TRD off road and TRD sport front spring differences??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Jul 5, 2015.
  1. Jul 5, 2015 at 12:14 AM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Im very curious as to if there is a height (actual spring construction height) and/or ride height difference between the stock TRD off road front springs (progressively wound) and the stock TRD sport spring (llinear wound)
    Just curious, Thank you
  2. Jul 5, 2015 at 10:44 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not that I am aware of. The main difference you have listed above will give a former ride for the sport, whereas the off road springs are designed to be smoother riding over bumpier terrain off road.
  3. Jul 5, 2015 at 10:54 AM
    kyleTRDtaco12
    Kyle
    New Jersey
    Alright, cool.. but I actually believe its the other way around... Im pretty sure the off road springs are the ones that are firmer as the progressive winds on the off road tighten slightly towards the top of the spring therefore increasing spring rate and thusly a firmer ride. And I also recall the majority of trd off road owners reporting a firmer ride as well. I have the trd sport linerar springs in my truck now (same as 4x4 sr5 and 4x4 base springs) and the ride is rather smooth
  4. Jul 5, 2015 at 11:01 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Progressive spring are designed to offer a lower initial spring rate, and then rapidly increase the spring rate as it is compressed. This gives a smooth ride over irregular surfaces while becoming much stiffer for larger amounts of suspension articulation.
    I did not drive a sport, only an SR5 and Off Road, so I cannot compare. But I believe Toyota states the sport had stiffer spring rates.
    kyleTRDtaco12[OP] likes this.
  5. Jul 5, 2015 at 11:41 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    SR5 / sport springs are the same.... TRD OR is the only one to have different springs in the front.
  6. Jul 5, 2015 at 12:00 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Wow, thats actually pretty interesting lol, that goes against everything ive been reading the last 3 years lol.
    But yeah, that aside, you're pretty sure that both the stock linear and stock progressive springs on these trucks are the same height off the vehicle completely and uncompressed sitting side by side next to each other?
  7. Jul 5, 2015 at 12:02 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Oh, and the sr5 utilizes the same springs as the sport, but not not the same shocks lol
  8. Jul 5, 2015 at 2:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I read your original post incorrectly, I was thinking mounted height. I'm not sure about unmounted height as I could see the OR spring compressing a little more once mounted due to the progressive design, so the springs could be very slightly taller. Again, not sure.
    What are you trying to accomplish?
  9. Jul 5, 2015 at 2:21 PM
    nd4spdbh
    SoCal
    also if i am not mistaken at least the Sport, but i think the SR5 as well have a larger diameter sway bar vs the TRD OR.
  10. Jul 5, 2015 at 2:43 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Ah,very good observations about the compressed state. Interesting. And im just trying to figure out all of the differences between both as I recently came into a set of free trd OR springs, but im running trd sport springs now. Most likely will not switch but I wanna expand my knowledge
