TRD Off-road Arb Locker
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Breakdown, Apr 13, 2025.
  1. Apr 13, 2025 at 11:21 AM
    Breakdown
    Breakdown [OP] Well-Known Member
    Could not find much info.
    swapped the rear to an arb locker. E locker light is staying on. Is there a way to get the light off? A bypass maybe?
  2. Apr 14, 2025 at 3:03 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    The ARB install manual has this:
    BarRedAmateur likes this.
  3. Apr 15, 2025 at 11:16 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    The 4x4 ECU is expecting to see a resistance on the wires that turn on the E-Locker. If that resistance is not present it thinks the E-Locker is not present and puts out a code/light. You must install a resistor across the two wires that feeds the old E-Locker. Value of the resistor I do not recall, but it was a small value. Look for the threads that detail the use of the E-locker at any time.
    Edit: I reread @4x4junkie response and it could work also, being it is from ARB.
