TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 1, 2019 at 11:31 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i changed my shock mounts yesterday. now my truck can do yoga:D20190831_203636.jpg
    Hawk373, lawless, Torspd and 5 others like this.
  2. Sep 2, 2019 at 4:21 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Thanks for that. I think we have worked out the problem. The engine and ecu I put in my Ute was out of an automatic. My Ute is a manual. This seems to be the issue. The ecu is cutting off the vacuum to the sc once it hits around 3500rpm. We are now in the process of recalibrating the original ecu and allowing it to take boost. Hopefully it works. Will keep you all posted.
  3. Sep 2, 2019 at 8:40 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Interesting.
    @JustDSM, didn't you confirm an auto ECU works in MT application?
  4. Sep 2, 2019 at 9:44 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    When I converted my truck from auto to manual. It would run. For the most part. Every time I engaged the clutch it would have a 2-3 second delay before the throttle would start to operate again. I have multiple faults for the transmission with a check engine light on. I never tried to drive it hard. I never took it over 3k either.
  5. Sep 2, 2019 at 9:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Is it still this way, or remedied?
  6. Sep 2, 2019 at 9:49 AM
    rheath08
    Russell
    Bakersfield, CA
    No, I fixed it with in days of the conversion. I had a new ecu for a manual truck ready to go. I just drove it a couple of days to make sure every thing was good until I could take it to the dealer to program the new ecu to the truck. It has been 2-3 years since the convertion.
  7. Sep 2, 2019 at 10:25 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Yes sir! It will run just like a MT ECU equipped truck with a rev-hang delete tune on it. Using HPTuners to disable all the codes generated from the missing transmission inputs ensures it runs just like it should w/ no throttle issues.
  8. Sep 2, 2019 at 1:44 PM
    australian hilux
    Justin
    None at this point
    Bloody bingo! Sounds exactly like my issue!
  9. Sep 2, 2019 at 1:52 PM
    australian hilux
    Justin
    None at this point
    Must be a slight difference then of ecu I’m some way. Who knows! It’s weird. I think in my case we need to delete the auto trans from the ecu. If that doesn’t work then it’s re program the original ecu. Maybe the Hilux auto and manual are slightly different in some way. We known the engines are the same.
  10. Sep 2, 2019 at 1:57 PM
    australian hilux
    Justin
    None at this point
    Just out of curiosity, when you say you didn’t take it over 3k, is that because you didn’t want to or because you actually couldn’t get the car to go above 3k?
  11. Sep 2, 2019 at 2:48 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    some poor saps like me are stuck in relentless traffic. 3k is hard to achieve a lot of the time.
    loginfailed likes this.
  12. Sep 2, 2019 at 3:24 PM
    australian hilux
    Justin
    None at this point
    Haha!! So true
  13. Sep 2, 2019 at 3:32 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    you can drive like 130kph for miles with only a worry of hitting a roo or getting bit by an 8 legger when changing a tire.
  14. Sep 2, 2019 at 3:35 PM
    australian hilux
    Justin
    None at this point
    Hahaha! You know us pretty well down here! Yeah those bastards of Roos are everywhere. Just on my property alone I have around 50-70 just hanging around. Myself and neighbours shoot them a lot cause they eat a lot of our grass for our cattle. And yes the spiders can get the hair on your next standing. Lol
  15. Sep 2, 2019 at 3:44 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Ill come for a week, purchase my own ammo, and clear them out
    mr.trd, Torspd, Norton and 2 others like this.
  16. Sep 2, 2019 at 4:05 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hope you got some limit straps on that bad boy or you're gonna be rebuilding shocks reeeeeaaaalll quick. :D
  17. Sep 2, 2019 at 4:19 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    max both ways shock still has play. im in the safe zone. reason i was the grinder knome. i hired a pro to check and weld.
  18. Sep 2, 2019 at 4:21 PM
    VolcomTacoma
    Jeff
    NorCal
    Yeah but leafs are gonna flex more than you can do in your driveway. I'm not trying to talk down at all. Just don't wanna see broken shocks hahaha. I'm looking at around $1200 or so to rebuild all mine.
    Did you drop down to just the single main leaf and flex everything out? You'll see your max flex then to make sure the shocks are long enough/if you need limit straps.
  19. Sep 2, 2019 at 4:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i appreciate the advice. we lifted the truck side to side with a forklift finding maximum stretch, but with a full leaf pack. i rarely wheel it, and when i do im nowhere near your level of badassery.:bowdown:
  20. Sep 2, 2019 at 4:32 PM
    VolcomTacoma
    Jeff
    NorCal
    Sounds good! Yeah if you were doing any high speed stuff then I'd be worried. Low speed, for the most part you shouldn't be flexing out the leafs to the point where the shock will reach max extension, but high speed you can easily.
    Torspd likes this.
