TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Aug 30, 2019 at 4:21 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    TW internets, i need help. i have a Speedhut AFR gauge the Innovate LC-2. the Innovate has been connected to a boost gauge for over a year and i finally got around to running the O2 sensor lead through the firewall so now i have this:
    i went to the muffler shop to weld on the bung thinking i would be reading AFR in no time only to find out the first cat is pretty much snugged up right against the header. question: has anyone welded a bung on an OEM exhaust setup or do i need to get custom cat-back piping in order to get my sensor in there? i have a 2012 DC. thanks!
    the gauge on the left is kinda lame right now:
    loginfailed likes this.
  2. Aug 30, 2019 at 4:27 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    check under dog racing. think they are having a labor day sale.
    EDIT: my bad i got retailers mixed up
  3. Aug 30, 2019 at 4:33 PM
    rheath08
    Russell
    Bakersfield, CA
    i had the jba long tube headers and could never get them to seal right with their strange design to mount to the cylinder head
  4. Aug 30, 2019 at 4:54 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I originally put bungs in both stock headers. I had to remove the headers to actually drill the holes and then weld the bungs on. You have to be very careful where you put the bungs and make sure there is enough clearance for the sensor to stick out.
    Much easier to just mount the sensor somewhere down stream.
  5. Aug 30, 2019 at 5:10 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    No worries I'm expecting one from either urd, summit, superchargers online, etc for a labor day or this coming black Friday.
  6. Aug 30, 2019 at 5:21 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    muffler shop said they could install in the header but I thought the reading may get messed up. LC-2 instructions say to install before the cat and at least 24 inches downstream of the exhaust port outlet.
    so I can install after the 1st cat but before the 2nd?
  7. Aug 30, 2019 at 5:53 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I welded a bung into the stock header. It’s double wall tube, but it worked well
  8. Aug 30, 2019 at 6:11 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    I see. sounds like a common place to install. thanks for your input.
  9. Aug 30, 2019 at 8:26 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Going by the innovate 24” measurement, you’re landing somewhere on the y-pipe. Yes, after the cat the reading will be skewed somewhat, it will read a bit leaner than actual but it is still useful data.
    Way back when pic. A bit close to the exhaust port if innovates 24” recommendation is observed, but they worked fine.
    Torspd and lawless[QUOTED] like this.
  10. Aug 30, 2019 at 8:29 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    make sure the block off o2 plugs in the headers are on tight. I had a leak there too.
  11. Aug 30, 2019 at 8:31 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I haven't seen them cross reference in part compatible manner. find a toyota guy locally and see if the plug matches up.
  12. Aug 30, 2019 at 8:33 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I did on my factory y-pipe right at the merge. worked fine.
  13. Aug 30, 2019 at 8:40 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If I were starting over from the beginning knowing what I know now, I’d have done the same.
    lawless likes this.
  14. Aug 30, 2019 at 8:58 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    had I not had guys like you to learn by I may have put it by the muffler.
  15. Aug 30, 2019 at 9:48 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Well I’m using a 76mm off a 4.7 tundra right now. I know how much you guys like that TB.
    zippsub9 likes this.
  16. Aug 30, 2019 at 10:05 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    I think we may have a winner.
  17. Aug 31, 2019 at 1:24 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  18. Aug 31, 2019 at 6:54 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ours are off 5.7 tundras
    Kelvin[QUOTED] likes this.
  19. Aug 31, 2019 at 8:41 AM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Super jealous.
    TodayWasTHeDaY likes this.
  20. Aug 31, 2019 at 9:40 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    This one wont be missed
