TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 30, 2019 at 9:46 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Will my ported 76mm Lexus TB work for you guys? If so I’ve got one for sale.
  2. Aug 30, 2019 at 9:47 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I poor man smoke tested for leaks with a cigar. Air filter off and a rubber glove over where the air filter would be. Blow smoke into a vacuum line and see where it comes out if anywhere. Can also look at the rubber glove at that point to see how it is holding pressure.
  3. Aug 30, 2019 at 9:48 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Na I'm getting the supercharger just didnt feel like paying 5300 bucks for a bad tune.
    oni06, DocME[QUOTED] and BassAckwards like this.
  4. Aug 30, 2019 at 9:49 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Turbo would be standalone which i already have for the race truck.
    oni06 and BassAckwards like this.
  5. Aug 30, 2019 at 9:53 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    I dont think the supercharger is suspect. Never had an issue till I put the headers on. JBA headers aren't flush all the way across the plate that mounts to the exhaust ports. The pipe inlets are slightly raised and if the gasket doesn't hit them just right or if they are not tightened down evenly they will leak. I am sure that is what I have going on.
  6. Aug 30, 2019 at 9:54 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Sweet! I haven't been able to follow all the builds lately, so I didn't know what was in the works. I just figured you were after a cheap way to tune with the expanded tables.
    Great to see you joining the whine club!
    12TRDTacoma[OP] and BassAckwards like this.
  7. Aug 30, 2019 at 10:03 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Welp since my f250 is in the body shop for an undetermined amount of time I'll need a decent tow vehicle for my other projects. Plus I could use more speed and noise in my daily.
  8. Aug 30, 2019 at 10:25 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I'm interested in those plates if you wanna sell 'em.
  9. Aug 30, 2019 at 11:27 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Speechless
  10. Aug 30, 2019 at 12:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Currie, ECGS, Dynatrac?
  11. Aug 30, 2019 at 12:10 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ecgs
    420taco and BassAckwards like this.
  12. Aug 30, 2019 at 3:03 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Is this set up compatible with stock brake master cylinder/abs/a-trac?
  13. Aug 30, 2019 at 3:08 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Looks like you got some work to do!
    GT7[QUOTED] likes this.
  14. Aug 30, 2019 at 3:32 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Bring it here so I can mount it under my truck.
  15. Aug 30, 2019 at 3:43 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Not geared enough for that ;)
  16. Aug 30, 2019 at 3:44 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Yes but they do have a brake master cylinder upgrade from a sequoia Ill get eventually. I dont have atrac. It has stock plugins for abs
    henryp[QUOTED] likes this.
  17. Aug 30, 2019 at 3:46 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Same here. Wallet and glasses and random stuff. I would be lost without it
    12TRDTacoma[QUOTED][OP] and GT7 like this.
  18. Aug 30, 2019 at 3:52 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    What did you go with again? I just ordered my 37’s so I’m sure whatever you got will compliment them nicely.
  19. Aug 30, 2019 at 4:00 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    4.30s. Still need your help with shock relocation but my schedule is crazy as I assume yours is
    JuanitoBonito likes this.
  20. Aug 30, 2019 at 4:07 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Oh you meant you wouldn’t have enough gearing lol. And yes we will need to do your shock relocation at some point. But I’ve got a crazy busy schedule with this semester.
