TRD off road have Open diff or LSD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by antspeed, Sep 22, 2008.
  1. Sep 22, 2008 at 4:49 PM
    antspeed
    antspeed [OP] Member
    Can you all please clarify something for me. I heard the TRD Off road package has an open differential with the locker and the Sport has the LSD. I thought all tacoma's had the LSD and the OFF ROAD package just adds the locker.
  2. Sep 22, 2008 at 4:50 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    TRD offroad has a Locker
  3. Sep 22, 2008 at 4:51 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The TRD Offroad package has the locker. But it is a fully OPEN DIFF until you engage the locker.
    The locker can only be engaged in 4lo range (from factory). When it's not engaged, it's an OPEN diff.
    The Sport has an LSD that is functional at all times and doesn't need to be engaged.
  4. Sep 22, 2008 at 5:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    but i wonder that since all 09's prerunner and 4x4 have auto lsd's standard, if the offroad has the auto lsd and the locker...since the auto lsd is just BS braking
  5. Sep 23, 2008 at 8:19 AM
    antspeed
    if I understand correctly prior to 08, tacos came with a real LSD, not the auto braking type the 09 has?
  6. Sep 23, 2008 at 8:22 AM
    The_Hodge
    SC
    thats right
  7. Sep 23, 2008 at 2:13 PM
    antspeed
    thats disappointing.
  8. Sep 23, 2008 at 3:29 PM
    Janster
    Jandy
    Lancaster, PA
    Some of them came with the auto lsd & VSC. It was an option.
  9. Sep 26, 2008 at 6:15 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Here is something strange. I have a base model 4dr 4x4 and I have the LSD. I didn't not order it just saw it on the lot. Is this odd?
  10. Sep 26, 2008 at 7:13 AM
    Janster
    Jandy
    Lancaster, PA
    Nope, you could get the LSD as an option on non-TRD trucks.
  11. Sep 26, 2008 at 7:16 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I have a SR5 Prerunner with the LSD also. I requested this option.
  12. Sep 26, 2008 at 7:44 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I new what I had just never saw it as an option. Thanks. I was under the impression that base model trucks only came with the open diff. Thought I just got lucky.
  13. Sep 26, 2008 at 7:49 AM
    Janster
    Jandy
    Lancaster, PA
    Lucky?
    I'd call that.... a good (and sneaky) salesman.
  14. Sep 26, 2008 at 8:37 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    My salesman was anything but good. They normally know less about the vehicles than I do. However I overlooked this and my heavy duty towing package. He understood towing package. So I don't have my heavy duty version. but hey that was my fault.
  15. Sep 26, 2008 at 8:39 AM
    antspeed
    is the auto LSD 4wheel or just on the rear axle?
  16. Sep 26, 2008 at 8:44 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Just the rear. Front is open.
  17. Sep 26, 2008 at 8:45 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Auto LSD is a fancy word for automatic brakes. It will not provide any extra power to your wheels. It will tap the brakes on the spinning wheel. On an open differential, this will provide a similar (but not the same) result as having a real LSD.
  18. Sep 26, 2008 at 8:46 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I don't think so. The auto LSD probably operates all the brakes in a manner similar to traction control.
  19. Sep 26, 2008 at 8:47 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I stand corrected.
  20. Sep 26, 2008 at 8:49 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    These are not the same systems from years ago. I just can't keep up. lol
