’re only missing boost the I would check for belt slip. What size belt are you running?
    Now if you’re saying the engine is cutting out or going flat at a certain rpm range then it could be your ecu/tuning. Did the ecu have the exact same part number from Toyota? I know you can put an automatic ecu in a manual, but I don’t know if you can go the other way. You’re tuning with HP Tuner?
    Athlaos likes this.
  7. Aug 29, 2019 at 3:29 AM
    australian hilux
    Justin
    None at this point
    I’m just running the same belt size as standard. I haven’t changed it since I changed to a smaller pulley.
    No one in Australia has the hp tuner software to tune the ecu from trd. It can only be done by someone who has a certain program to access the trd software. The guy who has my car now is able to do it.
    The engine does rev past 3000rpm but it’s a struggle.
    If the belt is slipping, would it make a slipping noise that is typically of a fan belt?
  8. Aug 29, 2019 at 3:31 AM
    australian hilux
    Justin
    None at this point
    What size belt would you recommend if I have gone a 2.55 pulley?
    Athlaos likes this.
  9. Aug 29, 2019 at 4:54 AM
    australian hilux
    Justin
    None at this point
    Actually I just realised something...it’s cant be the belt slipping because when I take off the vacuum line from the sc to the bypass valve I then get full boost all the way to red line. When I reconnect the vacuum line it goes back to no boost at 3000rpm.
    Athlaos likes this.
  10. Aug 29, 2019 at 4:56 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    A good buddy of mine has a single cab tundra s/c. I’ll ask to double check but I’m positive it’s unmodded putting out a little over 500
  11. Aug 29, 2019 at 6:36 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    billet plastic engine and tranny internals?:eek:
  12. Aug 29, 2019 at 6:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    plugged vaccum line??
    Athlaos likes this.
  13. Aug 29, 2019 at 7:13 AM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Have you not checked the vacuum line and get another bypass valve to test out. Its a mechanical problem not your ECU ;)
    Seems like this thread has somehow blown belt slip way out of proportion. 2.55 pulley and stock belt should have minimal belt slip.
  14. Aug 29, 2019 at 7:13 AM
    DocME
    California
    '07 FJ Cruiser
    Yeah that’s where your issue is at then. Technically you should be running a smaller belt length, you can verify what size and part numbers with the first post of this thread. If you have proper operation when you disconnect and plug that hose then you’ve got an issue there. Many of us put hose clamps on that line to keep it sealed when in boost. Maybe you could take a picture of it for us, just to confirm it’s connected properly?
  15. Aug 29, 2019 at 7:23 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    possibly a leak when a certain pressure is reached was all I could think of.
    TodayWasTHeDaY and DocME[QUOTED] like this.
  16. Aug 29, 2019 at 7:39 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The engines are cool. It's the trannys which are the Achilles heel after the 600HP mark because of the internal boost valves being made of plastic. At least from what I remember.
  17. Aug 29, 2019 at 7:45 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that sounds like a machinist could make parts to solve that.
  18. Aug 29, 2019 at 7:47 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    If I could get my hands on one and there was some demand... It cant be that hard of a part to machine.
  19. Aug 29, 2019 at 7:57 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I wonder if a trans shop with a parts unit would have one? ebay? dealer?
  20. Aug 29, 2019 at 8:03 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1 to all of this.
    FWIW, I'm running a stock belt on a 2.5" RIP-Modded Pulley with @Roostfactor's Pulley Wrap Mod, and have yet to experience any belt slip.
    JuanitoBonito, DocME and BassAckwards like this.
