TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 30, 2019 at 8:14 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Hey guys, I think it was in this thread that someone mentioned a voltage transformer to increase the voltage output by the alternator just slightly. Can anyone send a link for me to purchase one?
    Roostfactor likes this.
  2. Aug 30, 2019 at 8:17 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Athlaos[QUOTED] and DocME like this.
  3. Aug 30, 2019 at 8:17 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Athlaos likes this.
  4. Aug 30, 2019 at 8:19 AM
    DocME
    California
    '07 FJ Cruiser
    Looks like HKB is closed until: 14/9/2019
    Might one to look for one second hand, or you'll have to wait it out.
    Athlaos likes this.
  5. Aug 30, 2019 at 8:34 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Whats the general consensus here on the bully dog tune vs the 90l trd tune reflash. I have my own opinion in that the trd tune would more more consistent and reliable than the bully dog tune. I think the way the hptuner works is that it cannot upload a supercharger tune by itself, load table limitations I believe, so I was planning on getting the 'tuner' kit and get the 90l but was hesitant as I believe the 90l defeats you doing burnouts, fake recall b.s., where it closes the throttle if both the accelerator and brake are applied unless you bypass the pedal inputs.
  6. Aug 30, 2019 at 8:45 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I hate that brake/throttle restriction, so annoying.
    As far as BD vs trd. I’m not sure. Some people ran the BD with 0 issues, others their truck was running dangerously lean. I would like to think the BD would expand the tables but I don’t know if anyone has confirmed that it does.
    o0opackersfano0o likes this.
  7. Aug 30, 2019 at 8:52 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Send in ECU to OVTune to have them load the TRD map. Get TIS and a Mongoose cable to load it yourself. (More expensive)
  8. Aug 30, 2019 at 9:03 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Rather do the 2nd one for a quicker option. Time isn't on my side atm.
    loginfailed likes this.
  9. Aug 30, 2019 at 9:06 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yeah id rather be rich than lean even more so with my dd. Trd tune had some inconsistencies but I had understood it to be less than bd. I'm sure I could come up with a defeat method but was looking for a turn key method.
    12TRDTacoma[OP] likes this.
  10. Aug 30, 2019 at 9:13 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If you come to Houston anytime soon, we can use my Mongoose cable to do it.
  11. Aug 30, 2019 at 9:16 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Sweet, I'll take you up on that offer. ATM I'm trying to get the foundations done first. Trans, jfr y pipe, afr gauge, trutrac. Then boost time. Unless theres a good sale deal. ;)
  12. Aug 30, 2019 at 9:21 AM
    Athlaos
    Leigh
    Edmonton
    In that case... does anyone have a second-hand blade fuse they'd like to sell me?
  13. Aug 30, 2019 at 9:23 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I ordered mine direct, not from eBay. The link direct is on that page I sent you. I did not see anything about them being closed, but I only have order confirmation thus far and no way to track if it has shipped.
  14. Aug 30, 2019 at 9:24 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have been trying to do this myself. I have the diode ready, but need to find a add a fuse in the micro variety that will fit the fuse box. So far I have had no such luck doing so.
    I just recently tested my battery, and after 4 years of solid service and abuse it still had 804 CCA available out of the original 930 CCA it is rated. I love Odyssey and am a true believer now in their AGM batteries.
  15. Aug 30, 2019 at 9:29 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Haven't found any soot yet but am about about 99% certain there is a leak. AFRs are all over the place even under cruising. I am guessing a leak with cause that if the sensor is downstream of the leak.
  16. Aug 30, 2019 at 9:33 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Hell yeah man! Looking forward to having another person in the SA area with a s/c
  17. Aug 30, 2019 at 9:39 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You may want to get smoke tested from the intake on downward to make sure the supercharger is sealed up properly. If it is then smoke test the exhaust.
  18. Aug 30, 2019 at 9:41 AM
    DocME
    California
    '07 FJ Cruiser
    Why do I get the feeling he only wants the tune, not necessarily the S/C? Turbo?
    Just throw some compressed air in the tail pipe, skip the smoke?
  19. Aug 30, 2019 at 9:43 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That works as well. If he has the method or someone else does. I'm more partial to smoke because it is a visual thing for me.
    The air would work great if he has a water bottle with a little soap in it.
  20. Aug 30, 2019 at 9:46 AM
    BassAckwards
    Hmmmm.. you do have a good point. Now im curious! Hoping he gets a maggy though :fingerscrossed:
